Old 07-03-2014, 09:53 PM   #71
cnk
Drives: '13 DGM BRZ Limited
Or you could have just purchased the adapter mentioned in this thread for ~$15 and not have to splice anything. I got mine from Crutchfield here: http://www.crutchfield.com/p_120TOYU...s.html?tp=3486
Old 07-03-2014, 10:04 PM   #72
Fastbrew
Drives: 2014 Pearl White BRZ
I used this thing in my BRZ / ca-fi install.
[ame="http://www.amazon.com/gp/product/B00L2SF64E/"]Amazon.com: Axxess AX-USB-35EXT USB + 3.5 Waterproof Cable w/ Covered Panel: Car Electronics[/ame]
I also used one of these to connect to the RCA ins on the ca-fi.
[ame="http://www.amazon.com/gp/product/B001B8QUS6/"]Amazon.com: C2G / Cables to Go 40424 Stereo F/M RCA YCable (6Inch, Black): Electronics[/ame]
Fits perfectly.
Fastbrew is offline   Reply With Quote
Old 09-27-2014, 09:50 PM   #73
quality_sound
Drives: '15 BRZ Series.Blue
Originally Posted by AKSnowman View Post
Anyone know if it's the AX-TOYUSB or the AX-TOYUSB-2 that we need? gonna install the AVH-P4400bh. Thanks!
I was just looking at these and can't see a difference. Anyone else know what the difference is?
quality_sound is offline   Reply With Quote
Old 10-11-2014, 02:09 PM   #74
quality_sound
Well, I ordered the Access usb/aux input and it really does fit right in.
Old 10-11-2014, 02:58 PM   #75
wheelhaus
wheelhaus's Avatar
I'm installing mine right now and it fits perfectly.
Old 10-12-2014, 12:03 PM   #76
quality_sound
TBH, I'd MUCH rather have an adapter for the OEM connector like in my STI so I don't have the OEM cable sitting unused behind the dash, but at least it looks good. The really sad part is I'm debating about running a second USB into the glovebox like the Canadians have since my HU has two USB ports.
Old 10-12-2014, 01:28 PM   #77
wheelhaus
wheelhaus's Avatar
For the second USB I did exactly that for the glove box, but just ran a 3ft extension with a female A connector on the end, I didn't bother mounting a jack. I had to drill a hole in the plastic above the glove box on the left side as I didn't want the cable to snake and get kinked anywhere from opening/closing the glove box. It was a couple years ago so can't remember exactly how I did it. I think I removed the glove box to get an easy angle. If you do that make sure the hole diameter will allow the connector to fit through.
Old 10-12-2014, 02:32 PM   #78
quality_sound
I'll probably do something similar once I get the glovebox out of the car and see how everything pieces together. I just hate having a perfectly good OEM connector and cable just chillin' behind the dash. The HU I'm putting in now is probably not going to stay in too long and I don't know if its replacement will have 2 inputs or not. If not, I'll default to the glovebox location. I HATE exposed connectors and I don't use my phone as a music player. I really wish there was a pocket we could install with no start button and no USB connection.
Old 10-12-2014, 03:27 PM   #79
Fastbrz
Drives: Wrb brz
I'm assuming th brz uses the same adapter?
Fastbrz is offline   Reply With Quote
Old 10-12-2014, 06:14 PM   #80
cnk
I have a BRZ so yes.
Sent from my SAMSUNG-SM-N900A using Tapatalk
Old 10-12-2014, 07:51 PM   #81
quality_sound
As do I. Works and fits perfectly. I'll try to get a pic tonight.
Old 11-11-2014, 08:26 AM   #82
Tareim
Drives: 2013 Subaru BRZ
were you able to get a pic of this? as I've now got a brz and would like to get the usb linked with my aftermarket HU
Tareim is offline   Reply With Quote
Old 11-12-2014, 11:16 PM   #83
quality_sound
What do you need me to get a pic of? I can get one of it installed from the front. It literally is just a "remove the old one and snap the new one in" operation. The new one will have a USB and 3.5mm ends. You'll plug these into your new HU. It really is that simple but I'll get a pic of whatever you need. I'll probably have to email the pic or something since Imageshack charges now. Booooo
Old 11-13-2014, 05:31 AM   #84
Tareim
a pic of how it sits in place would be nice to see how it looks compared with the factory effort.
have you thought about imgur for hosting images?
Auto Factory Aftermarket exhaust ESBjiujitsu Engine, Exhaust, Transmission 113 01-17-2014 05:45 PM
More Scions in Richmond Port. Marloon CANADA 203 06-07-2012 01:43 PM
More shots from the Port of Portland DarrenDriven FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 10 05-11-2012 01:04 PM
Look what I spotted at the port of LB today Trojan_SC Southern California 4 05-09-2012 02:40 PM
Southeast Cars are In Port! Dadhawk Scion FR-S / Toyota 86 GT86 General Forum 3 04-27-2012 11:39 AM
