Old 06-28-2014, 08:02 AM   #197
ZDan
ZDan's Avatar
Drives: '23 BRZ
Originally Posted by fooddude View Post
Also a little accidental typo/miscalc in ur post if u dont mind ...550whp would be more like 687hp at the crank if using that overexaggerated 25% gain/loss factor (not 733).
The basis for %age power loss is power at the crank, not at the wheels. If power loss were 25%, then 550rwhp would equate to 550/(1 - .25) = 733hp at the crank.
25% loss does not mean you multiply rwhp by 1.25 to get crank hp. You have to divide by (1 - .25), which is the same as multiplying by 1.333. I.e., the power loss percentage going from crank/flywheel hp to rwhp is not the same as the apparent power "gain" percentage going from rwhp to crank/flywheel hp.
Ur car sounds very interestng tho. Mind posting vids/pics
"Interesting" is a good word for it
fooddude (06-28-2014)
Old 06-28-2014, 08:07 AM   #198
serialk11r
Drives: '06 AM V8V Coupe
Really neat lookin engine. But I bet it costs grip loads of money..
Idk if that is built for longevity and reliability, or if it's only built to win races and only last a few seasons/sessions. But, that 10k rpm, ITBs and its' feather weight def sounds super awesome tho
Isn't the Atom powered by a built Honda B16 engine? Or was that a different TG episode? Lol ...or, I guess they have a V8 version now that uses the engine you mentioned?
The stock Atom is powered by a Honda K20. Which is by the way, a fantastic I4 (can be tuned to like 300hp NA, and with the transaxle is almost as light as a 2ZZ-GE + C60, which is impressive considering it makes way more power and is way more reliable). The FA20 is an okay engine, but the boxer configuration, 2013 precats, and dual injection hardware weighs it down some. If you're going to compare an LS3 +T56 weight wise, it's more of a fair fight to compare against an older motor with higher emissions like the K20.
You can get a similar V8 to that here: http://www.h1v8.com/page/page/1562068.htm
I think it's 30000 dollars for the engine :P
Old 06-28-2014, 03:24 PM   #199
fooddude
Drives: 04 Toyota Tacoma Prerunner Reg Cab
Originally Posted by cf6mech View Post
The kit will include an appropriate radiator, so no, not the stock radiator , the kit will also include a aluminum one piece driveshaft, engineered long tube headers specifically for the 86 and a major header manufacturer making a lot run for Vorshlag.
Yummy :9
Seeing how this kit will have nice headers and a mandatory intake already (since it's not a stock corvette afterall with a factory airbox lol), I am sure this will add a decent amount of power and will surely be above 400whp with a crate LS3. So with the headers and intake already included in this kit, all one needs is a tune (and/or cam) if someone wanted the usual bolt-on mods/upgrades
Really looking forward to seeing their included wiring/ecu/electrical harnesses too.
fooddude is offline   Reply With Quote
Old 06-28-2014, 03:35 PM   #200
Reaper
in orbe terrum non visi
Reaper's Avatar
Drives: violent
not putting a cam in a OEM LS engine is like not putting good tires on an frs.
Old 06-28-2014, 03:37 PM   #201
fooddude
@ZDan: thx for the corrections of calculations..never knew that.
Nice clean whip! Looks business. Do you DD that too?
Old 06-28-2014, 03:52 PM   #202
fooddude
@ZDan: Any vids??
Old 06-30-2014, 09:23 AM   #203
ZDan
ZDan's Avatar
Drives: '23 BRZ
@ZDan:Nice clean whip! Looks business. Do you DD that too?
Yes! A/C, P/S, full interior, etc. I've taken a few LONG trips in it, including from Providence, RI to Beeville, TX for the Texas Mile.
@ZDan: Any vids??
No vids, stupidly enough
Launch at Texas Mile:
fooddude (06-30-2014)
Old 06-30-2014, 03:53 PM   #204
fooddude
Very nice..Love the FD!
I just saw under your avatar you have a 240z too...man, that too is a nice ride. The FD is super nice too...but I think I woulda put the LS in the 240 ...always dreamed of the old 240 and 510 cars.
Old 06-30-2014, 08:17 PM   #205
fooddude
I think this would be very similar to an FRS with a crate LS3 or LS376 Hot Cam 480 in it, regarding Weight and Power.
280z (similar to the FRS at about 2850lbs; unlike the much lighter earlier 240z which was 2300lbs) and this also has an older/lower model LS1 (but with heads/cam and getting around 450whp, which is similar in power to a Hot Cam crate LS376/480.
[ame="https://www.youtube.com/watch?v=cooLNj4DnSA"]C6 Z06 vs LS1 280z - YouTube[/ame]
Old 07-01-2014, 04:58 PM   #206
SomeoneWhoIsntMe
Drives: 2013 Subaru BRZ
I really wanted an RWB Porsche. Nakai-san is brilliant, and the cars he turns out are incredible works of art. However, I couldn't bring my self to save for 5+ years to be able to reasonably afford a $10k+ bare shell, $20k for just a body kit and paint, and then who knows how much in wheel, suspension, so on and so forth, and then having to do some totally off the wall swap like VR-T or something because of the RR configuration.
