Old 07-04-2014, 05:22 PM   #1233
markw
Drives: 2014 FR-S
That's what I figured, and I doubt anyone would protest me. I've trophied but never won class. Lots of talent in San Diego.
markw is offline   Reply With Quote
Old 07-04-2014, 09:04 PM   #1234
itzmik3
DBC Racing
itzmik3's Avatar
i've experienced fuel starvation once.... when i was running a full needle and some under empty LOL
#194 SM
itzmik3 is offline   Reply With Quote
Old 07-07-2014, 10:14 AM   #1235
qoncept
qoncept's Avatar
Originally Posted by markw View Post
Ok, looking at the crash bolts, and comparing them to a 14mm flange bolt from my industrial hardware store, they're pretty much the same except the toyota part costs 6 times as much. Looking at the rule book, 13.0 allows you to substitute a bolt ie like wheel studs. Any reason one couldn't just pick up a couple 14mm bolts from elsewhere and use them? Pretty sure any grade 10.9 flange bolt would suffice, as that is all Toyota is selling you.
Personally, I very briefly considered a trip to the hardware store but I decided I wasn't going to chance it over an $8 bolt. The upshot is I know for a fact the bolt is the right grade and has an appropriate flange and shank.
qoncept is offline   Reply With Quote
Old 07-07-2014, 02:40 PM   #1236
TrqlessWonder
Drives: 2014 FR-S
Well, there actually is a reason you can't just use any old 14mm bolt in Street. It does need to be the part number called out in the service manual.
Who would protest you? Not sure. But, the burden of proof in a protest situation isn't on the person protesting, it's on the person being protested. The person protesting needs to only accuse and post a fee.
The correct bolts are $6.33 each from oemautopartz.
-Mike
#24 CS/CSR
TrqlessWonder is offline   Reply With Quote
Old 07-07-2014, 07:54 PM   #1237
JB86'd
JB86'd's Avatar
Drives: JAWS
Here's my fastest run from this Sunday at El Toro.. 60.925. 8th place in S2. This is my 4th autox and I was only .8 seconds off of 3rd place so I'm happy with it.
[ame]http://youtu.be/jd4_qdIhDWU[/ame]
JB86'd is offline   Reply With Quote
The Following User Says Thank You to JB86'd For This Useful Post:
itzmik3 (07-08-2014)
Old 07-07-2014, 11:03 PM   #1238
brz7400
brz7400's Avatar
Drives: Subaru BRZ
Holy cow man! Your lines definitely look better than mine!
I'm toast once you add camber bolts and front sway bar...
And gratz to Mike for the incredible final run to end up less than 0.25 sec behind Jeff's 370Z!
brz7400 is offline   Reply With Quote
The Following 2 Users Say Thank You to brz7400 For This Useful Post:
itzmik3 (07-08-2014), JB86'd (07-07-2014)
Old 07-07-2014, 11:21 PM   #1239
Sccabrz192
Detroit Region, MI
Sccabrz192's Avatar
Drives: 13 BRZ, 13 Volt, 02 WRX
[ame]http://youtu.be/-5RZHPS8-y4[/ame]
My best Saturday Run at the Peru Match Tour... ended the day about 0.12 behind Chris Harvey, 0.15 behind Scott in the 350Z and an almost embarrassing 0.8 behind Grogan, great driving this weekend Sean!
This is the first time I really got video and data sync'd up like this and have really been able to analyze the feedback from the car and tires with what is actually happening... very powerful tool, already see LOTS of areas where I can improve. Data is from a DL1 exported to CSV format and sync'd with go-pro footage using race render 3.
