Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > Marketplace > User/Vendor/Sponsor Reviews, Feedback, Comments
Old 06-28-2014, 09:45 PM   #57
Philly758
Drives: GMC
Hmmmm, has Perrin ever provided an official response? I'm currently looking at motor mount options...
Philly758 is offline   Reply With Quote
Old 06-28-2014, 11:00 PM   #58
xwd
I think their official response was if you are going to use them in FI applications without heat shielding of some sort you are taking your chances.
I just installed the STi mounts in place of the Cusco ones. They do have shielding on one side of the mount, so it may not be an issue with those. The construction of the Cusco mounts doesn't really leave the urethane/rubber part of the mount exposed to much heat. They add a ton of NVH to the car though.
Old 06-28-2014, 11:41 PM   #59
evan
Drives: fr-s
Lol. A four banger melting mounts. Gotta love the aftermarket.
evan is offline   Reply With Quote
Old 06-30-2014, 10:30 AM   #60
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
@PERRIN_ADAM @PERRIN_Chris @PERRIN_Christina @PERRIN_Jeff @PERRIN_Mladen
Old 06-30-2014, 10:32 AM   #61
brz2013
brz2013's Avatar
Drives: 2013 wrb brz
And the over pipe melts the sway bar bushing Name:  ImageUploadedByTapatalk1404138751.917530.jpg
brz2013 is offline   Reply With Quote
Old 06-30-2014, 01:58 PM   #62
PERRIN_Chris
Drives: 2014 Subaru BRZ
Send a message via AIM to PERRIN_Chris
Originally Posted by FrX View Post
Add me to the list of molten mounts. Running an AVO kit. Mounts have been on the car since October, and have seen two track days. Was a bit sticky after the first track day, but after this last weekend, full on molten candle stick status.
Edit: On further inspection, it appears that the exhaust manifold gasket is leaking in that area too. That probably has a great deal to do with this.
Wow that is bad! I'd really suggest installing some heat shielding and/ or wrap, and of course figuring out the leaking. With any turbo kit install, it is required to install shields on the header or to wrap them to keep the heat out. Sending PM.
PERRIN_Chris is offline   Reply With Quote
Old 07-01-2014, 09:46 AM   #63
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
An AVO manifold.. leaking??? Who would have thought....
Like my friend @King Tut one day said, don't let this get on the way of a good story. (hint: sarcasm)
Old 07-01-2014, 10:01 AM   #64
sluflyer06
Drives: 2014 BRZ Ltd - DGM
Originally Posted by Ironsquid View Post
You guys don't live in Florida where it gets 98 degrees in winter. I melted a couple generic slimfans in a couple hours in Miami a month ago.
In any case, I'm pretty sure the Perrin mounts weren't designed for FI originally as I believe these came out of production before most turbo kits were developed.
It's not a bad part, but you northern parts shops need to consider 100+ ambient temps everyday driving, even if his car wasn't turbo'd these would have melted with aftermarket headers.
And FWIW, the stock mounts would have held the heat because they're made of materials with higher heat tolerances than a urethane filled and exposed mount. (weaker albeit, but *could* withstand the heat)
Meh, grew up in South Florida and now live in St. Louis, MO. Florida is not as hot as Missouri at all but it is much more humid. Florida is typicall high 80s and into mid 90s for some time. land locked regions will be up to 105F in the midwest for sometimes close to a month of summer. Sure there are really hot days here and there in FL but on the whole the temperatures are just not as high. Also think of guys in Arizona and other arid regions with temperatures around 110-115.
2014 BRZ Ltd. - DGM
E30 318is trackday funday car
E46 323ci vert
sluflyer06 is offline   Reply With Quote
Old 07-01-2014, 10:27 AM   #65
King Tut
NASA SpecE30 Racer
King Tut's Avatar
I bet he didn't use the right gaskets. It is ALWAYS the gaskets, and never the manifold.
Sportsguy83 (07-01-2014)
Old 07-01-2014, 03:33 PM   #66
Ironsquid
King of Kiwi Palace
Ironsquid's Avatar
Drives: Faster than you
Originally Posted by sluflyer06 View Post
Meh, grew up in South Florida and now live in St. Louis, MO. Florida is not as hot as Missouri at all..
ok..
Miami:
http://www.weather.com/weather/wxcli...graph/USFL0316
St Louis:
http://www.weather.com/weather/wxcli...graph/USMO0787
Who's average is hotter?
#math
Ironsquid is offline   Reply With Quote
Old 07-01-2014, 04:34 PM   #67
evan
Drives: fr-s
Do the AVO manifolds have a high tendency to leak? Are the mounting surfaces not true?
Old 07-02-2014, 08:17 AM   #68
Sportsguy83
Drives: Limited BRZ
Check my reply here...
http://www.ft86club.com/forums/showp...3&postcount=28
The Following User Says Thank You to Sportsguy83 For This Useful Post:
evan (07-02-2014)
Old 07-02-2014, 10:05 AM   #69
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Not sure if SRS. In my research there are more members with AVO kits that have had leaks than have not had leaks.
The Following 4 Users Say Thank You to King Tut For This Useful Post:
Draco_PR23 (07-04-2014), evan (07-02-2014), Sportsguy83 (07-02-2014), Tristor (03-25-2019)
Old 07-02-2014, 01:10 PM   #70
evan
Drives: fr-s
Definitely serious. I have not kept up with the AVO kit since early last year. I was considering it at some point while trying to make an FI decision. It is unfortunate that the vendor shortcomings are so varied and widespread across the board. Maybe there is some wisdom to having things custom fabbed locally (easier to hold someone responsible when things go sideways).
perrin engine mounts
Perrin or Cusco Engine Mounts and NVH APS86 Engine, Exhaust, Transmission 7 08-04-2018 02:08 AM
Engine Mounts? mrk1 Engine, Exhaust, Transmission 17 05-15-2016 04:31 PM
Perrin Engine Mounts and Cusco Catch Can Install and Review @ Pure Automotive Pure Automotive Engine, Exhaust, Transmission 23 05-15-2016 04:21 PM
engine mounts for FI jamesm Forced Induction 19 04-18-2013 08:57 AM
Perrin Engine Mounts and Cusco Catch Can Install and Review @ Pure Automotive Pure Automotive Mid-Atlantic 9 01-31-2013 01:03 AM
