Old 06-26-2014, 12:49 PM   #57
GT86_2014
Drives: Raven
any news?
GT86_2014 is offline   Reply With Quote
Old 06-26-2014, 02:34 PM   #58
marcoaferrer
marcoaferrer's Avatar
Drives: Whiteout FR-S
so far nothing new. right now its a waiting game on getting the money together and deciding whether or not Im going to need swap out the intercooler and modify the A pipe. Im not trying to be secretive I just dont want to give out any half baked info watch people start screwing up there motors cause I gave wrong info. I feel more comfortable telling people what Im going to do after I test it lol knock on wood nothing goes boom like the dude that ran the sprintex 335.
marcoaferrer is offline   Reply With Quote
Old 06-27-2014, 01:21 PM   #59
GT86_2014
Drives: Raven
wish yoy big luck!!!
I have V2 upgraded system...
the way I am thinking is to switch to toothed belt system (cog style supercharger pulley and add the same pulley to the crank) but I will have to redesign mounting bracketry....
I am waiting for your update and will be first to follow your's way...
Old 06-27-2014, 01:26 PM   #60
Tye300
Tye300's Avatar
Drives: Toyota 86 TRD Version AT
Originally Posted by marcoaferrer View Post
@Tye300
Im getting the finances together so I can make the jump. Ive done the research if you couldnt already tell lol. Ill post more info once I start buying parts
Oh I can tell brother. I'm just waiting for you to blaze the trail so others can follow! Good luck on your build!
Tye300 is offline   Reply With Quote
Old 06-30-2014, 06:16 PM   #61
marcoaferrer
So I called up vortech today to get some specs on the intercooler in the kit. Tech told me that it will flow up to 1000 cfm before it becomes a restriction. On the stock vortech kit that isnt much of a problem since the H67B max flow is rated at 750cfm. But with the changes I'm planing to make to my kit it looks like Ill have to go ahead with my plan of swaping out the intercooler and changing up the charge pipe routing for a shorter design.
I might be able to get my stock washer fluid reservoir back in the car.
Old 07-14-2014, 04:29 PM   #62
Tye300
Tye300's Avatar
Any updates? @marcoaferrer
Old 07-14-2014, 05:07 PM   #63
sissupr
sissupr's Avatar
Drives: 2014 BRZ Premium - SWP
Vortech Supercharging - FAQ and Notes
Table of Contents
  • Kit Revisions
  • Install Instructions
  • v3-H67B Compressor Map
  • v3-H67B Blower Specs
  • Impeller Speeds vs. Pulley Size
  • V2 Upgrade Info
  • Pulley/Belt Combination Chart
  • Third Party Parts Suppliers / Rebuild Services
  • Idler Pulley Issues/Solutions
  • BPV/BOV Upgrades
  • Wastegate Integration
  • Possible Boost/Vacuum Leak
  • Oil Cooler Fitment / Modifications (PERRIN Specific post 3
  • Compatible EL/Longtube Headers
@Dezoris pointed out that the Vortech owners thread had gotten so long it was impossible to navigate through and find any specific info you might need. He wasnt the only one that felt so. Heres my shot at trying to compile what ever I can find that is relevant.
Ill be adding more as I filter through all the pages. Let me know if I miss something and Ill add it to this post. (This is going to be a constant work in progress) The goal is to have the important info and FAQ on the first page so people dont have to hunt it down.
Kit Revisions:
Install Instructions:
Manufacturer installation guide
http://www.vortechsuperchargers.com/images/97.pdf
Manufacturer V2 UPGRADE installation guide
Thx to @draggin_az
FR-S Oil Feed_Drain Manual 081613.pdf
Thx to
@RallySportDirect
http://www.ft86club.com/forums/showthread.php?t=39392
Thx to
@Dezoris
http://www.ft86club.com/forums/showthread.php?t=40792
Thx to
@Enjuku Racing
www.ft86club.com/forums/showthread.php?t=30900
Partial torque specs
Thx to
@Foobar
v3-H67B Compressor Map:
v3-H67B Blower Specs:
Max Speed - 52,000rpm
This number was provided by Vortech over the phone. The confusing part is that we have always been lead to believe the max impeller speed is 50,000rpm. I think i figured out what caused all the confusion. When the kit was originally released the blower it shipped with was the V3-H67BC.
