#169 |
Drives: UK GT86
Thanks :p I actually tried something yesterday that @mad_sb suggested a while back; Running full time OL just to see how good my MAF scaling was, especially as I had encountered an area where the 2 were vastly different (as described in a previous post). The curves were actually very well matched, so for those who spend run after run doing lots of CL testing to see how accurate their MAF scale is, I suggest that once you think you're close you run in full time OL and then leave the MAF after that. Obviously you can then return the maps to run CL again. Here's the original thread for full info: http://www.ft86club.com/forums/showthread.php?t=57279 Taken from that thread.... How to Force Full Time Open Loop:
Use the same technique as above for Non-WOT OL scaling to get your results.
.: Stealth 86 :.
#170 |
Drives: FT86
#171 |
Why would you want to run full time open loop?
Are there any benefits?
![]() Last edited by s2d4; 07-04-2014 at 04:05 AM. |
#172 |
Drives: Celica 04
This is my log:
http://datazap.me/u/toy-sooby/maf-re...g=0&data=1-4-6 Weird... My LTFT is 0% throughout whole log! |
#173 | |
Drives: FT86
The commanded AFR and measured AFR are also following each other under load (on overrun ie closed throttle the difference is normal) so looks good ![]() you might see a couple of percent on the ltft as the IAT temperatures change 20 degrees or more but thats normal |
#174 | |
Drives: Celica 04
Thanks @steve99 for your great help and thanks @vgi for such a great program! I noticed afr of 12 is that considered dangerous? |
#175 | |
Drives: UK GT86
I guess if you know that it's always hitting targets then running full time OL is possible, but then STFT aren't active so you won't generate LTFT and this could be detrimental with seasonal and fuel changes. Reading RomRaider and other Subaru tuning sites, some people do run full time OL. I guess you could give it a go and keep an eye and log it and see what you think. AFR of 12 where? What makes you think 12 is dangerous? No AFR is dangerous until it results in knock. TBH around 12 isn't dangerous at WOT, it's right on the boundary of best power AFR and being rich, which is ideal. For reference, there is a "typical" value of 12.6-12.7 that is a rule of thumb for best power. However this is more of a vague guide rather than a set number, as you trade off AFR produced power for ignition timing produced power. So long as it's not knocking, it's safe.
.: Stealth 86 :.
Abbey Motorsport/K47 Tuned Sprintex 210 Supercharger Kodename 47 DJ: Soundcloud / Instagram / Facebook Last edited by Kodename47; 07-04-2014 at 04:54 AM. |
#176 | |
Drives: FT86
14.7 is stoich and is usually targeted during cruise and very low loads for max economy Max power is usually around 12.5 -13 afr on petrol NA motors low to mid 12's are considered on the rich side but these motors need to run quite rich as they are knock prone on our fuel anyway , its always a trade off more timing usually means more power (up to a point) and running richer than around 12.5 afr tends to loose power but provides some extra knock resistance, so experienced tuners will trade advance and AFR to find the best power at higher rpm under high load. |
#177 |
Drives: Celica 04
I am getting some LTFT around -5.47/-4.69/-3.91% around the following parameters:
Engine Load: Approx 0.3 MAF Voltage: 2.0-2.15 Engine Speed: Approx 2800-3000 Is it advisable to remove any LTFT that is in the good range in my data logs? i.e. around 0% and only process the problematic areas? Also, how does temperature variance affect the LTFT? i.e. If I data log and modify this at 60 degrees F compared to another day doing this at 80-90 degrees F? Thanks. |
#178 | |
Drives: FT86
If thats the only point thats a problem you can just manualy take say 3% off the values in that area of the maf scale to compensate for the negitive ltft at that point try to keep scale smooth no chunky bits :-) Last edited by steve99; 07-10-2014 at 10:49 PM. |
#179 | |
Drives: Celica 04
So just to get this right.. Decreasing values from the MAF scales is required for negative LTFT and Increasing Values is required for Positive LTFT? |
#180 | |
Drives: UK GT86
Positive trims: MAF value is too low - ECU "see's" less air, adds less fuel - trims go positive to add in more fuel Negative trims: MAF value is too high - ECU "see's" more air, adds more fuel - trims go negative to remove the excess fuel Hence if the trims are -5%, you have 5% too much fuel so you can just reduce the area by 5% to re-align things. @steve99 is correct, temperatures do make quite a difference. If you're logging in varying temperatures, it might be worth zeroing out the IAT compensations table while you do the MAF and then return it after.
.: Stealth 86 :.
#181 |
Drives: 2012 Toyota 86
maybe this is in here somewhere and i missed it, but ill ask. So im getting virtually 0 stft and ltft while wide open throttle, but my afr is a bit low, i ran vgi's scaling app and its still suggesting a new maf curve for open loop. im assuming this is to bring the afr closer to the targeted value?
#182 | |
Drives: FT86
Yes VGI utility will suggest MAF scale to bring your OL AFR in line with the OL Fuel table in RomRaider. I think shiv alters the maf scale to run a bit richer than what in the OL fuel table for safety and knock resistance. If you do lean out the top end just keep an eye out for any knock. your fuel is very likely better than ours so you might be able to lean it out to values in OL fuel table with no knock. |
| AFR in Closed Loop | Toyota John | Software Tuning | 39 | 07-07-2019 08:26 AM |
| BRZedit Fuel Trims, Closed to Open loop transiton | mad_sb | Engine, Exhaust, Transmission | 32 | 08-06-2015 03:14 AM |
| Notes on injector / maf scalining using full time open loop | mad_sb | Software Tuning | 40 | 03-03-2014 05:49 PM |
| Screencast: closed loop boost control with RaceRom | jamesm | Software Tuning | 2 | 02-10-2014 02:23 PM |
| Screencast: experimenting with full-time closed loop fueling | jamesm | Software Tuning | 2 | 12-27-2013 10:19 AM |