Detroit / NWOR SCCA Member
2005-06: #192 ES 91 MR2 N/A Hardtop
2007-08: #54 STX 05 WRX Sedan
2009-12: #92 BSP/ASP 07 Solstice GXP
2013-14 : #192 CS 13 Subaru BRZ
Sccabrz192 is offline   Reply With Quote
The Following 4 Users Say Thank You to Sccabrz192 For This Useful Post:
bimmer635csi (07-08-2014), JB86'd (07-07-2014), SeanRTR (07-08-2014), stevo874 (07-07-2014)
Old 07-07-2014, 11:55 PM   #1240
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
this is a local event, scored 1st in class and 12th raw out of 88 people. (they don't do pax)
I've dialed out oversteer and now kind of miss it, as WOT/lifting does nothing
[ame="https://www.youtube.com/watch?v=qaRKCawnkEw"]2014 PITL #4 - YouTube[/ame]
Old 07-08-2014, 08:04 AM   #1241
bimmer635csi
bimmer635csi's Avatar
Drives: 2013 Cayenne turbo
I totally agree. I've learned more watching videos in between runs than I have anywhere else.
The strip charts look useful on the video too. I didn't realize RR3 could do that. Guess I need to look into it more.
Cheers,
bimmer635csi is offline   Reply With Quote
Old 07-08-2014, 10:14 AM   #1242
DylanFRS
Lost in Kansas
DylanFRS's Avatar
Drives: 2013 Scion FRS (Raven)
I am working towards doing some data acquisition finally, I notice DL1 is pretty popular, is anyone using SoloStorm?
Looks tight! You guys have 88 people and you don't calculate PAX? We only average 45 people per event and even we do PAX.
DylanFRS is offline   Reply With Quote
Old 07-08-2014, 10:24 AM   #1243
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
this particular series does not use SCCA classing and rules, it's effectively the beer-league of autocross. Only 9 classes but very tight competition.
but because half the people also do our regionals (which does follow SCCA rules) then i can just keep track of our relative performances to one another.
sometimes we have 100+ attendance days.
The Following User Says Thank You to 7thgear For This Useful Post:
DylanFRS (07-08-2014)
Old 07-08-2014, 11:18 AM   #1244
SeanRTR
C-Street AutoX
SeanRTR's Avatar
Thanks Tim. I thought your car drove really well in fun runs...I liked the turn-in feel of the dunlops quite a bit. While the Rivals felt more vague on turn in, the ultimate mid-corner grip still seemed to be quite good though. Your EBC yellow pads seem to have more initial bite than my Stoptech pads, but I haven't decided if that's a good or a bad thing yet. The 235 square setup felt better in the tight turn around, but not as stable in the slaloms. I took a significantly different approach to that long 270 degree right hand sweeper. I'll have my video uploaded to my build thread later tonight most likely.
-2013 Scion FR-S C-Street
Gearhead Homes - Homes geared towards car enthusiasts: https://www.facebook.com/GearheadHomes.RealEstate
SeanRTR is offline   Reply With Quote
Old 07-08-2014, 02:16 PM   #1245
itzmik3
DBC Racing
itzmik3's Avatar
sad thing is i didn't record my fastest run
i will post up my second fastest run, but with a cone.
this course definitely favored our cars compared to jeff, but jeff in the end was able to come out with the win
#194 SM
The Following 2 Users Say Thank You to itzmik3 For This Useful Post:
brz7400 (07-08-2014), JB86'd (07-08-2014)
Old 07-08-2014, 04:04 PM   #1246
Jawnathin
Drives: Toyobaru FRZ
What are you C Street guys running for alignment?
Getting the crash bolts in this weekend hopefully and may take it to the alignment shop next week to dial everything in.
Jawnathin is offline   Reply With Quote
Cinco De Mayo SCCA SOLO Ryeong86 NY / NJ / CT / PA 0 04-23-2013 05:22 PM
Koni Sports in SCCA SOLO Ryeong86 Tracking / Autocross / HPDE / Drifting 4 04-22-2013 12:58 PM
2013 Preliminary SCCA SOLO and PRO SOLO National Schedule Scooby South Tracking / Autocross / HPDE / Drifting 13 12-05-2012 08:08 AM
Houston SCCA Solo #9 - 5 FRS, 1 BRZ hankster Tracking / Autocross / HPDE / Drifting 0 10-09-2012 01:35 PM
SCCA Solo Car Class for the FR-S/BRZ? MrVito Scion FR-S / Toyota 86 GT86 General Forum 31 06-15-2012 10:03 AM
