Old 07-01-2014, 08:28 AM   #1
DarkSunrise
DarkSunrise's Avatar
Measured: Aero Lift, Roll Stiffness & Distribution, Steering Effort, and more
I was looking at C&D's long term review of their BRZ and came across this little gem. Some interesting facts in here (e.g., BRZ generates 25 lbs lift F and 35 lbs lift R @ 70 mph).
Apparently C&D also had their BRZ tested on a kinematics and compliance rig, so there's some suspension tidbits in there as well.
http://media.caranddriver.com/files/...lete-specs.pdf
2022 BRZ Build
2013 FR-S Build
The Following 5 Users Say Thank You to DarkSunrise For This Useful Post:
2013GTRNate (07-01-2014), Bristecom (07-01-2014), DAEMANO (07-01-2014), FRSBRZGT86FAN (07-01-2014), Silver Ignition (07-01-2014)
Old 07-01-2014, 08:35 AM   #2
sluflyer06
Drives: 2014 BRZ Ltd - DGM
Thats really cool but the numbers don't mean much to me without comparing it side by side with a handful of other cars to put it all in perspective.
Going to search for other reports like this.
2014 BRZ Ltd. - DGM
E30 318is trackday funday car
E46 323ci vert
sluflyer06 is offline   Reply With Quote
Old 07-01-2014, 08:51 AM   #3
DarkSunrise
Here's one for the Mustang GT:
2022 BRZ Build
2013 FR-S Build
The Following 2 Users Say Thank You to DarkSunrise For This Useful Post:
chas3wba0 (07-01-2014), DAEMANO (07-01-2014)
Old 07-01-2014, 08:57 AM   #4
sluflyer06
Originally Posted by DarkSunrise View Post
Mustang fairs pretty well, though through very different setup, impressive is how much higher the roll center is and the difference in anti-squat/anti-dive.
Hopfeully some reports on something like a Cayman/Miata/GTI etc would be fun. Thanks for finding this.
2014 BRZ Ltd. - DGM
E46 323ci vert
Old 07-01-2014, 10:45 AM   #5
phobos512
phobos512's Avatar
Drives: 2014 FR-S 6MT Whiteout
I found datasheets on their site for a few other vehicles (these are handwritten from comparison tests rather than the final panels like you see for the Mustang and BRZ but they contain similar data).
14 Ford Focus ST - http://media.caranddriver.com/files/...d-focus-st.pdf
14 Fiat 500 Abarth - http://media.caranddriver.com/files/...14-comparo.pdf
12 BMW 328i Manual - http://media.caranddriver.com/files/...ine-manual.pdf
14 Ford Fiesta ST - http://media.caranddriver.com/files/...14-comparo.pdf
Matt | '14 FR-S 6MT Whiteout | '13 Sonata Hybrid | '11 CBR1000RR
phobos512 is offline   Reply With Quote
The Following User Says Thank You to phobos512 For This Useful Post:
Old 07-01-2014, 11:35 AM   #6
sluflyer06
Actually not one of those has the Chassis/Kinematics dyno results, those are just standard testing notes. What we're looking at is the Aero Drag/LIft/ROll Centers/CG/etc etc.
2014 BRZ Ltd. - DGM
E46 323ci vert
Old 07-01-2014, 12:08 PM   #7
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
For how much we obsess about balance, the Mustang has a better F/R weight distribution according to these numbers. And that's the V8...
BRZ: 55.3/44.7
Mustang GT: 54.7/45.3
ineedyourdiddly
Old 07-01-2014, 12:33 PM   #8
DarkSunrise
BRZ: 55.3/44.7
This is an important point IMO. People conflate handling balance with weight distribution all the time. They're not the same.
The Twins are praised for their excellent handling balance (i.e., fairly neutral), but that's not the same as saying their static weight distribution is 50/50.
On the flip side, manufacturers like BMW love to brag about having "perfect" 50/50 weight distribution on their cars, but the handling balance on many current BMWs is not that great (i.e., significant understeer). Cars like the 135i and E92 M3 are good examples of that.
Handling balance is not the same as static weight distribution.