According to Vortech support the new blower (V3-H67B) has a max impeller speed of 52,000rpm. This means that the 2.87 pulley overspins the blower by only 166rpm when the engine is at 7,400rpm.
Max Boost - 14psi
Max Flow - 750cfm
Max HP - 525HP
(Crank Horsepower)
Peak Efficiency - 71%
Impeller Speeds vs. Pulley Size:
Vortech Impeller RPM calculator
(Stock crank pulley diameter is 5.62, Use calculator labeled "V-2 / V-3 Calculator")
http://www.vortechsuperchargers.com/...id=33511#rpmv2
V2 Upgrade Info:
Part differences between V2 & V3 Blowers:
Cost of V3 -> V2 upgrade:
Thx to:
@draggin_az
$1,095 + Shipping
Thx to @draggin_az
Pulley/Belt Combination Chart:
Goodyear Gatorback belt part numbers:
Thx to
@DJCarbine
SuperchargerRebuild.com
SuperchargersOnline.com
JonBondPerformance.com
Idler Pulley Issues/Solutions:
Thx to @cb7tuner
BPV/BOV Upgrades:
Using the stock A Pipe from the kit:
Thx to:
@tye300
Link to write up with pictures. Comparison videos inside
http://www.ft86club.com/forums/showthread.php?t=67729
Thx to
@DJCarbine
Vortech Manufactured Option (Replaces A Pipe):
http://www.ft86club.com/forums/showp...33&postcount=1
Wastegate Integration:
No exact details but an apparent functioning example of limiting boost via EBC
Possible Boost/Vacuum Leak:
Thx to @spdbydesign
Detailed Pictures:
http://www.ft86club.com/forums/showp...&postcount=528
Thx to @Sportsguy83@KAB-FRS
It can be done with out removing the intake manifold:
http://www.ft86club.com/forums/showp...91&postcount=1
Oil Cooler Fitment / Modifications:
Perrin Oil Cooler
Scroll down to Dezoris post below.
Mishimoto Oil Cooler
Supplied cooler mounting bracket NOT COMPATIBLE. Custom solution required
Thx to
@tye300
http://www.ft86club.com/forums/showp...&postcount=276
Compatible EL/Longtube Headers:
(As headers are confirmed theyll be added)
JDL Catted EL (With minor modification to blower bracket)
NOT COMPATIBLE WITH V2 OIL FED UNITS
Thx to @kiichiro
HKS EL Headers
Thx to @Drift-Office
Full thread can be found here: http://www.ft86club.com/forums/showthread.php?t=45835
How do you know if you have the updated D-Tube? anyone have a pic?
Vortech SC V3 // 3.12 Pulley // Moto-East Tune (93oct,e40-50,e85)
sissupr is offline   Reply With Quote
Old 07-14-2014, 05:16 PM   #64
marcoaferrer
So heres what Ive gathered so far.
The stock vortech to intercooler is rated to 1000cfm. The blower I was looking at what the V3-SI which would put the blower output at somewhere between 18-20 psi on a 2.87 pulley and right around the same efficiency range as the as the stock blower.
blower specs
http://www.vortechsuperchargers.com/page.php?id=30148
I was looking into customizing the IC routing in a similar configuration as the JDL turbo kit. This isnt that hard to accomplish especially if you rotate the volute on the blower. There are 2 setting bolts (2-4 bolts actually I cant remember exactly) that allow you to rotate the position of the discharge outlet of the blower.
EDIT: The volute angle is held in place by 6 allen bolts. After removing the bolts hold the blower and tap it with a rubber mallet to loosen its rotation.
