Old 07-12-2014, 02:00 AM   #1947
Khorne
Super 86
Khorne's Avatar
Drives: Red 86 GTS
Originally Posted by s2d4 View Post
Ahh, got ya.
Sounds alright although the tuner is more important, probably easier to send a kit to shiv and get it sorted like the ESC and the SBD turbo.
I'm still trying to nail down the exactities around it, who is actually doing the tuning of it etc. Also the possibility of getting a custom dyno tune with it as well.
We'll see, either way more options are better. The only info i was able to extract on date is "soon" some bugs to work out and the car sounds pretty rough at the moment.
230rwhp/184ftlb on 98RON/93AKI
Build thread
Red 86 GTS MT | Sprintex Intercooled Twin Screw SC | Invidia N1 | Mocal 10 row | Invidia Front Pipe | Motiv Overpipe| Enkei RPF01 with Bridgestone RE002s | MCA Blue Coilovers | Radium Catch Can
Khorne is offline   Reply With Quote
Old 07-12-2014, 02:05 AM   #1948
s2d4
s2d4's Avatar
If it's tokyomotorsport then it would be the same old, which is....
Agreed with the rest.
Old 07-13-2014, 01:41 AM   #1949
ST-A
Master Tuner
Drives: GT86 + Celica ST205 GT-4 WRC + MR2
we are almost ready with our basemapping for the KW kit, car runs very good allready and has some big grunt lolz, but we need the upgrade map sensor to go any further as it it now leaning out over about 400grams of boost.
we are using romraider + OFT
KW supercharger system
SARD equal length decat manifold
SARD catpipe
Milltek catback
Mishimoto low temp thermostat
Does anybody have the Honda part number for the upgrade denso map sensor?
ST-A is offline   Reply With Quote
Old 07-13-2014, 02:34 AM   #1950
nelsmar
SARD catpipe
Milltek catback
Denso #: 079800-5140
Honda #: 37830-PK-A01
My flickr - Canibeat
Local magazine scout
The Following User Says Thank You to nelsmar For This Useful Post:
ST-A (07-14-2014)
Old 07-13-2014, 02:40 AM   #1951
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
SARD catpipe
Milltek catback
It's not an upgraded map sensor you need but rather a larger diameter MAF housing (like in the Vortech kit). And then recalibrated the MAF table
Shiv@Openflash is offline   Reply With Quote
The Following User Says Thank You to Shiv@Openflash For This Useful Post:
ST-A (07-14-2014)
Old 07-13-2014, 11:14 AM   #1952
lookchris
lookchris's Avatar
I have a 2013 Limited BRZ and was wondering if any of you guys w/ push to start have problems starting your car after the flash? I'm just running the stage one flash
lookchris is offline   Reply With Quote
Old 07-14-2014, 12:37 PM   #1953
ST-A
Master Tuner
we are using stock MAF on the kraftwerks intake pipe, and rescaled maf with the help of long and short trim rescaling. max MAF at 5V is now at 324.16g/s
does that sound about right?
Old 07-14-2014, 12:40 PM   #1954
Shiv@Openflash
Drives: 2013 FRS
Is the diameter of the KW pipe bigger than the diameter of the stock MAF housing?
Old 07-15-2014, 01:13 AM   #1955
ST-A
Master Tuner
have to check to be sure but it looks like it. the KW pipe is same size as throttle body
Old 07-15-2014, 01:38 AM   #1956
steve99
Drives: FT86
Yep have one of those no problems yet.
Follow direction on OFT (or flash software) after flash is completed turn car completely off.
Then turn on (don't touch accelerator),wait about 20 sec, should start straight up, let it idle for a minute or two (no throttle), then your good to go.
see here
http://www.ft86club.com/forums/showthread.php?t=68328
if your LTFT are large it might be worth scaling MAF, shortens up fuel trim learning process after flash or reset also get smoother drive and AFR closer to those set in OL Fuel tables.
http://www.ft86club.com/forums/showthread.php?t=64790
lookchris (07-15-2014)
Old 07-15-2014, 10:35 AM   #1957
lookchris
lookchris's Avatar
see here
My cars been flashed for awhile. It just started out of no where recently. My guess is it might just be my switch
Old 07-17-2014, 02:39 PM   #1958
unsurety
aeiou
unsurety's Avatar
Drives: WRB BRZ
So will there ever be a BPB, E85, UEL/EH tune in the works? Or do you guys just run the stage 2 map?
Originally Posted by Shoebox View Post
For that price anyone could get a c6z and have money for a simple heads cam package and make a bunch more power and have a superior handling car. This seems overpriced to say the least. "Have it your way" is basically offering someone a massive dildo to shove up their ass BUT they have the option of choosing the method in which it is inserted....
unsurety is offline   Reply With Quote
Old 07-17-2014, 02:46 PM   #1959
steve99
Drives: FT86
Unlikely shiv said somewhere that BPB and E85 don't play well.
BPB move the powerband lower in the rpm range and E85 produces its best power above the rpm range where BPB work best, so it was counter productive.
Same deal for BPB and forced induction eg electric SC
Old 07-18-2014, 10:32 AM   #1960
lucid215
just flashed my 13 limited brz with the stage 1 rom. drove the car easy for a few miles to get the car to learn a bit. gave it a good 3rd gear pull and the power is very smooth. it may just be me or the car hasnt fully learned but it doesnt seem like the vvl doesnt kick in as hard. ill try to get some logs today. what exacly needs to be logged? thanks
lucid215 is offline   Reply With Quote
cat overtemp
OpenFlash Tablet Rombinhood@OpenFlash Software Tuning 1838 07-29-2023 06:35 PM
OpenFlash Tablet Stg 2 Tune (Dyno Progress) Rombinhood@OpenFlash Software Tuning 26 10-24-2013 01:19 PM
FBM Tuning fixed my issue, FA20 and Visconti didn't work as well whitefrs Forced Induction 253 08-19-2013 12:39 PM