To me, the only thing that comes close to an RWB in terms of class and style is a Rocket Bunny 86. The FR layout which can utilize powertrains which I'm more familiar with and has been proven to work with my favorite engine, the JZ, sold me on the idea. The fact that you get to build it yourself is just that much more enticing. RWB's you have to send out to get the kit fitted and painted. Which is sweet, but it also adds a lot of cost that I just couldn't justify.
And versus just buying a new, similar car? I would never be interested in something so exotic that you're totally boned if you blow it up driving it hard. The brilliant part about JZ / LS swapped cars is that you get the performance without sacrificing durability or ease of service.
1jz salvaged brz build thread brought to you by visconti tuning --> Pipe dreams and poor life choices
SomeoneWhoIsntMe is offline   Reply With Quote
Old 07-01-2014, 07:55 PM   #207
fooddude
Is anyone making FRS bolt on kits for the 2jz engines?
How much do 2jz engines go for these days? I assume pretty cheap?
What trannys work with a 2jz in an frs chassis?
How much does a 2jz weigh? With and without tranny?
I kinda like the idea of 2jz, because it's toyota and also an import engine still. And I like the idea of LS3 because it's NA and also can be easily bought brand new or found with low miles. 2jz will most likely be old, needs rebuilding, and is also a turbo and also cast iron.
Old 07-01-2014, 08:29 PM   #208
suaveflooder
This is why I prefer the LSX motor. Cheap all around. The 2JZ has sex appeal for sure, but for a simple motor that will just "get it done" on the track and take the beating without an issue, I would pick the LS motor personally. Either swap is bad ass, just my personal preference. Says something considering that I've owned mostly Fords
suaveflooder is offline   Reply With Quote
Old 07-01-2014, 09:44 PM   #209
SomeoneWhoIsntMe
Xcessive Manufacturing makes engine mounts but you're on your own after that.
I believe aristo vvti 2jz's are in the ballpark of $2200 but you'll need a manual trans
anything will need fabrication around the tunnel but I would go with an R154 or a nissan Z33 6-speed.
around 450lbs dry with accessories but without flywheel. It's also LONG and barely fits in the bay.
most 2jz's only need new gaskets which are cheap. Rebuilding one is a waste of a perfectly good high horsepower capable rotating assembly.
Old 07-02-2014, 10:04 AM   #210
ZDan
ZDan's Avatar
Drives: '23 BRZ
Sad to say I partial-traded the Z for the FD. Gave up car I built from dead stock to a 255rwhp street/track monster that took on and beat Z06s, Vipers, 911 Turbos etc. at the track. in its (and my) day
The Z is a much better platform for such swaps because of its basic architecture. To accommodate a LONG inline 6 while maintaining 50/50 weight distribution (mine weighed in at 49F/51R with fuel and me in it), the front wheels are shoved way forward of the firewall. This means you can swap in a large-displacement V8 and *IMPROVE* weight distribution (move it rearward), which is pretty critical to putting down a lot more power. Also, an LS V8 not any heavier than the stock iron-block aluminum-head inline 6, so near-zero weight gain.
With the FR-S/BRZ, some critical factors are working against you:
1. Front-biased 54/46 F/R weight distribution with driver and fuel might not seem too far off from 50/50, but that's 8% less weight on the drive wheels. Not an issue with 200hp, but it becomes significant when adding big power.
2. Since the stock engine is a very short H4, so just about any engine you swap in will have its c.g. situated well forward of the stock engine.
3. Since the stock engine is an aluminum 2.0 four, just about any big-power potential engine is going to be somewhat heavier, so the car is heavier and the c.g. is moved still further forward
In the end, with an LS FR-S/BRZ you'll have a ~2800-2850 lb. car with ~56/44 weight distribution with driver and fuel, vs. the swap in the 280Z where you'll be about the same weight with 49/51 (or better) weight distribution. The Z will have 14% more static weight on the drive wheels. That's HUGE if you're trying to put down ~400rwhp in a car of this weight.
fooddude (07-02-2014)
After the "Ferrari" 86, we now have the "Porsche" BRZ Nardi330 Scion FR-S / Toyota 86 GT86 General Forum 30 07-06-2013 11:41 AM
Portland people meet with Seattle area people before going into ForumFest 2013? stockysnail Northwest 24 06-18-2013 06:19 PM
First spotting in the wild! pr0j AUSTRALIA 3 07-22-2012 03:48 AM
Official: The new Ferrari V12 Ferrari Berlinetta Levi Other Vehicles & General Automotive Discussions 27 03-07-2012 11:31 PM
First Ferrari, now Porsche??? zoomzoomers Other Vehicles & General Automotive Discussions 33 02-26-2012 11:45 AM
