Old 07-01-2014, 12:19 PM   #1
MAPerformance
Drives: Asphalt FRS
MAPerformance FA20 Short Block
Hey everyone! We are happy to announce that we are offering FA20 short blocks! We have been so crazy busy around here with other projects lately, but we finally got around to focusing on this beauty. We have over 8 years building Subaru engines, as well as many other platforms (primarily 4G63 engines, GM LS engines, 2JZ etc).
Included Services
  • FA20 Crankshafts are never cut or turned, and they receive a micro-polish treatment and balancing specifically for high performance race applications.
  • The First step in the machining process is resurfacing. We pride ourselves on the surface finish (RA) we achieve as it is of the utmost importance in regards to head gasket sealing.
  • Next, we bore the sleeves square to the deck surface. Our MAP FA20 specific torque plate is used to ensure roundness. The overbore is followed with a four step plateau honing process that provides the absolute best cylinder wall finish and ultimate ring seating.
Included Components
  • OEM Toyota FA20 Main and Rod Bearings Installed With MAPerformance Specs
  • Option of Carrillo Pro H Beam Connecting Rods W/ CARR Bolt Upgrades, or Manley Turbo Tuff I Beam Rods
  • JE Forged FA20 Pistons (compression ratio ranging from 9.5:1 to 13.5:1)
Options
  • Crankshaft: We use standard size OEM crankshafts most frequently as we have not had a crankshaft failure to date. However, we realize that there are weight advantages and stroke options available with some aftermarket crankshafts so we will happily build your shortblock accordingly!
  • Pistons:If you would like to go with a different brand of pistons or are interested in a custom compression ration please give us a call.
Core Options
No core? No Worries! Simply select a new OEM FA20 short block option above for us to use as a starting point. New OEM FA20 engine cores require less cleaning, preparation and machine work compared to used FA20 shortblocks.
Please PM me for pricing info or any questions you may have
MAPerformance is offline   Reply With Quote
The Following 9 Users Say Thank You to MAPerformance For This Useful Post:
brianhj (07-01-2014), Creole (08-17-2014), DeliciousTuning (07-01-2014), JonAvalon (07-01-2014), Manji (07-01-2014), maxjedi (07-31-2014), neutron256 (07-02-2014), zoth (07-01-2014)
Old 07-01-2014, 12:39 PM   #2
RD1428
RD1428's Avatar
Drives: 2013 Scion FRS
Looks amazing, is there a discount if I send in my old core? Please pm me prices
RD1428 is offline   Reply With Quote
The Following User Says Thank You to RD1428 For This Useful Post:
MAPerformance (07-01-2014)
Old 07-01-2014, 12:43 PM   #3
Kuros
Drives: 2014 FRS Raven. 2011 sti red (gone)
Very interesting.
Whats the cost difference between a new short block and the rebuild of a used?
Kuros is offline   Reply With Quote
Old 07-01-2014, 12:57 PM   #4
DeliciousTuning
PhoneFlash by EcuTeK
DeliciousTuning's Avatar
Like those Carrillo rods.
The Following User Says Thank You to DeliciousTuning For This Useful Post:
Old 07-01-2014, 01:02 PM   #5
sluflyer06
Drives: 2014 BRZ Ltd - DGM
How does cylinder work (honing/ over boring/etc) compared to motors with a iron sleeve?
2014 BRZ Ltd. - DGM
E30 318is trackday funday car
E46 323ci vert
sluflyer06 is offline   Reply With Quote
Old 07-01-2014, 01:53 PM   #6
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
Originally Posted by MAPerformance View Post
[*]OEM Toyota FA20 Main and Rod Bearings Installed With MAPerformance Specs
I'm pretty sure @Element Tuning figured out that the rod bearings are prone to oil starvation and spinning as a consiquence. Was there any thought to upgrading those? Or is it possible to add different bearings?
The Following User Says Thank You to cdrazic93 For This Useful Post:
Old 07-01-2014, 02:52 PM   #7
MAPerformance
Drives: Asphalt FRS
PM'd
Old 07-01-2014, 02:54 PM   #8
MAPerformance
Drives: Asphalt FRS
Also PM'd!
Originally Posted by Kuros View Post
Very interesting.
Old 07-01-2014, 02:58 PM   #9
MAPerformance
Drives: Asphalt FRS
Yes sir. We are aware of the potential bearing issues with these engines, especially at the higher torque outputs. It's not my engine builders ideal situation to use OEM bearings, but there isn't a ton of options at the moment. However, we would be more than happy to upgrade to an aftermarket bearing of your choice no problem.
The Following User Says Thank You to MAPerformance For This Useful Post:
cdrazic93 (07-01-2014)
Old 07-01-2014, 03:01 PM   #10
MAPerformance
Drives: Asphalt FRS
There really isn't a big difference. If you do plan on sending in your core, we will over bore it typically .10 to .20 over with matching pistons.
Old 07-01-2014, 06:27 PM   #11
JackSmiley
JackSmiley's Avatar
Drives: A Potential Traffic Ticket
I wonder if a built block, but with stock compression ratio + turbo would be worth it.
JackSmiley is offline   Reply With Quote
Old 07-01-2014, 06:33 PM   #12
Reaper
in orbe terrum non visi
Reaper's Avatar
Drives: violent
with e85 yes.
The Following 2 Users Say Thank You to Reaper For This Useful Post:
DBW (08-01-2014), JackSmiley (07-01-2014)
Old 07-01-2014, 06:36 PM   #13
JackSmiley
JackSmiley's Avatar
Originally Posted by Reaper View Post
with e85 yes.
I do plan on running e85. I like the smell of fries in the morning. Hmmm....20psi on a built stock CR block would be something.
The Following User Says Thank You to JackSmiley For This Useful Post:
Old 07-01-2014, 06:37 PM   #14
Reaper
Reaper's Avatar
Drives: violent
that's my plan. 11:1 is about as low as I ever plan on going.
WTB: FA20 Short Block or Blown Long Block The Racers Line Want-To-Buy Requests 1 06-29-2014 05:21 PM
Fa20 with Fb25 block. jet86 Engine, Exhaust, Transmission 49 04-23-2014 06:21 PM
FA20 oem Short Block 3k miles Area51 Engine, Exhaust, Bolt-Ons 29 09-13-2013 01:01 AM
WTB: short block or long block DOTman05 Engine, Exhaust, Bolt-Ons 2 07-14-2013 06:48 AM
