| BRZ First-Gen (2012+) — General Topics All discussions about the first-gen Subaru BRZ coupe |
Drives: Sc10n Series FR-S
Where is your Fog light switch?
I want to add aftermarket fog lights to my FR-S and I was wondering where the switch is on the BRZ so I can replicate a factory look.
A picture would be awesome, thanks
I figure as long as you smile while driving the car, you're doing it right.
#2 |
Drives: 2013 Subaru BRZ (Galaxy Blue)
On the BRZ Limited it located on the head light stem.
![]() Others who have added it to their FR-S add it here. ![]() Here's a link from someone who did it to their FR-S http://www.ft86club.com/forums/showthread.php?t=40153 |
#3 |
They're on the turn signal stalk. I'd expect them to be the same place on the FR-S -- check your owner's manual, they probably have a picture (even if your model doesn't have them, the manual's the same for everyone).
The turn signal stalk tip twists for lights, right? The fog lights are controlled by a separate ring that rotates just inside (ie. closer to the steering column) that bit. ...Paul |
#4 |
Yeah FR-S doesn't have that extra wheel on the stalk. Since I have HID on mine there is no place for a switch next to the trunk release (HID level toggle is there )
Anyone have a part number of the BRZ light switch stalk? Sent from my SGH-T999 using Tapatalk 2
#5 |
u could get this
i think the part number is PT413-18130-LL ![]() the fog button is pushed in "on" thats why it looks weird Last edited by mush; 09-09-2013 at 08:06 PM. |
#6 |
JHerbert Racing
Drives: 2013 Scion FRS
Any idea what part number the button is?
#7 |
Berz
#8 |
JHerbert Racing
^thats the part number for the bezel. I found it on the linked thread though. Thanks
The button is 84160-12060 for future notice
#9 |
#10 |
Drives: 2013 FR-S 10 Series #1186
same for my 10 series which came with fogs from the dealer.
sent via mobile.
#11 |
Drive From Home
Drives: BRZ STI Performance
The optional front fog light switch is not on the stalk for the FRS, I think is because it probably doesn't have a wire from the stalk to the fuse box, and then from the fuse box to the fog harness.
This is also the reason why North American BRZ cannot readily do a factory retrofit of the rear fog light, as the wiring is totally missing. In Japan / Asia, the wiring is actually there, so the rear fog light is actually an option from the dealer. |
| So where will the fog light switch go... | Asphalt | Scion FR-S / Toyota 86 GT86 General Forum | 19 | 04-08-2019 07:09 PM |
| STi to BRZ? Who Else Made The Switch? | Haole-Pino | BRZ First-Gen (2012+) — General Topics | 78 | 11-01-2013 06:02 PM |
| 12v RCA Switch/Toggle? | MmmDieselFumes | Electronics | Audio | NAV | Infotainment | 23 | 08-13-2013 11:05 PM |
| How to replace turn signals with switch backs and its relay switch. | Scionshaun | Scion FR-S / Toyota 86 GT86 General Forum | 1 | 05-30-2013 11:42 PM |
| What is this switch? | AtlasMick | Electronics | Audio | NAV | Infotainment | 1 | 04-08-2013 08:35 AM |
