| Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack Specific topics relating to wheels and tires. |
Drives: World Rally Blue BRZ
federal ss595
Hey everyone I have a question about federal ss595 tires. I haven't seen if this has been answered on the forum. I am looking for a cheap set of tires just to beat up on and I am interested in the federal ss585, but I hear they run kinda wide. My question is will a set of 215 45 17 or 225 45 17 federal ss595 tires fit on the stock wheels or are they too wide?
#2 |
Drives: Subaru
Not to wide, great tires for destroying or limited use. Had a pair on my last car and they suck as a performance tire but are cheap and can get the basic job done
| The Following User Says Thank You to BadBRZ For This Useful Post: | WorldRallyBlueBRZ (06-30-2014) |
#3 |
Thanks, Yea I'm just looking for something to beat up on and have some fun with. I kept hearing rumors that the tires ran wide but no one ever really said how wide and i didn't want to other them and have them not fit And the website i was going to order them from was no help.
#4 |
Drives: '13 BRZ Ltd WRB
basically, a 235 Federal is like a 245 from most others. I ran 235/45-17 (taller than stock) with no issues (stock height) on 17x9 +28 wheels.
they're a good tire for the price.
| The Following 2 Users Say Thank You to 2point0 For This Useful Post: | TheWhiteWizard13 (06-30-2017), WorldRallyBlueBRZ (07-01-2014) |
#5 |
I used them in that size, fantastic tire for the price. Go for the 225's.
| The Following 2 Users Say Thank You to Kostamojen For This Useful Post: | TheWhiteWizard13 (06-30-2017), WorldRallyBlueBRZ (07-01-2014) |
#6 |
The Angry Brit
Drives: 1991 E30 318iS
| The Following User Says Thank You to VacantSky For This Useful Post: | WorldRallyBlueBRZ (07-01-2014) |
#7 |
Awesome thanks for all the info guys. I searched on here and other forums and couldn't find an answer anywhere.
#8 |
Swiss Alps Driver
Drives: Toyota gt86
There is a misunderstanding i guess. 595rsr are awesome tyres (close from semi slick) and run wide.
Ss595 are different tyres, and are not very good. They actually kinda suck. They do not run that wide neither. |
#9 |
Thanks
255s should be run with a 35 sidewall on 17" wheels, not sure why would use a 40?
#10 | |
245/40 is the sweet spot for nearly the same diameter as stock on a 17" wheel.
| The Following User Says Thank You to 2point0 For This Useful Post: | hmong337 (07-02-2014) |
#11 |
SS595 also run wide. Maybe not to the extent of the RSR, but I haven't run those personally. But yes, they are two totally different animals.
| The Following User Says Thank You to 2point0 For This Useful Post: | WorldRallyBlueBRZ (07-03-2014) |
#12 | |
I'm running the 595RSR's now with my 18" wheels and they are leagues better than the ss595's. Splurge the little extra for the RSR's IMO but if you want to just wear out some tires, get the ss595's super cheap. |
| The Following User Says Thank You to Kostamojen For This Useful Post: | WorldRallyBlueBRZ (07-03-2014) |
#13 |
Platinum Member
Drives: Toyota 86 Vortech SC
The only experience I've had of SS595s is about 30 track laps that I did in an Inex Legends Racecar.
SS595s are their prescribed tyre. I wasn't impressed with the grip but I did find them easy to predict because they squeal a lot. If you want to make a lot of noise and smoke in an affordable manner - then OK... However, I run Federal 595RS-Rs on my S/C 86 and the RS-R is a different animal completely - excellent grip even when cold (so well suited to spirited road use), predictable, and I've had quite good life from them (I'm near the end of my second set). IMO a far better tyre and I'd recommend RS-Rs over SS595s anyday for road and light track use. However don't go for the 225/45-17 RS-R because it's the only size with shallower tread depth (5.2mm vs 6.5mm). For stock rims, I'd recommend 215/45-17 or even 215/40-17 which is the only size that has a 7.5mm tread depth giving it longer life but probably a vaguer feel when new. 595RS-Rs do run wide - a 215 RS-R is similar to a 225 other brand. See http://www.federaltire.com/download/spec595RS-R.pdf
| The Following User Says Thank You to Fish Eagle For This Useful Post: | WorldRallyBlueBRZ (07-03-2014) |
#14 |
@Fish Eagle, how many miles are you getting out of the RS-Rs, and what size are you running?
| Federal 595RS-R - Reviews? | empower-auto | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 23 | 05-12-2016 08:38 PM |
| FS: Federal 595-RSR 255/40/17 600 miles SoCal $200 | RiskyTrousers | Wheels and Tires | 2 | 06-12-2014 03:12 AM |
| (2) brand new 215/40/18 federal 595 tires | pinaygirlcassy | Wheels and Tires | 2 | 05-31-2014 08:55 PM |
| FS: Federal 595 tires - 235/40/17 (Socal) | HSC | Wheels and Tires | 1 | 05-02-2014 06:28 PM |
| Fluor Greenish Forged R17 8J ET39 on 225\45\17 Federals SS595 | MSTiFK8R | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 26 | 11-01-2012 09:37 AM |
