Old 07-03-2014, 06:41 PM   #1
Bg8780
Bg8780's Avatar
Drives: '13 Black Subaru BRZ Limited
How bad is launch control
Those of you with ECUtek tunes and launch control. How often do you use it? I imagine it is very rough on the clutch and other transmission/driveline components.
I know a few F430 variants came with this option and Ferrari would not warranty it and eventually stopped shipping cars with it. Most cars with launch control now have dual clutch trans so this is no longer an issue.
Bg8780 is offline   Reply With Quote
Old 07-03-2014, 07:08 PM   #2
Dipstik-sportech
Dipstik-sportech's Avatar
It's meant for racing only, when else would u use it? Ours isn't the same as Ferrari and others because our clutch is human controlled
Old 07-03-2014, 07:14 PM   #3
Bg8780
Bg8780's Avatar
Originally Posted by Dipstik-sportech View Post
It's meant for racing only, when else would u use it? Ours isn't the same as Ferrari and others because out clutch is human controlled
I would use the feature when I want to. Just curious of the damage it could cause and how people with tunes have been using it, if at all. I don't know a lot, just enough to know it couldn't be used extensively without consequence.
I definitely understand the difference. I chose the F430 because both cars are single clutch and this is something Ferrari did from the factory (at least at first) and I found that intriguing from a production car standpoint.
Old 07-03-2014, 09:01 PM   #4
Reaper
in orbe terrum non visi
Reaper's Avatar
Drives: violent
I have launch control and im very confused about your question. Letting the clutch out at 5,000 rpms is the same whether I have my launch control turned on or not. Its just easier to pick which rpm when using launch control.
ECUTEK launch control doesn't launch the car for you. Its just a rev limiter activated in first gear with the clutch in.
Old 07-03-2014, 09:02 PM   #5
chiefshayan
chiefshayan's Avatar
Drives: 2013 AT Firestorm FRS
Oh it's bad, real bad
chiefshayan is offline   Reply With Quote
Old 07-03-2014, 09:07 PM   #6
Manic
Is not fast.
Manic's Avatar
Drives: 2014 Whiteout M/T
Well, whether you're driving an automatic or manual, you can imagine what launching at 4k+ revs could do to the clutch. I can't imagine using that feature anywhere other than on a track to be honest.
Manic is offline   Reply With Quote
Old 07-03-2014, 09:10 PM   #7
Dipstik-sportech
I think you're confusing our launch control with those used in electronically controlled paddle shift transmissions. Whether it be single or dual clutch they work exactly the same. They rev the car up to a preset rpm then bang the clutch in when u release your foot from the brake. Ours is the same except our clutch isn't controlled by a computer so u can release it how u wish. There's also antilag which will confuse you even further lol
Old 07-03-2014, 09:17 PM   #8
boredom.is.me
Custom User Title
boredom.is.me's Avatar
Drives: Asphalt FR-S MT
Rev to 2200rpm.
Release clutch.
Am I following this the right way? You don't need a stupid limiter to do that.
The question probably shouldn't be "how bad is launch control?" More like, "how much strain does hard launching put on our drivetrain?"
Old 07-03-2014, 09:39 PM   #9
Reaper
Reaper's Avatar
Drives: violent
I used launch control today. Every molecule in my body exploded at the speed of light. By body I mean tires.
Old 07-03-2014, 10:28 PM   #10
mike the snake
Any time you drop the clutch at high rpm's it's going to put harsh loads on the drivetrain.
I think WITH launch control though, you can set the limiter to a lower rpm, and more safely, and more consistently ( more important) launch the car.
Old 07-04-2014, 08:30 AM   #11
Bg8780
Bg8780's Avatar
Originally Posted by boredom.is.me View Post
Rev to 2200rpm.
Release clutch.
Yeah that's probably how I should have worded it. Thanks fellas.
Sent from my LG-V500 using Tapatalk
Old 07-06-2014, 06:38 PM   #12
Reaper
Reaper's Avatar
Drives: violent
mine puts very little strain on my drivetrain since I have zero traction. Launch control seems to be harder on my valve train from overrevving while spinning than from drivetrain shock.
Old 07-06-2014, 06:53 PM   #13
boredom.is.me
Custom User Title
@Reaper, you will never have grip. Leave this world and go to one where the roads are made of glue.
Old 07-06-2014, 07:36 PM   #14
woode
Boosted Member
woode's Avatar
Drives: 2013 Subaru BRZ
Send a message via MSN to woode
Rev to 2200rpm.
Release clutch.
Launch control let's you floor it and build boost and launch at ______ rpm. Can't really do that without.
Traction, however, is another story.
Mine is set to 4000rpm and it will build about 10psi
2013 Subaru BRZ LTD 6MT DGM
2014 Subaru XV Crosstrek Hybrid TRG PG
2011 Honda CBR1000RR
2010 Subaru Impreza WRX PRM SSM
woode is offline   Reply With Quote
Launch Control is back! m.wood0213 Other Vehicles & General Automotive Discussions 0 04-16-2014 12:00 PM
EcuTek RaceROM Launch Control just86 Software Tuning 47 03-14-2014 02:55 PM
Unichip Launch control SCharged Software Tuning 11 01-22-2014 01:13 PM
FS: Unichip + USB Cable + Launch Control $300 daywheniwaschillin Engine, Exhaust, Bolt-Ons 6 07-04-2013 01:19 PM
Launch Control on Auto? devinclfalcons Engine, Exhaust, Transmission 28 03-01-2012 07:14 PM
