Old 06-27-2014, 11:37 AM   #4873
tahdizzle
So elite I'm 1338
Drives: WRB Subaru BRZ
Any news on the 210+ kit? I have searched and haven't found any new information.
The innovate kit is my chosen FI, but i've been thinking about baseball to keep from blowin my load on it because of the 210+ kit.
Old 06-27-2014, 12:39 PM   #4874
mikalem
mikalem's Avatar
Drives: 2020 DGM BRZ Limited
Originally Posted by xjohnx View Post
Anyone else running @DeliciousTuning's 8.59 rom notice that almost all of that nasty rasp/resonance around 4k rpms is gone (or at least, greatly reduced?)
That rasp/resonance was likely the car on the tip of mis-fire - 8.58 was doing it for me - on the test maps I was working with Bill on it stopped the moment he adjusted the ratio of DI/PI if memory serves. Car is much happier for it
mikalem is offline   Reply With Quote
Old 06-27-2014, 12:44 PM   #4875
xxscaxx
Drives: 2013 SWP BRZ
can't wait for 8.59. Only think theres a few with it so far.
xxscaxx is offline   Reply With Quote
Old 06-27-2014, 12:57 PM   #4876
olorin
olorin's Avatar
Drives: GBS Premium
Originally Posted by moto-mike View Post
Finally stitched together some video from the WBM event. Enjoy the whine!
Any plans to release that intake?
olorin is offline   Reply With Quote
Old 06-27-2014, 01:04 PM   #4877
Xero-Limit
Xero-Limit's Avatar
Drives: JDL Turbo FRS, 335SC BRZ (ret)
Green lighted and welded up 4 of them yesterday. We will have some pictures next week. They will be powdercoated and use a giant filter in the engine bay. Best for intercooled setups or those running primarily e85.
Though not a cold air intake, the advantages of a full 3" intake and an oversized filter outweigh the benefits of a (restrictive) cold air intake.
No bumper removal required.
Xero-Limit is offline   Reply With Quote
Old 06-27-2014, 01:13 PM   #4878
mikalem
mikalem's Avatar
Is it going to require any scaling for the MAF in the tune, or is it completely plug in play if you were tuned with the stock airbox?
Old 06-27-2014, 01:16 PM   #4879
Xero-Limit
Xero-Limit's Avatar
It will need to be scaled for. We'll provide our approximate scaling for other tuners, but AFRs should be double checked since it is a custom part.
Old 06-27-2014, 01:16 PM   #4880
olorin
olorin's Avatar
Drives: GBS Premium
Awesome, I'm interested. That will go well with your FlexFuel kit I just put in
Old 06-27-2014, 03:18 PM   #4881
Draco-REX
Corner Junkie
Draco-REX's Avatar
Drives: 13 BRZ, 11 STI, 99 RS
Is there any information other than the name? If not, I wonder if it's what people are thinking it is.
The current kit uses a 210 already. So, to me at least, 210+ implies that it uses the same blower. Would Sprintex make a bigger blower and name it the same as a smaller one? I wouldn't believe so..
Old 06-27-2014, 04:08 PM   #4882
tahdizzle
So elite I'm 1338
I have no idea. I'm trying to find out more information beyond "Sprintex is developing a 210+ and 335 kit."
Old 06-27-2014, 05:10 PM   #4883
Calum
That Guy
Drives: 2013 asphalt FRS MT
First off, I'm assuming that the 210 compressor is limited to the speed that it is, because of the critical speed of the shafts. So, my assumption was that the 210+ compressor would include shafts with a higher modulus of elasticity as that would move the critical speed higher. This would allow the same compressor to move more air. Hopefully these new shafts would include a different profile to help with efficiency at the higher speeds.
Old 06-27-2014, 05:32 PM   #4884
DeliciousTuning
PhoneFlash by EcuTeK
DeliciousTuning's Avatar
Couple in tuning development right now. Definitely flows more air but we are refining the tune for it at the moment and working on getting some numbers on it.
8.59 Revision:
We are slowly releasing updates, as we need to customize each persons map, as every person has custom setups and this is a very time consuming process.
Intake Options:
As for intakes, we have different calibrations for various intakes now including Stock, Airaid, 3" and 2.5", all tested and running well on our new 8.59 tune. Of course you will need custom scaling for the 3" and some 2.5" but we have that taken care of now with some geat customer support.
Intake Temp Notes:
If you plan on running intakes that may induce more hot air than your standard intakes we have created custom intake temp compensations for ignition and fueling already built into our maps. In certain scenarios such as sitting in traffic, waiting in line at an Autocross or Drag event we have seen temps rise to near 180 degree Fahrenheit (80 C) on some intakes. But having these compensations in place helps to protect the engine from pre-detonation but can lower the torque levels of the vehicle, slowing response and power output until the air has cooled sufficiently.
So making sure you have cool ambient air coming into the FA20 engine is key on large or standard sized intakes for consistent and optimal power output. It may be worthwhile on the "warm" air intakes to add some sort of shrouding to the intake in order to keep cool air flowing to it or so that it draws cool air from outside the vehicle. Might be the best of both worlds, larger intake size and cool air.
Cheers,
William Knose
Old 06-27-2014, 06:13 PM   #4885
xjohnx
Grip>Slip
xjohnx's Avatar
All I know is that I had been running my stock axleback because of the rasp. Reinstalled my nameless axleback tonight and it sounds so much better now.
Old 06-27-2014, 08:09 PM   #4886
MINOCIN
MINOCIN's Avatar
Drives: Asphalt 2013 FR-S
This. I switched back to the stock muffler for the same reason, but after truly missing my Nameless axleback and then learning to keep my revs under 4K for daily driving I then switched back to the Nameless. I would love to get rid of the rasp at 4K though. I basically drive on a self-imposed limp mode because of it
I honestly thought the rasp was due to my headers in combination with the super charger. As though they were just a bad match and not well suited.
GFR - aka my build thread
"They don't think it be like it is, but it do." -Oscar Gamble
MINOCIN is offline   Reply With Quote
Innovative ideas to increase interior storage capacity? swift996 Cosmetic Modification (Interior/Exterior/Lighting) 0 01-30-2013 10:45 PM
AVO vs Innovative diss7 Forced Induction 32 01-21-2013 06:15 PM
Technical topic sub-forums OrbitalEllipses Site Announcements / Questions / Issues 1 07-17-2012 11:38 PM
