#15 |
Because compromise ®
Drives: Red Herring
If you are using a sway bar as a boat anchor you want as heavy as possible.
It depends on what you are trying to achieve. Are you trying to reduce roll or change steering behavior? Don't forget there is no free lunch. The heavier the sway bar the less independence your suspension has at that end.
| The Following User Says Thank You to Captain Snooze For This Useful Post: | wparsons (07-13-2014) |
#16 |
Drives: ZC6, Junk of ALL sorts
# 1. Always know where your towel is.
ZC6-CBS, is home |
#17 | |
Drives: FT86
They will stop body roll alright but will make for a very uncompliant ride over anything but the smoothest of roads or track. Over bumpy corners it would likely become unsettled and skittish especially with stock dampers, might be best to talk to some others with bars that size or maybe go for something like 22 mm front 16 mm rear preferabably adjustable , think whiteline do those sizes |
#18 | |
Drives: Scion FRS
#19 | |
Drives: VW MK6 GTI | 13 Mustang GT
Makes sense. Perrin recommends running 19/16 F/R for their bars to get some flatness in turns but also to keep the most OEM ride.
#20 |
Drives: BRZ Pearl White
I think adding stiffer bars makes more sense than increasing the spring rate which is already reasonably high for a street car.
Going that big however, may compromise your ability to get the meagre power down exiting corners, especially if the track isn't smooth. On the street you might find the handling a little alarming over any sort of bumpy curves. The other thing is Whiteline, for example, recommends you consider just increasing front roll bar stiffness first. Reason is the FRS is a bit soft in the front relative to the rear. The BRZ is likely a little quicker on most tracks because the front roll stiffness is already higher (springs not roll bar). My BRZ has 1.9 degrees negative rear camber (for street use) and I see you are only at 1.2. If you don't mind tire wear then increasing negative camber at the rear will be preferable to adding roll stiffness. Add a stiffer front bar (19 mm for example or as whiteline suggests 22mm) and if you get too much understeer dial in more negative camber at the front as well if you have adjustable front camber which it seems you do. Only increase rear roll stiffness as a last resort if only because of the traction issues you can have if you try to put power and cornering power into the rear axle at the same time. Roll bars work by levering the outside spring (wheel actually but the effect is to add spring rate to one side and to the other side but the inside wheel spring rate addition reduces the drooping of the inside spring so does actually increase the spring rate on both sides at the same time) against the inside spring with the twist in the bar proportional to the force trying to lift the inside wheel, springs work independently of each other which is why you need twice the roll bar rate increase to deliver the same roll control as changing just the spring rate. Roll bars tend to lift the inside wheel more than increasing spring rate would. There's no free lunch in return for that smoother ride.... Last edited by Ubersuber; 07-13-2014 at 12:10 PM. |
| The Following User Says Thank You to Ubersuber For This Useful Post: | steve99 (07-13-2014) |
#21 |
Drives: Subaru BRZ Limited M/T
Remember that a 25 mm hollow bar is equivalent to about a 22mm solid bar. Per RCE website.
I'm running a 20mm solid bar Superpro front with Whiteline end links. Koni dampers. From stock with front bar only. I found balance excellent, good turn in, no under steer. Now with the Koni's, I'm at full stuff at the rear and 1/4 to 1/2 from soft in the front. Sent from my iPhone using Tapatalk |
#22 |
Small phone for fat fingers.
This seems to be opposite to everyone else with the same setup. Thinking of putting the stock bar back on, but putting the yellow springs in. I autocross the car. Last race I found braking hard on entry, slow in, settled it all down. I now had power out of the corners. This is just an example of what happens when you do change the suspension balance. So research and be prepared for a change that will require additional changes. That why the shops sell packaged deals. Sent from my iPhone using Tapatalk |
#23 |
Drives: Red Herring
The rear is softer than the front. Don't forget motion ratio.
#24 | |
Drives: FT86
Suspension setting / changes are so complex i dont claim to know much :-) |
#25 |
Most definitely. Just put the RCE Yellows on. If you have ever driven a top tier German car, 98 M Roadster, there suspension is very firm but supple. Very flat cornering, you know it's stiffer but supple.find it hard to put into words. Wonder why I didn't do it in the first place. But STX now. More money.
#26 | |
Drives: FT86
18 to 25mm front stiffness increase = 270% 14 to 19 rear stiffness increase = 240% increase http://www.whiteline.com.au/docs/bulletins/BL-281.pdf |
#27 | |
The motion ratio actually favours the front springs, i.e. the rear lower arm acts as a lever on the rear coilover so the effective rate of the rear spring is lower than its actual rate. Motion ratio on the front strut is closer to 1:1 than at the rear coilover. Motion ratio also applies to the roll bar rate. The front roll bar drop link is on the strut itself and for practical purposes has the same motion ratio as the strut spring. At the rear the roll bar drop link is inboard of the coilover and so is even less effective than its diameter would suggest. Put another way both the rear spring and the roll bar have higher spring rates than needed because of the point of action being some distance inboard from the hub. Changing these spring rates would have less effect at the back than at the front, important to remember when trying to match changes front to rear. Putting a bigger bar on the front will add more to the spring rate than adding the same relative increase to the rear. |
| BRZ / F86 Sway bars | timlewis82 | Australia Classifieds | 3 | 02-02-2014 03:06 AM |
| BRZ / F86 Sway bars | timlewis82 | AUSTRALIA | 1 | 11-11-2013 02:53 AM |
| WTB:OEM BR-Z REAR SWAY BAR | Ryeong86 | Want-To-Buy Requests | 1 | 09-04-2013 04:40 AM |
| Need help with sway bar purchase | ngabdala | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 31 | 09-22-2012 07:38 AM |
| STI rear sway bar | carbonBLUE | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 0 | 03-25-2012 12:58 PM |
