Old 07-02-2014, 01:13 PM   #351
salvanipour
Single and Loud
salvanipour's Avatar
What was the labor cost at the dealership? They want 8+ hours here in Austin...
2013 FR-S, Enkei RPF-1s, Geforce Sports, Berk Track Pipe, etc.
salvanipour is offline   Reply With Quote
Old 07-02-2014, 03:13 PM   #352
tennisfreak
Drives: 2018 BMW M240i
I got a quote of $550 in labor and $265 in parts at Toyota of Fort Worth.
The Following User Says Thank You to tennisfreak For This Useful Post:
JonAvalon (07-02-2014)
Old 07-02-2014, 03:59 PM   #353
nosi9frs
nosi9frs's Avatar
Drives: Raven FR-S
Originally Posted by newports View Post
Can I please get some more Side shots of people with TRD springs on?
nosi9frs is offline   Reply With Quote
The Following 2 Users Say Thank You to nosi9frs For This Useful Post:
JonAvalon (07-02-2014), newports (07-02-2014)
Old 07-03-2014, 01:07 AM   #354
Frs32907
Drives: Asphalt grey, manual Fr-S
Would these springs work with these tires:
Front- 225/35-19
Rear- 255/30-19
Frs32907 is offline   Reply With Quote
Old 07-03-2014, 11:48 AM   #355
tennisfreak
Originally Posted by nosi9frs View Post
Looks good, just need some tire shine on those tires to bring out the black!!!!!
nosi9frs (07-03-2014)
Old 07-03-2014, 12:20 PM   #356
STV3
Señor Member
STV3's Avatar
looks good. wheel and tire size please?
STV3 is offline   Reply With Quote
Old 07-03-2014, 02:00 PM   #357
nosi9frs
nosi9frs's Avatar
Drives: Raven FR-S
Black OZ Ultraleggeras 17x8 +35 with 225/45R17 tires
Old 07-03-2014, 03:00 PM   #358
STV3
Señor Member
STV3's Avatar
Nice. Drop looks perfect!
I'm debating these springs so bad but I really don't want alter the feel/handling of the suspension at all. The stock setup rides perfect.
Old 07-03-2014, 04:38 PM   #359
Sh944
Unwashed Heathen
Drives: 2014 Scion FR-S
I just installed the TRD springs and swaybars, and trust me, its a big improvement in ride quality as well as handling. It handles rough roads better, which I suspect is due to the progressive nature of the TRD springs as opposed to a static rate on the stock springs. If you drive normally, you won't really feel much difference aside from a smoother ride (imo) but when you push the car harder, the changes really become apparent. The car is much more predictable, more planted and neutral in a turn, and cosmetically, the ride height looks much better.
I have extensive experience with Porsches and plenty of track experience over the last two decades. The TRD springs/sways are in no way a replacement for a properly dialed in coil-over set up if you are planning on tracking your car, but they are absolutely perfect, imo, for a street car. Everything I complained about with respect to the stock handling, which was fun for what it is but a good bit less than perfect from my perspective, was resolved by making this change.
I would strongly suggest changing the sway bars if you are going to run these springs, they complement each other very well. For what its worth, I am running stock tires/wheels on my '14 FR-S.
If you are doing the work yourself, make sure you get the car aligned after the install. The install took me around 6 hours total, but I was mostly enjoying some garage time to myself rather than trying to hurry through an install, or I expect I could have come close to cutting the time in half.
Sh944 is offline   Reply With Quote
The Following 8 Users Say Thank You to Sh944 For This Useful Post:
BabaYaga (02-16-2015), Createddeleted (07-03-2014), Evil Jesus (07-03-2014), gonzo (07-07-2014), newports (07-10-2014), nosi9frs (07-03-2014), number1Tango (07-25-2015), STV3 (07-03-2014)
Old 07-03-2014, 10:49 PM   #360
Shady195
Drives: '13 10 Series FRS #1203
Can the TRD springs be used with the factory struts?
Shady195 is offline   Reply With Quote
Old 07-04-2014, 12:02 AM   #361
Sh944
Unwashed Heathen
Yes, in fact, they are designed to work with them according to the Toyota rep I talked with before I bought mine.
Old 07-06-2014, 09:24 PM   #362
BRZ21
i kill cones.
BRZ21's Avatar
Drives: around cones in a parking lot
Originally Posted by FR-Swag View Post
I just installed my TRD springs and TRD 18" rims with recommended tires and maybe its just me but it seems to have much more body roll than the stock setup I only drove it for about 30 minutes last night so I'm not 100% sure, maybe I need to install the TRD sway bars front and rear????
Sent from my DROID RAZR using Tapatalk
Thats probably because you have sticky tires now which would cause more body roll. Yes sway bars would help
2013 SSM BRZ Limited 6MT
BRZ21 is offline   Reply With Quote
Old 07-07-2014, 07:58 PM   #363
fitcious
i am selling a set of TRD lowering springs, brand new in box, never open or used for $210 obo if anyone is interested. Thanks
fitcious is offline   Reply With Quote
Old 07-07-2014, 08:06 PM   #364
hunter3232792
hunter3232792's Avatar
Drives: FRS
Originally Posted by fitcious View Post
i am selling a set of TRD lowering springs, brand new in box, never open or used for $230 obo if anyone is interested. Thanks
ive been asking for some for a while
hunter3232792 is offline   Reply With Quote
Lowering Springs|Alignment Kits|Strut bar|Sway Bars|Strut Mount +More SOURCE,LLC Brakes, Suspension, Chassis 445 05-11-2015 06:41 PM
ST Suspensions Lowering Springs & Anti-Sway Bars Now Available @ BMS! Boston Motorsports Brakes, Suspension, Chassis 84 07-24-2013 12:42 AM
Stock springs and sway bars Spencer Brakes, Suspension, Chassis 3 04-25-2013 10:41 AM
FR-S/BRZ SWAY BARS & STRUT BARS @ NINJA AUTOSPORTS!!! NJA Brakes, Suspension, Chassis 18 04-07-2013 07:00 PM
**The Eibach Thread** Springs, Coilovers, Sway Bars @ Pure Automotive Pure Automotive Brakes, Suspension, Chassis 1 02-06-2013 03:32 PM
