#29 | |
[ame="https://www.youtube.com/watch?v=pgU6BIWjcG0"]Ice Mode - YouTube[/ame] I don't usually log wheel speed sensors. I always have TQ running and logging but I don't think that's very easy to pull data from? Probably should get AIM.
#30 | |
Automatic activation of the brakes (applying pressure) should make the pedal pulse or even go down further.
Fun car leads to autocross, autocross leads to track days, track days lead to lemons, lemons leads to racing school, racing school leads to spec Miata...
No idea where it leads next! |
#31 |
Wow, I've never had this happen (CSR BRZ on 245 Z214s) in probably 250 runs across ~10 different sites and I never do the pedal dance.
#32 | |
Drives: 2013 GBS BRZ Limited
The ABS system can only release the brakes it cannot apply them. Although is IS in charge of repressurizing the system AFTER it releases them (keeps them pumped up for you) This is the pulsing most of us are familiar with with "older" ABS systems. The VSC and electronic DIFF can apply the brakes to individual wheels. The BFD can only relieve pressure to front/rear (that is my understanding, and likely incorrect) |
#33 | |
Given this, I think it is likely (from a logical perspective, I have no real proof) that the body control computer would be able to apply, relieve, block, and modulate the brake strength to each wheel.
#34 | |
They are all one system, so when we say things like "disables everything, but leaves ABS still active" it is difficult to know what that means. If the pedal dance disables TC & VSC as most believe, but leaves ABS still active, WHICH parts of each of those are enabled/disabled?? I am even curious "Does the main ECU control the TC & VSC systems, or are those functions in a separate computer?" My guess is that the key ABS functions work without intervention from the car's main ECU. But I bet the VSC, TC, etc IS controlled by the ECU and can probably issue commands to the ABS when in TC/VSC mode. Is there an ABS computer in the engine bay with CAN Bus run to it? Sorry for thread jack. |
#35 | |
| The Following User Says Thank You to ddeflyer For This Useful Post: | stugray (07-07-2014) |
#36 | |
| The Following User Says Thank You to CSG Mike For This Useful Post: | Dezoris (07-08-2014) |
#37 |
Drives: 2024 GR86/ 2015 FRS
I get ice mode every time I AutoX.
The only way I can try to prevent it is to let off the gas,......wait.....then brake. I left foot brake, and my co-driver doesn't. He Only had it happen once. I really wish there was a way to fix it. Simmons
2024 GR86 71 STR/ 2015 FRS 71 STX
Sponsors Xero-Limit//Karcepts |
#38 |
This problem has meanwhile started to occur more often since I started to run on slicks.
Besides the pedal dance is there any solution to this problem? |
#39 |
| The Following User Says Thank You to CSG Mike For This Useful Post: | TrqlessWonder (06-03-2015) |
#40 |
It only happened on bumpy sections (I already knew that braking in turns can provoke a hard pedal). (So it's not necessarily me who's lacking smoothness.)
But after some searching I think one would need some sort of a motorsport ABS to prevent this. So there's nothing one can do about this other than just quickly release the pedal and brake again (regardless of what trees might coming closer rapidly). |
#41 |
Drives: Hydra EMS Powered FRS Raven Black
I haven't had ICE mode since switching up to a brake system RR Racing designed for us to shift more mechanical brake torque rearward. I still get ABS failure when I push 10/10th and I can't seem to get the pedal dance to work. My radiator is probably too good to get up to temp in the pits but I tried it after my race and still failed. The car is now raceable even without ABS due to the brakes but I still can't brake as hard as I need to (engage abs and back off).
I'm going to tweak my suspension setup slightly to try and make the system happier. I discovered the fault is more likely "stability control" as the light popped on twice during my warm up laps when I wasn't braking hard. Anyways for ICE mode to recover you have to get off the brake and then back on for the brake pressure to return. The Nissan Z race guys have this same issue and that can keep you out of the tire wall. |
#42 | |
The Stig's German cousin
| Redline360: Brake Lines, Brake Rotors, Brake Pads for BRZ/FRS | Redline360 | Brakes, Suspension, Chassis | 12 | 01-05-2013 10:20 PM |
| Rattle from the middle of the car | brichard0625 | Issues | Warranty | Recalls / TSB | 11 | 10-05-2012 07:04 PM |
| Odd brake pedal feel, fade? | yomny | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 27 | 09-11-2012 12:29 PM |
| First Whiteout 86 in the Middle East | i_giado | Member's Car Journals | 26 | 07-09-2012 05:30 AM |
| Anybody near Middle Indiana | AX_FRS | Tracking / Autocross / HPDE / Drifting | 17 | 06-01-2012 11:16 PM |
