Old 07-03-2014, 01:13 AM   #29
Scalzo
Scalzo's Avatar
Drives: Asphalt FRS <3
Alright so I managed to reflash the tune and it seems to be fine it's running a little lean but no problem so far. I managed to do a 3rd gear pull and be able to log it. Sent an email to JR we'll see what happens nd what he says
Scalzo is offline   Reply With Quote
Old 07-03-2014, 02:11 PM   #30
steveoexige
Drives: UK GT86 in White with alcantara
Interested to hear your findings as my car seems to have the same issues as described in your original post. I've running the JDL turbo kit with a GTX3071r and 550cc injectors. My setup is running MAF off boost and then speed density thereafter (which is all russian to me I'm just quoting my tuner here in the UK).
Mine does always start though it just cranks a bit longer than I'd like when warm before catching and firing up.
steveoexige is offline   Reply With Quote
Old 07-03-2014, 02:35 PM   #31
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Originally Posted by Scalzo View Post
Car doesn't start now got it towed home .. Hopefully he gets back soon
It stalled while I was coming to a stop.. Driving the beater now
Injector tuning is out of whack... you are getting high fuel trim errors and the ECU trying to compensate for that error is what is causing the car to stall on stops...
He corrected this same issue on a car just days ago.
Might be time to get a tune from the best... @jamesm
The Following 2 Users Say Thank You to Sportsguy83 For This Useful Post:
Ironsquid (07-10-2014), jamesm (07-03-2014)
Old 07-03-2014, 04:21 PM   #32
Scalzo
Scalzo's Avatar
Hey I was gonna message you on Facebook actually.. For some help
So basically my ecutek was out of date I updated it to the newest software loaded up the same map and it seems to be running fine . The only problem I'm having is when I'm just cruising it goes to about 14-15 afr then if I stomp on the gas it'll go to 12-13 and now I'm boosting 8.9 psi.. Before I was boosting 10psi on the same map.
So something doesn't make sense ....
I'm at the point where if jr can't figure it out I'm going back to n/a .. I've been through 2 tuners and not down for another . I have a local garage that tunes but at ridicoulous prices .. I spent 500$ on a dyno tune at prime motoring it ran fantastic when I was in fl. Everything was good until I went back and got my koyo radiator installed ever since then car is sluggish and it didn't boost properly .. But for some reason now everything is fine... I sent him a log with the same tune and I'll see what happens *fingerscrossed*
The Following User Says Thank You to Scalzo For This Useful Post:
Sportsguy83 (07-03-2014)
Old 07-04-2014, 08:16 AM   #33
ecko04
Seems Legit
ecko04's Avatar
Drives: Toyota
Issues starting
I agree with saying injector tuning may be off.
I would also say that the 3" intake tube and bad MAF placement on the FA20Club kit is also contributing to the issue of stalling. At low speed it's entirely possible that air is not being directed through the MAF as it should but rather around skewing the readings.
It's one thing to have a large intake tube with good enough MAF placement to get good usable readings. It's another to have a large tube with poor MAF placement that causes the ECU to go into WTF mode.
No build thread. I don't want to be reminded of how much money I spent.
[insert profound quote here]
ecko04 is offline   Reply With Quote
The Following User Says Thank You to ecko04 For This Useful Post:
Sportsguy83 (07-04-2014)
Old 07-04-2014, 08:27 AM   #34
ecko04
Seems Legit
ecko04's Avatar
Drives: Toyota
Your ECUTek software being out of date wouldn't cause or solve the issues you're experiencing. If you reloaded the same map your boost should be the same. Now there are situations where you may not see the same boost levels but it should come pretty close. Are you using any boost controller? Have you checked for any boost or vacuum leaks recently?
If you're not confident in your tune then I would turn down the boost until you get it sorted out.
Old 07-04-2014, 09:22 AM   #35
enjetek
Drives: 93.5 supra t & prius
Hmmmm. Depending on speed of your cruising 14-15 is normal and might even go leaner since not much fuel is being used. When you mash on it it should go into the lower numbers since it should be richer. I'm a supra guy so I've had to go to a standalone ecu and switched over to map sensors...no worrying about boost leaks too much here.
enjetek is offline   Reply With Quote
Old 07-04-2014, 09:26 AM   #36
enjetek
Issues starting
Also I would get more gauges (not too many since you don't want to look too tacky lol) to help you monitor your car. As stated above I wouldn't push anything hard until you get things sorted out. You did mention your radiator - I know with my aem you can do certain things based on operating temp so maybe someone mangled that sensor reading somehow with their work? Are you also venting to atmosphere for bov? Reason I ask is because maf can be sensitive if you do that too - hence map sensor.
Old 07-04-2014, 05:18 PM   #37
Scalzo
Scalzo's Avatar
I'll get back to replying your messages tomorrow...
Just a quick update.
Still no answer from JR .
Old 07-07-2014, 11:13 AM   #38
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
The only thing reloading your ROM did was reset your short term and long term fuel trims. Where are you getting your boost reading from? Unless your boost is EcuTek controlled and you flashed a different ROM, the boost level should not have changed. Good luck with getting JR to correct your tune.
Old 07-07-2014, 11:15 AM   #39
Scalzo
Scalzo's Avatar
Yeah I'm starting to think , part out the turbo .... Still no response and I sent him a datalog .. Fuck :/
Old 07-07-2014, 11:19 AM   #40
King Tut
NASA SpecE30 Racer
King Tut's Avatar
You probably won't get much for your FA20Club kit. I would try and stick with it or get an @jamesm tune.
jamesm (07-07-2014)
Old 07-07-2014, 11:21 AM   #41
Scalzo
Scalzo's Avatar
Thing is it's my 2nd tuner and both of these we're recommended by the forum.. I'm starting to think no one can tune it.
Old 07-07-2014, 11:34 AM   #42
ptuning
ptuning's Avatar
Drives: White FR-S
It would be a pretty long drive for you, but if your car is mechanically sound otherwise, we can tune it. The blow-thru MAF design as it is leaves a lot to be desired, but it can still be tuned well enough to keep fuel trims within reasonable limits.
However, running a custom 2.5" MAF tube with a properly positioned MAF sensor, BOV on the hot side IC tube, and a hybrid speed density blend tune would be the way to go.
Hopefully you can get it resolved at no additional cost to you though.
- Toan
ptuning is offline   Reply With Quote
Rev when starting ? (Possible and why ?) Simon99 Software Tuning 11 05-22-2014 04:12 AM
Car having trouble starting up!!! TomT2411 Issues | Warranty | Recalls / TSB 3 05-09-2014 07:57 PM
just starting out mortachi Cosmetic Modification (Interior/Exterior/Lighting) 3 10-06-2013 10:23 PM
Starting a Group Buy haloterence Site Announcements / Questions / Issues 7 08-29-2012 03:09 AM
Starting it off e10rice Mid-Atlantic 93 03-26-2012 03:16 PM
