Old 07-10-2014, 05:42 AM   #1
mrharry
Drives: GT86
Looking for a new coilover .Need some advice
Hey guys
Im currently looking for a new coilover that is great on the track and can drop low. Im currently running BC BR with Swift springs.
Heres a list that im thinking of
RS*R Black i
MCA Red/Blue
any advice would be great
mrharry is offline   Reply With Quote
Old 07-10-2014, 06:58 AM   #2
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
Doesn't exist.
It has already been discussed that in Australia you are best off going with MCA. They are local and Murray and Josh are super helpful. Have you looked at MCA's website? If you had and you want to track your car you would know you want the Reds. A few people on theses forums have Reds (myself included) and one person I know of has Blues. MCAs are not made to go "low". There is a drop, I don't remember of how much but if you are wanting low then MCAs aren't for you as they were made for performance not show.
Here, have a read:
http://www.ft86club.com/forums/showthread.php?t=37468
http://www.ft86club.com/forums/showthread.php?t=32990
http://www.ft86club.com/forums/showthread.php?t=56419
http://www.ft86club.com/forums/showthread.php?t=36454
http://www.ft86club.com/forums/showthread.php?t=30492
Old 07-10-2014, 07:07 PM   #3
mrharry
Drives: GT86
Doesn't exist.
Here, have a read:
I plan to go low when its not going to be hitting the track and raise it up for the track when i go
Old 07-10-2014, 07:25 PM   #4
Digitalanalog
Drives: '13 BRZ Limited, '95 BMW M3
thats alot of alignments you'll be buying
Digitalanalog is offline   Reply With Quote
Old 07-10-2014, 08:19 PM   #5
boredom.is.me
Custom User Title
boredom.is.me's Avatar
Drives: Asphalt FR-S MT
There's a little something called lifetime alignments.
Old 07-11-2014, 03:01 AM   #6
Captain Snooze
Drives: Red Herring
What are they? Do they exist in Australia?
Old 07-11-2014, 09:16 AM   #7
boredom.is.me
Custom User Title
Sucks to suck. Here in le US of A, we have shops like Firestone that offer lifetime alignments. The FS LT price is about double the price of one so it's worth it. It isn't a "race" shop, but they get the job done.
Old 07-15-2014, 03:55 PM   #8
Jive Turkey
the tuna, no crust.
Jive Turkey's Avatar
Drives: 2014 Hachiroku of the year
yeah, if i bring my car to firestone they will have no idea what to do with half the suspension components. but it all depends on where you go i guess, each place is different. regardless i've aligned my car almost on a bi weekly basis to get it to how i want, i'm sure firestone would have told me to go away pretty quick.
what you're not stating is a budget.
coilovers need travel, slamming a quality coilover is just pretty pointless. stick with your BC's and swift springs in that case.
Jive Turkey is offline   Reply With Quote
Old 07-15-2014, 06:50 PM   #9
SomeoneWhoIsntMe
Drives: 2013 Subaru BRZ
lots of coilovers adjust ride height independently of spring preload by means of a threaded bottom bracket. there's also other ways of adjusting ride height independent of the struts / shocks.
the biggest limits on ride height are
1) roll center should be kept within reason if you want it to handle well
this can be solved by
a) using a tapered shank in a spherical bearing in place of the front lower ball joint
b) modified or fabricated steering knuckles and/or rear uprights
c) modifying the inboard pickup points on the subframes or going to tubular subframes
d) relocating the subframes higher
then
2) the rear axle issues, which can be alleviated with diff risers, different axles, axle spacers, or a tubular rear subframe
and finally
3) the height of the surface of the earth, which unfortunately cannot be modified. the absolute minimum ride height is whatever it takes to keep the frame off the ground at your maximum bump travel
1jz salvaged brz build thread brought to you by visconti tuning --> Pipe dreams and poor life choices
SomeoneWhoIsntMe is offline   Reply With Quote
Old 07-15-2014, 07:00 PM   #10
totopo
Drives: 370z
then
and finally
In terms of performance is what he meant. Your suspension needs bump travel to work. Bottoming out is bad. High spring rates are also bad. Negative camber gains on compression are good. At some point the benefit of lowering cg height is offset by the uselessness of your suspension.
https://www.google.com/url?sa=t&sour...MqQOmwvZJsB1XQ
totopo is offline   Reply With Quote
The Following User Says Thank You to totopo For This Useful Post:
Jive Turkey (07-15-2014)
Old 07-15-2014, 07:10 PM   #11
SomeoneWhoIsntMe
the OTHER thing that hasn't been discussed is what "on the track" means
even the worst setup will get you around a track at an HPDE event, or even cone chasing parking lot circlejerks. because he hasn't come to us with a specific class in mind that he's preparing his car for, we can assume that his car will be woefully under-prepared for any particular sporting event he attends, and thusly he won't be competitive anyway, for reasons far beyond having excessive roll couple
maybe it's just me, but I have a hard time taking complains about "too low to handle" seriously from anyone that still has an interior, radio, a/c, cats, anything but the stickiest of tires, airbags, etc. in their car.
Old 07-15-2014, 07:13 PM   #12
DAEMANO
Time Traveller
Hey guys
RS*R Black i
MCA Red/Blue
Black-i's are nice (very nice), but changing the ride height often would be a pain. You should be considering airbags or an Aircup system. Can't think of anything else that is going to accomplish what you're looking for.
Old 07-15-2014, 07:35 PM   #13
Lavalover
Drives: 2014 FR-S Monogram Hot Lava
There is even a thread for that:
http://www.ft86club.com/forums/showthread.php?t=68140
Lavalover is offline   Reply With Quote
Old 07-15-2014, 07:44 PM   #14
SomeoneWhoIsntMe
all I'll say about mike kojima is he's usually somewhat helpful, but take what he says with a grain of salt. if you'd like to learn something instead of being spoon-fed rules of thumb, check out carroll smith and milliken & milliken.
Need Coilover Advice Please distracteddev Suspension | Chassis | Brakes -- Sponsored by 949 Racing 22 03-07-2014 05:43 PM
Need a little advice on coilover install swift996 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 3 02-01-2014 10:00 PM
STX Coilover Advice ubersoph Tracking / Autocross / HPDE / Drifting 30 11-01-2013 07:34 PM
Need Coilover Advice for combined Street Comfort + Track Use distracteddev Suspension | Chassis | Brakes -- Sponsored by 949 Racing 21 06-23-2013 04:15 PM
Spring/Coilover advice canuckbrz Suspension | Chassis | Brakes -- Sponsored by 949 Racing 11 06-16-2013 07:09 PM