2022 BRZ Build
2013 FR-S Build
The Following 6 Users Say Thank You to DarkSunrise For This Useful Post:
Bristecom (07-01-2014), chas3wba0 (07-01-2014), Creole (07-03-2014), DAEMANO (07-01-2014), frsvr4 (07-02-2014), Skurge (07-02-2014)
Old 07-01-2014, 12:55 PM   #9
sluflyer06
truth. I came to the BRZ from a 135i with punched out alignment pins and E92 M3 front sway bar, I also undersized my rears to 235 just to try to get some balance out of it but still underteered terribly. However back when I had a E36 333i ZHP it was wonderfully neutral.
2014 BRZ Ltd. - DGM
E46 323ci vert
The Following 3 Users Say Thank You to sluflyer06 For This Useful Post:
Ammonia (07-02-2014), DAEMANO (07-01-2014), fstlane (07-02-2014)
Old 07-01-2014, 01:20 PM   #10
phobos512
phobos512's Avatar
I *did* say it wasn't all the same data. I looked through every file in the directory on their site and the Mustang and BRZ are the only ones in there with that aero data - it must be something new they only have just started doing.
Old 07-01-2014, 03:56 PM   #11
strat61caster
I never purported it to be. The conversation often goes that muscle cars are inferior due to the large motor in the front when in reality our little Japanese 4 banger has a similar weight distribution, just found it curious is all as I thought the Toyobaru was closer to 53/47 as I'm sure you know.
Handling dynamics are complex and not many people can gain a lot from a sheet like this (obviously putting aside the base info like curb weight and engine specs).
Thanks for the info
ineedyourdiddly
Old 07-01-2014, 04:22 PM   #12
DarkSunrise
Thanks for the info
Haha apologies man, I should have been more clear, I didn't mean you specifically. I was just quoting your post since you referenced it.
The conflation of handling balance and weight distribution was something I've seen frequently on the internet, sometimes even on this board, and was meaning to comment on. Your post just gave me the segue I was looking for.
Rather than 50/50, I've actually been thinking about whether a 45/55 MR layout (like the Cayman) is actually ideal for a RWD car.
  • The slight rear-bias would increase traction under acceleration vs. 50/50.
  • The slight rear-bias would give you more even weight distribution when braking vs. 50/50.
  • The mid-mounted engine would reduce polar moment of inertia, allowing better turn-in vs. FR, and easier oversteer recovery vs. RR. Also MR has minimal drivetrain loss.
A lightweight 55/45 FR car like the FR-S has its own advantages though, e.g., pretty good turn-in and probably the easiest oversteer recovery. Just not ideal for outright speed vs. MR.
2022 BRZ Build
2013 FR-S Build
Old 07-01-2014, 04:36 PM   #13
totopo
Drives: 370z
I think fmr is still better in terms of vehicle dynamics for performance. Iirc in the Japanese jgtc/supergt experience, with min weight requirements fmr with greater than 50% weight in the front ends up faster. The main benefit of mr over fmr is total weight.
Less weight in back means you can accelerate earlier at corner exit.
totopo is offline   Reply With Quote
Old 07-01-2014, 04:59 PM   #14
strat61caster
For going around a track and trying to nail down a great time? Definitely, there's power in being able to swing the back end around a corner and have the traction to seriously power out of a corner, for all the shit Porsche gets it's been effective for over 50 years at many levels of racing. Most of the major supercars in the last 10 or so years have been around there or even more rear weight biased.
I've been wondering the same thing and as I fantasize about getting another sports car the MR2 is a strong contender, both the MK1 and MK2 are roughly 45/55, it seems like for less than the cost of a Toyobaru you can get similar straight line performance and the advantage of the MR through the twisties.
ineedyourdiddly
install cruise control coz for me roll connector / steering sensor fail aagun Issues | Warranty | Recalls / TSB 15 11-14-2013 09:29 AM
Gearbox Stiffness? pevangelista Issues | Warranty | Recalls / TSB 3 05-08-2013 01:00 AM
Roll stiffness: Springs vs anti-roll bars? Captain Snooze Suspension | Chassis | Brakes -- Sponsored by 949 Racing 31 07-24-2012 05:44 PM
Steering wheel stiffness? j4m35ly Scion FR-S / Toyota 86 GT86 General Forum 6 06-20-2012 02:51 PM
Dealership to Dyno: Our FR-S gets measured Arsenal Autosport Engine, Exhaust, Transmission 21 05-30-2012 06:55 PM
