| BRZ First-Gen (2012+) — General Topics All discussions about the first-gen Subaru BRZ coupe |
#8877 |
I love peanut butter
Drives: 2013 SWP BRZ Limited
Trans and diff fluid changed yesterday with Motul 300 @ 29k miles. The fluid that came out of both looked good, it was a nice gold color. The drain plug for the diff was loaded with metal as I expected. Trans drain plug wasn't that bad.
#8878 |
Drives: Subaru BRZ 2014 Limited WRB
Took it into the dealership for some work yesterday.
Head Unit suddenly died last month - replaced under warranty (but noticed when I got home that it has "remanufactured" stickers on the back). Driver's side headlight had some kind of water stain on the inside, noticeable under certain lighting conditions at certain angles - replaced under warranty. Installed a Mini 0803 dashcam, running the wires under the headliner and passenger A pillar, behind the dash, and into the glove compartment power socket. Nice and clean. Plan to wash and polish today. |
#8879 |
Drives: 2015 BRZ
Yesterday I took my new BRZ with 8 miles on it and stuffed it with my six dogs and two ducks. 300 miles later and it is full of fur and feathers. I love this car and now it smells like it.
#8880 |
BAMF
Drives: 2014 SWP BRZ
Curious as to why...and how you had the need to put six dogs and two ducks in your brand new car?
#8881 |
Drives: 2015 BRZ
#8882 |
Drives: '13 BRZ Ltd WRB
Got new rubber yesterday in the form of Continental ExtremeContact DW 245/40. Put them on without spacers and the tire rubbed the spring perch (due to -1 degree camber). Added a 3mm spacer and it was super close, so I swapped up to 5mm and feel much better about it.
Maybe the tires are a bit over-inflated, but the steering has a really "light" feeling. Could also be the super deep tread being a little more squishy than the MPSS I removed. I also installed Whiteline KDT925 - Diff cradle and outrigger inserts. Easy install and did you know they're black now?? Blew my mind, I liked the little hints of yellow but the diff cradle inserts always looked a bit awful, so black is a good move.
#8883 |
Ignorance Intolerant
Drives: '13 WRB BRZ Limited
#8884 |
Are you 20/20?
Drives: Hopes and dreams
Awesome pictures, @chanomatik
What are you shooting with?
#8885 |
Power Ranger Elite
Drives: '13 WRB Sport-tech
Thanks man, I followed the link and just ordered a pair too. Did it require any thing other then swapping them out?
Also new exhaust!! And rain.. ![]()
#8886 | |
frank
Drives: Subaru BRZ WRB
do you have some links i should read up before i tackled these fluid changes?
2013 SUBARU BRZ WRB LIMITED M/T
Los Angeles, CA Build Photo Album - http://bit.ly/brz_wrb SoCal LA 86 Club Member ![]() |
#8887 | |
http://www.ft86club.com/forums/showthread.php?t=19218 For the differential, if you're using Motul that has the built-in spout it's a little hard to get the final drops out of the bottle. I added this remaining fluid to a fresh bottle then continued my fill. My diff held a little under 1.3L. With the transmission, once you squeeze out what you can from a bottle into the transmission, you can then wedge/prop the bottle above the fill hole draining downwards and let the remaining fluid run out by itself. It goes a little slow because there's no air vent but it shouldnt take more than 3-4 minutes. Motul bottle wedged upside down (above transmission) to fill what I couldn't squeeze out:
#8888 | |
Snow Don't Hurt!
#8889 | |
The color looks great. It's a little on the blue side, but that's probably because it's next to the 4500k headlights. But definitely > stock.
#8890 |
I removed my front lip today because of this...
| Saw My First FR-S Today | Marrk | Scion FR-S / Toyota 86 GT86 General Forum | 26 | 05-15-2013 12:40 PM |
| Got my new FR-S today. | Boosted2.0 | Scion FR-S / Toyota 86 GT86 General Forum | 51 | 06-03-2012 10:35 PM |
| Sat in a FRS today!! | Ladnerd | Scion FR-S / Toyota 86 GT86 General Forum | 12 | 04-30-2012 01:48 PM |
| Got my VIN today... | Enemies | BRZ First-Gen (2012+) — General Topics | 63 | 04-12-2012 10:19 PM |
| sat in a BRZ today | NESW20 | BRZ First-Gen (2012+) — General Topics | 8 | 03-31-2012 08:53 AM |
