#1737 |
Boosted Noob
Drives: '13 FRS MT KW SC, '05 4Runner 4WD
My original KW OTS tune suffered from what felt like significant parasitic loss from the supercharger, but honesty the subsequent tunes I received from KW (I believe there were 2 that I received after the original tune that required a different MAP sensor) were really smooth and were N/A-like even below 2500RPM.
#1738 |
Drives: Whiteout FR-S, Evo 8 RS
What are you using as a logger? OP2 and BRZ edit show 86% and OFT shows 100% I think.
#1739 |
Drives: 2022 BRZ Limited
I have been using Ecutek cable, I can also try Torque app
#1740 |
Drives: 1st RBv2 10 Series FRS
#1741 |
Drives: Kraftwerks BRZ
@zERoTu, clearly there is something wrong. Are you sure you don't have a boost leak somewhere? Does the car feel like it's even boosting? Check your email inbox.
#1742 | |
I check all the lines. Nothing is loose. 1st gear and 2 gear pulls great. 3rd and 4th gear pull are taking forever for the rpms to climb. Sent from my iPhone using Tapatalk |
#1743 | |
Drives: 2013 BRZ Premium Dark Gray Metallic
Up to what rpm's @ 1st and 2nd?
KraftWerks SuperCharger C30=HB-Waterless Coolant-(Mishi)Racing Thermostat & Oil Can
Tomei EL-PLM Overpipe-HKS Dual Resonated Front Pipe-Invidia N1 DR31 18x9+38 Square w/ 255/40r18 PT-722, TRD Quickshifter, ACT Streetlite Kit Moto-East Flex-Fuel Kit (Almost running 100% E85 all the time) DW 700 cc Injectors-Tune by (Moto-East)-KW Oil Cooler |
#1744 |
Drives: 2013 WRB BRZ
After three days of working on the car, I have the kit installed. I took my time but had multiple things to work around and install.
I installed my ROBISPEC radiator, hmm it had quite a few compromises in terms of fit, DAMN tight all around but it fits. I had to make a gasket for the oil sandwich as the bottom of it had a groove for what looked to be a gasket but none was there. I used a high temp gasket maker and had to buy 3' more oil line since the way I had to run lines to avoid the supercharger needed more. Then I installed a Raceseng cam plate, changed my oil and radiator fluid. Then I installed the supercharger which went pretty fast if I hadn't wasted so much time on the above radiator. Now I have to deal with my last problem. Ecutek updated but seems to either have corrupted or lost my license file. I sent a note off to Delicious Tuning as I can do nothing until that gets sorted to even start the car to look for leaks and check the rotrex oil.
Second place is just the first place loser.
Dale Earnhardt |
#1745 | |
#1746 |
Yes, Yes I did.
This is the final install minus bumper until I get to run it and check for boost leaks.
Dale Earnhardt |
| The Following User Says Thank You to Squishy For This Useful Post: | D-VO (07-10-2014) |
#1747 |
#1748 |
The location is back near the battery.
Dale Earnhardt |
#1749 |
Nevermind figured out the issue with the license - had to apply the license file. Man I do not really like this ecutek thing. Oh well just gotta get this done.
Dale Earnhardt |
#1750 |
| Innovate (Sprintex) Supercharger Owners Topic | DarrenDriven | Forced Induction | 9139 | 12-29-2023 10:58 PM |
| Kraftwerks Rotrex Supercharger Discussion | nelsmar | Forced Induction | 697 | 01-18-2022 12:06 PM |
| All SUPERCHARGER kits compilation thread | subatoy | Forced Induction | 76 | 03-10-2016 12:38 PM |
| Kraftwerks Supercharger?? | umpadupa | Forced Induction | 1 | 08-05-2013 05:27 PM |