I was about ready to pull the trigger but was advised against it. I know sucks to hear but its based on my personal circumstances. It doesnt mean that someone else cant try my plan out. Reason why Im backing out is cause with the larger blower Im basically married to e85 forever since theres no way to limit boost efficiently. Even with a wastegated setup the engine is still doing the work for 18 psi even if I limit it to 12 so it starts to become an issue of engine stress. Also although it should be possible to break the 400-450 whp mark with this setup the stress put on the engine would be the same as a 550+whp turbo setup.
Vortech is honoring their exchange program that they have in place for other platforms for our kits. So if you send in your blower they will rate its condition. They will then credit you anywhere from $500 - $1000 on a new blower. With the V3-SI costing around $2400 the max someone would have the come out of pocket is $1900 to upgrade, min cost $1400.
You can skip the custom IC piping and bolt the larger blower right up to our bracketry but once you start really pushing the blower youll start to bottle neck at the intercooler.
If I do end up not pursuing this route Im still going to look into getting a custom impeller made for the stock blower to at least bump up this blowers max output a little in the mean time. Probably somewhere between 2-4 additional psi.
EDIT: bunch of typos lol....
Old 07-14-2014, 05:18 PM   #65
marcoaferrer
Let me see if i can find a pic. but one easy way to tell is by seeing if your pipe has any visible welds on it and a little dent near the blower pulley
Old 07-14-2014, 06:02 PM   #66
sissupr
sissupr's Avatar
Sorry. I missed that the new one is cast. I have the old welded one. The reason why im asking is im noticing that the pipe is rubbing on the blower bolt. Not sure if the new cast pipe addresses all clearence issues throughout the routing or if this is just alignment with my specific install...
Old 07-14-2014, 06:12 PM   #67
marcoaferrer
With enough tweaking you should be able to get it to not hit. I have about 2mm of clearance but I have everything tight enough that it doesnt move even after closing the hood.
Old 07-15-2014, 09:14 AM   #68
draggin_az
Small penis big dreams
draggin_az's Avatar
Drives: '13 Scion FR-S
after a lot of tuning and dyno time, you must have a proper exhaust set up to support the 2.87
long story short the engine will "choke out" at 6500rmps. beyond that the dyno will look like a heart about to explode on an EKG.
below 6500rpms the engine feels amazing and is much more responsive then the stock pulley.
custom header and overpipe are in the works.
v3 -> v2 Vortech SC / 2.87 pulley
Fuel pump, FIC 770 injectors, custom header back, perrin resonated CBE
277hp 93 octane
370hp on E-85
draggin_az is offline   Reply With Quote
Old 07-15-2014, 09:24 AM   #69
marcoaferrer
Awsome man. Can't wait to see what your final numbers are
Old 07-25-2014, 02:50 PM   #70
Jaden
Road-hole
Drives: 2013 Whiteout FR-S
yeah probably a different compressor housing.
I think another problem with the 2.62 pulley is that it puts the impeller speed at 57,143rpm which spins the blower faster than its 55k cap. I dont think there is much if any power to be made with a 2.62 pulley over the 2.87. Hell I could be wrong, but the numbers seem to point to no.
Im working on a solution to bring the power output for a vortech kit over the 400whp mark and maybe even the 450whp mark but it requires some changes to the kit.
You would probably need a different compressor housing to hit those numbers or a liquid to air intercooler because of the inefficiency of the compressor at the necessary boost levels, besides the fact that you're having to run at higher boost levels than you would with a more efficient compressor.
Jaden
Jaden is offline   Reply With Quote
New Vortech Maxflow Blow-Off Valve Upgrade for FT86 Supercharging Systems Brian@Vortech Forced Induction 168 08-08-2018 11:45 AM
Questions and Discussion on Vortech Supercharging Systems Brian@Vortech Forced Induction 1462 01-27-2017 02:05 PM
Vortech Supercharging System Update - More boost, more POWER! Brian@Vortech Forced Induction 337 03-12-2016 03:42 PM
Vortech Supercharging Systems Now Legal On 2 Continents... Brian@Vortech Forced Induction 27 01-22-2014 01:33 PM
New Vortech Supercharging System Information... Brian@Vortech Forced Induction 306 11-08-2012 05:49 PM
