Old 06-23-2014, 04:33 PM   #1667
Racecomp Engineering
For a good auto-x/track/dailydriver mix, -2.0 degrees camber front and approx -1.75 in the rear with 0 toe is about right. More camber up front would help but past -2.0 you begin to see some uneven wear.
You would need camber plates or camber bolts to get -2.0 up front. Just bolts and I think you'll be closer to -1.5...which isn't bad but -2.0 is much more fun.
Without rear lower control arms to adjust with you may end up around -1.8 to -2.0, which isn't bad either.
- Andy
oldlostcory (07-23-2014), Turkish (06-23-2014)
Old 06-23-2014, 06:41 PM   #1668
jvincent
jvincent's Avatar
Originally Posted by 7thgear View Post
guys I'm blind
there used to be a thread that had all the swaybars listed for comparison and I can't find it now.. plz help?
Here you go.
http://www.ft86club.com/forums/showthread.php?t=49659
The Following User Says Thank You to jvincent For This Useful Post:
7thgear (06-23-2014)
Old 06-27-2014, 02:08 PM   #1669
Malt
Drives: 2015 WRX
For those of us with camber plates and slotted mounting holes/camber bolts would there be any benefit to adjust for positive camber at the strut and then dial that positive camber back to negative with the camber plates to get the scrub radius to a minimum?
Malt is offline   Reply With Quote
Old 06-27-2014, 02:25 PM   #1670
1Cor10:23
1Cor10:23's Avatar
Drives: '13 Whiteout FR-S (M/T)
- Andy
Going to install camber plates and RLCAs next week - should I remove my front camber bolts or leave them in there for future in case I want to dial in more camber?
Looking to do the 2.0/1.75 you recommended.
Thanks!
1Cor10:23 is offline   Reply With Quote
Old 06-27-2014, 02:32 PM   #1671
Thanks!
Kind of an answer to both questions here.
It is a good idea to get more of your camber from the lower mount via bolts or a slotted mount. You will probably need to still move your plates in a bit, but get the majority down low.
Also, it's better to make sure the plates are set even and then fine tune with bolts to make sure you're good side-to-side.
- Andy
1Cor10:23 (06-27-2014), gramicci101 (06-27-2014)
Old 06-27-2014, 02:46 PM   #1672
gramicci101
Off Topic
- Andy
Are the bolts capable of finer correction than the plates are?
Old 06-27-2014, 02:48 PM   #1673
1Cor10:23
1Cor10:23's Avatar
Chalk it up to the awesomeness that is @Raceseng cascam! I'll admit they are expensive but my god are they worth it!.
Hey Malt, did you max them out? Is there a sweet spot or is this one of those things that you want to max out within reason?
Cheers.
Old 06-27-2014, 02:51 PM   #1674
Malt
Drives: 2015 WRX
Cheers.
Actually my camber plates are set at 0 camber atm! I had enough adjustment in the T2 slots to get -2 like I wanted. I am however enjoying the 7 degrees of caster the plates gave me.
Before I goto VIR in sept I'll go get another alignment for -3 up front and I'll obviously have to use the plates for adjustment then.
The Following 2 Users Say Thank You to Malt For This Useful Post:
1Cor10:23 (06-27-2014), Racecomp Engineering (06-27-2014)
Old 06-27-2014, 02:58 PM   #1675
It's more important that the plates are "even" since they have an effect on roll center location and it's nice if it's in the middle of the car.
- Andy
gramicci101 (06-27-2014), Surok (07-02-2014)
Old 06-27-2014, 03:07 PM   #1676
Getting more of your camber from the plates would give you a higher roll center, but getting more from the lower mounts gives you a better SAI. For most people the better SAI is the better deal.
If you're very low it could better to use the plates and have a slightly higher roll center. Also could be a little track dependent.
- Andy
Surok (07-02-2014)
Old 06-27-2014, 03:08 PM   #1677
gramicci101
Off Topic
- Andy
Ah, didn't know that. Thank you.
Actually, I don't understand. Either one will make the knuckle pivot inwards on the lower ball joint. If you draw a line between the lower ball joint and the strut top nut, a camber bolt would effectively fold that line at the lower strut bolt, whereas a camber plate would tilt the entire line inwards by moving the top nut. Either way, the effect at the lower ball joint is the same. How does one affect roll center location and not the other?
edit: How did you answer my question before I asked it? Is that because you're on the east coast?
Old 06-27-2014, 03:14 PM   #1678
1Cor10:23
1Cor10:23's Avatar
Actually, was referring to caster haha. Should've been more clear.
Old 06-27-2014, 03:47 PM   #1679
Changing camber at the lower mount doesn't necessarily affect strut angle or the lower link angle.
I'm just so damn good!
(someone PMed a similar question and I decided to post the answer here)
- Andy
Old 06-27-2014, 04:08 PM   #1680
gramicci101
Off Topic
- Andy
So, using Fig. 14 as an example, you would dial in more camber at the plate by moving the thrust bearing towards the vehicle centerline, right? That doesn't change the angle of the transverse link, so the center line of the virtual reaction point stays the same. However, it changes the angle of the steering axis. It also pushes the tire pivot point (intersection of steering axis and ground) towards the outside of the vehicle, because that line is pivoting on the lower ball joint.
It looks like the line between the virtual reaction point and the thrust bearing is at a right angle to the steering axis. If so, the change in steering axis angle would bring the virtual reaction point closer to the vehicle centerline, and when you draw the connection between the new virtual reaction point and the new tire pivot point, you get a higher intersection with the vehicle centerline, which means a higher roll center.
Am I correct? Is that small amount of change significant enough to produce major changes to the roll center?
If that is how it works and I'm not actually plummeting down the rabbit hole, then changes at the upper strut mount bolt (camber bolt) would serve to lower the roll center very slightly. Since the strut is not directly connected to the transverse link and lower ball joint, instead being connected to the knuckle, which is connected to the lower ball joint, adding negative camber at the camber bolt will fold the line a little at the other strut mounting bolt and bring the steering axis just a hair closer to vertical, which would push the virtual reaction point further out, which would lower the roll center just a little. Or is that change so minor that it's only interesting in theory? Would the negative roll center change from the camber bolt sufficiently offset the positive change from the camber plate?
I'm not at home or I could draw pictures of what I'm talking about to better demonstrate that I'm not crazy.
Air Suspension Discussion Thread - Let's Get Nerdy Andrew@ORT Suspension | Chassis | Brakes -- Sponsored by 949 Racing 174 02-13-2016 04:17 PM
RallySport Directs Everything Suspension thread!! RallySport Direct Brakes, Suspension, Chassis 21 07-02-2014 06:31 PM
The OFFICIAL Ohlins Coilover Suspension thread - High End Competition Suspension ModBargains.com Suspension | Chassis | Brakes -- Sponsored by 949 Racing 63 05-22-2013 09:15 AM
2012 Team USA vs the 1992 Dream Team ERZperformance Off-Topic Lounge [WARNING: NO POLITICS] 1 09-14-2012 07:19 PM
Team build thread; PROJECT.STH trueno86power Other Vehicles & General Automotive Discussions 0 03-02-2010 11:13 AM
