Old 03-12-2014, 02:45 PM   #155
SirBrass
Trust me, I'm the Doctor
SirBrass's Avatar
Originally Posted by yomny View Post
I may sound like a dumb face, specially after this being my second FRS but what size are our mid pipes? After market exhausts(2.5") fit and seal good? The whole idea of another resonator in there sounds good, specially after adding their header.
Yes, 2.5" seals up perfectly with the stock exhaust system, including the midpipe.
It's not exactly 2.5", but close enough for a 2.5" system to not be hindered by it, or for a 2.5" system to be benefited reasonably by it's replacement.
^GT5 Replay Photo Mode^
The Following User Says Thank You to SirBrass For This Useful Post:
yomny (03-12-2014)
Old 06-04-2014, 10:08 PM   #156
BeRZed
Can anyone confirm the hardwares included in the overpipe/downpipe system? Is it just two bolts and reusing the stock doughnut gasket?
BeRZed is offline   Reply With Quote
Old 06-05-2014, 10:51 AM   #157
Efferalgan
Drives: 2025 BRZ, ex-2012 GT86
No hardware included. At all. You will need 2 gaskets and potentially (depending on their condition) bolts.
Efferalgan is offline   Reply With Quote
The Following User Says Thank You to Efferalgan For This Useful Post:
BeRZed (06-05-2014)
Old 06-05-2014, 08:51 PM   #158
BeRZed
Strange. On their website it says it includes all hardwares but gaskers are reused.
Old 06-06-2014, 12:23 PM   #159
Efferalgan
Maybe because it requires no hardware apart from gaskets? Of course you may try to reuse the old ones if they look reasonable. Mine cracked in 2-3 pieces - so was little opportunity of re-using them.
BeRZed (06-06-2014)
Old 06-06-2014, 09:39 PM   #160
Bobblehead
Bobblehead's Avatar
Drives: 2013 BRZ (gone) 2016 Ford Fusion SE
I'd still like to see a dyno of this pipe. I'm thinking about getting one to have a little more power.
Bobblehead is offline   Reply With Quote
Old 06-30-2014, 07:55 PM   #161
RobotChobot
Drives: Scion Fr-s 10 Series M/T
How big of a difference does the Helmholtz make? I have just the TRD catback exhaust on my car, and I am looking to get this pipe catted, but I can't find any comparisons between the resonated and unresonated
RobotChobot is offline   Reply With Quote
Old 07-02-2014, 07:24 PM   #162
calibrz
Turbo 86
Drives: GT86
resonated only help on drone.
10 - 1 = 0
real math
calibrz is offline   Reply With Quote
Old 07-03-2014, 08:58 AM   #163
ToyoburuBRZ
ToyoburuBRZ's Avatar
Drives: Black BRZ
here is the dyno curve from their website. It is in their header back package (which is just the OP/DP plus the axleback as the midpipe stays stock).
And since the axleback won't add any significant power, I think it is safe to say that the power gains you see here are from the OP/DP
ToyoburuBRZ is offline   Reply With Quote
The Following User Says Thank You to ToyoburuBRZ For This Useful Post:
Bobblehead (07-04-2014)
Old 08-14-2014, 11:15 PM   #164
Brinks
Brinks's Avatar
@Ryan@Nameless
@Jason@Nameless
I've having a little issue with my setup. I have a major increase in VVT noise after installing the catted/Helmholtz resonated downpipe. If I go with the non resonated version would it get rid of the sound without increasing drone?
(Its twice as loud in person)
[ame="http://www.youtube.com/watch?v=LqOZUlfgluk"]Nameless header / OFT Stage 2 EL E85 v2.3 - YouTube[/ame]
OFT Stage 2 EL E85 V2.3
Nameless EL Header
Nameless mid/over with Helmholtz Resonator
Perrin 2.5 Resonated Cat Back
K&N drop in filter
Brinks is offline   Reply With Quote
Old 08-19-2014, 11:14 PM   #165
yomny
yomny's Avatar
Drives: 2013 FRS Whiteout
Just a guess here but I think removing a resonator would increase noise. Also not sure if the valve train noise has anything to do with an exhaust part. Let's see what the experts have to say though.
GTX2867R, moto-tuned , tomei op , motiv fp , Invidia Q300 ti , Rota titan 17x9 +42 , nt555 255/40 , ST coilovers w/cascam , Hotchkis sways
yomny is offline   Reply With Quote
Old 08-20-2014, 03:57 PM   #166
Efferalgan
Check fitment. If the pipe contacts the engine block - that's the cause of your noise. If not and there at least 5mm clearance, removing of the resonator won't help.
Old 08-20-2014, 04:19 PM   #167
ToyoburuBRZ
Drives: Black BRZ
Originally Posted by Brinks View Post
@Ryan@Nameless
@Jason@Nameless
Nameless EL Header
K&N drop in filter
Did you do the OFT tune recently as well? This tune has much more aggressive VVT tuning than stock and significantly increases VVT noise.
Changing to non resonated wouldn't do anything but make it louder.
Did you just get the nameless downpipe? Or is it the OP/DP combo. If it is the combo than you may have the OP hitting the engine block. If that is the case, unbolt everything from the header back. Then, just install the OP/DP ensuring you have clearance to the engine block. Once that is fully tightened into place, install the catback.
Old 08-20-2014, 10:44 PM   #168
Brinks
Brinks's Avatar
It's not a fittment issue, I have plenty of room. Everybody that has described that specific noise has had a nameless 2.5 downpipe combo with Helmholtz resonator. I talked to Ryan at nameless in a PM conversation , he told me that there was an issue with a small percentage of the resonators making that sound while paired with an aftermarket header. They have since changed there design with no issues so far. The new design is a round ball instead of the tube type, same style as the cosworth downpipe.
So if you have this spesific "marbles in a tin can" sound, removing the Helmholtz will get rid of it but you will have an increase in drone so it kind of a trade off. I just went and ordered the new design, lead time is about 4 weeks.
Nameless Performance BRZ Axleback Exhaust ESBjiujitsu Engine, Exhaust, Transmission 1377 04-21-2020 02:23 AM
Nameless Performance Downpipe is available for pre-order. Nameless Performance Inc. Engine, Exhaust, Bolt-Ons 4 07-12-2012 04:57 PM
Vitamin R from Nameless Performance. Jason@Nameless BRZ Photos, Videos, Wallpapers, Gallery Forum 4 06-22-2012 11:27 AM
We are Nameless Performance. John@Nameless Announcements, Contests, Giveaways 22 06-18-2012 11:32 PM
Nameless Performance is here. Nameless Performance Inc. Engine, Exhaust, Bolt-Ons 16 06-06-2012 04:32 AM
