#85 |
Drives: 2018 Subaru BRZ
I picked up my '14 FRS almost 2 weeks ago currently at 1400KM's and have noticed the following issues:
-Chirping when using 94, not so much with 91 -Audible knock under load for the first hundred KM's which I suspect might have been from poor quality fuel from dealer ( I worked for different car dealerships for years and know sometimes the part-time detailers don't always follow the recommeded fuel ) haven't heard since I put in my own gas. -Rattle from cluster/dash area especially when hot outside and inside temps are much, much lower ( Suspect change in temps and contraction rates of materials inside changing ) If pressure applied to cluster and trim noise gone - needs felt tape fix -Cold transmission 2nd gear is tricky but fine when warm -Idle not smooth but not rough ( Not smooth compared to a Honda, but seems normal for a boxer - Owned many WRX's and Impreza's and boxers aren't smooth ) -When driving/cruising and series of bumps on road I feel a rattle through column and floor, seems worse in warmer weather or after driving for awhile ( Feels like possible chassis sway bar bushings too much play ) -Really annoying paint chip and sharp pinch on bottom of drivers door seam - Appears issue from factory as there is no damage on body side which would be the case if something got caught in door when shut. I have to admit that I'm really anal when it comes to my belongings and suffer from serious OCD. Working in service at a busy Honda dealer and VW dealer for years I have dealt with all sorts of gripes, complaints and problems with customers cars when new and Honda makes a really great product with very little issues but nonetheless they still have problems, VW on the other hand... I couldn't believe the issues they had on new vehicles, specifically those made in Mexico. I would never spend the money VW wants on those vehicles considering how poorly assembled they are.This being said, regardless of the issues I have with my FRS I consider them minor when I look at all of its strong points and price. I LOVE THIS CAR and most of the problems the dealer will solve or I will with replacement of upgraded parts evetually anyways. What it rewards me with smiles on a daily basis I'm pleased overall. PS. From working in service for awhile, if you have issues with your car, document them with notes and pictures/video. Book an appointment with the dealer, be prepared to leave the car, be assertive, but don't be a ****. If the issues are difficult to explain take the tech for a ride and always, always be the customer who brings coffee (Trust me, small gestures like this go a long way)
On my fourth 86... and everything in between
#86 |
Drives: 2014 BRZ Limited CBS
I've got a bit over 8000 miles on mine. Just had it taken to the dealer yesterday.
I stopped at a stop sign after a little spirited driving and it stalled. I started it back up and tried to accelerate. Above 2000 rpms a very audible knocking sound came from the engine. The higher the rpms and the louder it got. I took my foot off the gas and it stalled when it tried to idle. It continued to stall on idle when I started it up again. So I disconnected the battery and reconnected it. Fixed the stalling problem, but it still has the knocking. I'm going to call the dealer tomorrow to see what's going on with it. I miss my car. |
| The Following User Says Thank You to FT911 For This Useful Post: | paiceyfan (07-08-2014) |
#87 |
Daily Driven Expert
Drives: FR-S Monogram(BLACK)
Crickets isn't a bad thing, which most people believe. I know it comes on during idle because of the direct injection(DI). But it being a tuned boxer engine with DI is probably just a character trait of this platform.
I got crickets once I passed the first stage of the break-in period (~1,200 miles) As for the taillights, I've said if my dealer doesn't fit the problem right the first time I'll try to get some type of refund or something idk to put towards the Toms tails |
#88 |
Drives: 2014 WRB BRZ Limited
I've got 8600 miles on my '14 (bought brand new in april). Have crickets, but they go away when I get shell 93. Other than the tissue paper thin paint, really have zero complaints. Think this one's a keeper
| The Following User Says Thank You to xxBrun0xx For This Useful Post: | paiceyfan (07-08-2014) |
#89 |
A Very Powerful Wizard
Drives: 2014 BRZ LTD WRB (RIP), 2017 FiST
6k on mine. Absolutely zero issues so far.
| The Following User Says Thank You to XanRules For This Useful Post: | paiceyfan (07-08-2014) |
#90 |
Drives: 2014 SWP BRZ, MT
Put 7500 miles on her in under 3 months. Crickets, creaks and rattles from "ok" build quality, clickity left axle that sound like it need replacing (tiny clicks before any mods, got worse), squeaky windows when it's humid, laggy and annoying navigation system.
But yet, not a single thing really bothers me, not a single regret . For me, it's all in the drive. I drove my old car for 2 days while doing some of my mod installs and it just felt so numb, even though I had no complaints about my old car. She has me spoiled
| The Following User Says Thank You to zkv476 For This Useful Post: | paiceyfan (07-08-2014) |
#91 |
Drives: 2014 FR-S Whiteout
My April 2014 with 1k has notchy 2nd gear and that's about it so far...
| The Following User Says Thank You to FRSpappa For This Useful Post: | paiceyfan (07-08-2014) |
#92 |
Drives: '16 WRX, CBR1000RR
almost 2,500mi and no real issues. I've just recently (like last 50-100 miles) noticed the idle dip issue. However I think mine is fuel related, just filled up with a fuel brand I've never used in the car before. We'll see I guess.
Phantom ESC'd Build Thread (Retired):http://www.ft86club.com/forums/showthread.php?t=75293
#93 |
Drives: 2014 Scion FRS (Ultramarine)
Had the chirping fuel pump... replaced by toyota, 300 miles so far no more crickets...
#94 |
Space for Rent
Drives: 2014 6MT ToyoBaru86ScionMonogram?
a little over 3k, the moment i parked it on my driveway from the dealer on day 1, i hear the crickets
#95 |
Drives: Subaru Brz 2014
7000+ Km
- sometimes crazy loud sounds (like modem connection) from front/left side before driver, around 6-7K RPM - very often quite metal vibration sound (short) around 3K-4K RPM - Sometimes rear seats, driver doors crickets... - 3-4 Gear shift at 6K RPM crickets (probably synchro issue) - Fuel pump tick tack sound, when idle (but probably even when i drive it) Its pity, because otherwise car is perfect.. |
#96 |
Cliuless
Drives: Whiteout Scion FRS 2014
2700km with about 2 months of driving. No crickets, nothing.
A bit of rattling on the drivers side, but I'll have to investigate that. Nothing major, completely content. |
#97 |
Drives: 2013 FRS
other than crickets, I have had only one issue that the dealer had to fix which is common, the rear tail light aquarium issue. Replaced, no cost, no other issue so far
#98 |
Drives: 2014 Porsche Cayman S
I have had the same issue twice, but everything has been OK since. I think it is fuel related, too.
It's not speed or the attention that matters, it is that unexplainable moment when man and machine become one! At that time, nothing else exists except the path before you.
| Limited owners, how's the alcantara holding up? | tracerit | BRZ First-Gen (2012+) — General Topics | 43 | 10-14-2016 12:00 PM |
| Holding off on test drive | italy7 | BRZ First-Gen (2012+) — General Topics | 45 | 01-12-2014 01:33 AM |
| My car kept holding back after 4k rpm | Frsexxxy | Engine, Exhaust, Transmission | 25 | 05-09-2013 05:36 PM |
| Anyone still holding out for BeSpoke? | MrFRsLa | Electronics | Audio | NAV | Infotainment | 23 | 07-20-2012 05:24 AM |
| Seatbelt snaps not holding very well | ubersoph | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 7 | 06-23-2012 02:57 AM |
