Drives: Scion FRS
Sway Bar
Was wondering how sway bars would affect the handling of the car. My current setup is
17x8 with 225/45/17 hancook rs3 v2 Whiteline camber bolts Front and rear centric rotors with HP+ pads Front is about -1.4 camber with 0 toe Rear is about -1.2 camber with 0 toe The kit I'm thinking about purchasing is the eibach sway bar kit. Will it increase cornering grip and decrease body roll? I've done 2 track days and I wanted to reduce body roll and increase cornering grip without going coilovers first. Eibach Front 25mm solid vs OEM Front 18mm Eibach Rear 19mm solid vs OEM Front 14mm Thanks |
They would definitely reduce body roll.
Many will say swaybars should only be used for fine-tuning balance but honestly they don't have to be limited to that. I think a set of swaybars for your uses will improve the car. That said, those are pretty big bars. - Andy |
Drives: Scion FRS
Thank you for the reply RCE. I decided to go with Eibach becuase i scored a really good deal with them. I really like the feel (for now) of the stock suspension, was just wanting less body roll with increased cornering grip. Is having such big bars a bad thing? I'm going to have to play around with the adjustments to still keep the overal neutral feel of the car.
AIM4APX
Drives: 2013 WRB BRZ Limited
I only put on the Strano 22mm bar:
http://www.stranoparts.com/partdetails.php?PartID=928 "This 4 pound 22mm tubular front sway bar for the Subaru BRZ and Scion FR-S is 1 pound lighter than stock, but stiffer. Stock is 18mm and 5 pounds." I'll say that I'm really happy with only upgrading the front bar. I think it adds a little more responsiveness to the front while still allowing the rear to be a little more planted with the softer oem sway. That 25mm does seem kind of fat. If the front becomes too stiff then you could start to get understeer. I'm not sure where that point is with our car or if 25mm is close or not.
"It's very difficult to present technology as an overtly positive sales device to people who want an emotional car" -Chris Harris
#5 | |
Undisputed El Presidente
Drives: Zenki 37J ZN6
Drives: Scion FRS
This is true and im not really about just buying cheap things. Like i mentioned before, I really enjoy the stock shocks/springs. judging by ur post, i guess its not good at all to run this setup with coilovers?
#7 | |
I know a few people personally and have read of multiple others who ended up downsizing sways after some time. Not saying that will happen but maybe do some research on how stiff they are at the varoous settings compared to stock and other bars. @Racecomp engineeting do you have data for the for of the oem bars? Seems to not be a reliable answer out there. |
Boosted Noob
Drives: '13 FRS MT KW SC, '05 4Runner 4WD
Sway Bar
I have the Eibachs front and back, both set to stiff (there are 2 settings for each). Made a big difference in how responsive the steering feels and how flat it corners now. With that said, things are a bit more uncomfortable over bumps now and I occasionally have problems with driveways having a rear wheel in the air momentarily. So in summary, sways make a big difference in turning and onramps, but you lose some of the comfort of the stock setup.
Drives: 2014 Pearl White BRZ
If you aren't sure - start out with your sway bars as "soft" (short) as possible front and rear. They will most likely still be stiffer than stock. Go from there.
#10 |
Because compromise ®
Drives: Red Herring
I'm not quite sure what you meant by this but the way I read it you are giving incorrect information.
#11 |
Sorry - check your instructions for your specific type
#12 |
Drives: Red Herring
I do not know what you mean by this. Specific type of what? To the best of my knowledge all makes of sway bars for BRZ/FR-S/86 work the same way.
#13 |
Drives: 2015 Series.Blue
#14 |
Drives: 2013 MT Asphalt FRS
I'm also keeping my coils as is and wanted to get some sway bars as well.
Was actually thinking of going with TRD but these reviews you guys are giving seem really good. So what's better, a heavier or lighter sway bar? |
| BRZ / F86 Sway bars | timlewis82 | Australia Classifieds | 3 | 02-02-2014 03:06 AM |
| BRZ / F86 Sway bars | timlewis82 | AUSTRALIA | 1 | 11-11-2013 02:53 AM |
| WTB:OEM BR-Z REAR SWAY BAR | Ryeong86 | Want-To-Buy Requests | 1 | 09-04-2013 04:40 AM |
| Need help with sway bar purchase | ngabdala | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 31 | 09-22-2012 07:38 AM |
| STI rear sway bar | carbonBLUE | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 0 | 03-25-2012 12:58 PM |
