Old 07-06-2014, 05:02 PM   #6539
fenton
Originally Posted by Sojhinn View Post
@Robftss and @fenton feel free to use my install video anyway you guys see fit. If you want it on your website or on the first post go for it.
Install video added to first post!
Phantom Electric Supercharger Install [ame]http://youtu.be/qkxPcDUPFdk[/ame]
fenton is offline   Reply With Quote
Old 07-06-2014, 05:38 PM   #6540
nlowell
nlowell's Avatar
Drives: 2013 Scion FRS
Ok so I won't say I have e85 around the corner. 😁
I drive ~20 miles to get it....but stock up while I'm there Name:  ImageUploadedByTapatalk1404682721.024537.jpg
nlowell is offline   Reply With Quote
Old 07-06-2014, 05:58 PM   #6541
DAEMANO
Time Traveller
You can get it delivered if you don't mind $6/gal
http://www.maperformance.com/55-gall...cing-fuel.html
There are also a selection of caddies here, that might make it easier to tote even more
http://www.northerntool.com/shop/too...n+fuel-caddies
Old 07-06-2014, 08:39 PM   #6542
VR46
are you Jeff Vader?
VR46's Avatar
Drives: Black BRZ Limited
Same here - 21 miles to the nearest station with e85. I can't for the life of me figure out why there is no e85 in northern viriginia. They've got it in DC and Maryland, and elsewhere in Virginia. Used to be able to get it at the gas station at the pentagon and and ft. belvoir, but even those are gone now.
VR46 is offline   Reply With Quote
Old 07-06-2014, 09:01 PM   #6543
Winjr
Drives: 2013 Subaru BRZ Premium
Originally Posted by WNDSRFR View Post
Here's my latest rear garnish.
I tried to apply Shiv's Vishnu Tuning sticker, but it sticks to the backing paper much better than it sticks to the car. I like to give credit where credit is due. The badge on the front is Toyota. I really have it backwards. Toyota should be on the back and Subaru should be on the front.
I did something similar but with the rear debadged I chose a different spot, passenger side. Still debating if I like it or not.
Winjr is offline   Reply With Quote
Old 07-07-2014, 01:31 AM   #6544
keen as
keen as's Avatar
Drives: 86 GT MT
An article mentioning ESC
"at least one of the new-age technologies AMG is currently looking at is electric turbo charging, where the compressor is powered by an electric motor rather than the exhaust gases and can therefore provide maximum boost earlier in the rev range and be better controlled for greater fuel consumption benefits."
http://www.drive.com.au/motor-news/m...707-zsrmn.html
keen as is offline   Reply With Quote
Old 07-07-2014, 06:51 AM   #6545
VR46
are you Jeff Vader?
VR46's Avatar
I currently have a clear Valentino Rossi sticker that looks like this:
I was thinking of trying to have two made that say "PHANTOM SUPERCHARGED" or something similar.
Old 07-07-2014, 11:57 AM   #6546
shif7i7down
Erected Member
Drives: frs
is the new 1.5 dump tune only for cars that also have the OFH installed?. I just flashed the new beta 1.5 dump map. and the car is very sluggish.
I used the 93oct ESC 1.5 tune.
shif7i7down is offline   Reply With Quote
Old 07-07-2014, 11:58 AM   #6547
Sojhinn
Lightning McQueen Driver
Sojhinn's Avatar
Drives: Limited Red 6MT BRZ
I'm using it with my stock header.
Installed Mods:
Old 07-07-2014, 11:59 AM   #6548
Khyron686
Drives: 2011 Outlander XLS, 2013 FR-S Blue
Did you let it idle for a few minutes after flashing (no touch the go pedal). If you just started driving it feels pretty bad for like 40km.
Khyron686 is offline   Reply With Quote
Old 07-07-2014, 12:02 PM   #6549
shif7i7down
Erected Member
Drives: frs
yeah, i let it idle for like 5 mins before taking it for a drive.
at first when the esc came on I can hear it spinning but the car was actually slowing down even while in WOT.
kinda weird.
not sure what's going on. switch back to the original phantom tune and everything is fine...
gonna stay with the original tune untill i get the OFH, and i'll give it another shot. hopefully it'll be out of beta by then.
Old 07-07-2014, 01:33 PM   #6550
enwave
That headunit though...
enwave's Avatar
Drives: 2013 Subaru BRZ Limited SSM
You can also pedal pump to make sure your throttle position is accurate. This is done by alternating sets of ten-twenty full compression presses with key off, key on no ignition, and key off again. It's not prevention for the no-VVT mode that idling is supposed to solve, but it makes it so you don't have pedal learning for that first while.
Side note unrelated to this -- I noticed that my steering wheel is off center by about an inch. I'm assuming this happened while the battery was disconnected. Is there an easy way to reset steering wheel position?
2013 BRZ Limited SSM 6AT
Phantom ESC 1.5Dump + E85 + OFH + Q300
Eibach Pro-Kit + Michelin PSS (stock size)
enwave is offline   Reply With Quote
Old 07-07-2014, 03:35 PM   #6551
Gary in NJ
Gary in NJ's Avatar
Drives: WR Blue BRZ, 240Z
The electric motor on the steering is only used for boost for the powered rack. The steering wheel being off by an inch is more then likely an alignment issue. Resolve this ASAP before you get asymmetrical wear on your tires.
Phantom ESC, ECUtek Tune, Nameless Front Pipe & Axle Back, Enkei RS+M 17x8 et35, OEM+Ref
Gary in NJ is offline   Reply With Quote
Old 07-07-2014, 03:44 PM   #6552
enwave
enwave's Avatar
Full throttle Electric Supercharger Build Thread
Interesting, I wonder what happened there. I'll take it in and get it looked at ASAP. Thanks for the heads up on the motor.
EDIT: sure enough, took her in and had a decent amount of toe-in on the front driver side. Those things don't just happen, so I wonder if my wife had a run-in with a curb or something she didn't want to share. The weirdest part is that I'm lowered enough that I can't imagine hitting a curb without damaging anything else, unless maybe the wheel was turned and only the tire hit something. I suppose it could have just been natural slip too, but I feel like I would have caught it over time.
My luck with other people this month is going to turn me into one of those super protective types... When it rains it pours I guess.
Circuit Motorsports - Vortech Supercharger FR-S Build + Full Perrin Exhaust & Extras Circuit Motorsports Member's Car Journals 4 03-21-2013 04:45 PM
Subaru BRZ : Full Throttle, powerslide, hard revving & ride ESBjiujitsu BRZ Photos, Videos, Wallpapers, Gallery Forum 20 05-30-2012 06:43 PM
86 Full Throttle Video + another. Aus86 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 2 04-02-2012 07:07 AM
