Old 06-26-2014, 08:43 PM   #15
BRZnut
Drives: BRZ DGM Limited
my gap is slightly more on the right than the left, but nothing as bad as the pic. I think that is how the crickets get in.
Old 06-27-2014, 04:40 PM   #16
iamdaspoon
iamdaspoon's Avatar
Drives: 2015 Subaru WRX
Originally Posted by dtrop View Post
Your steering wheel is wicked dirty.
All the yellow is from the oil sticker in the windows reflection
iamdaspoon is offline   Reply With Quote
Old 06-27-2014, 04:43 PM   #17
ZionsWrath
Thanks
ZionsWrath's Avatar
Why do you have an oil change sticker in the window? I thought that was for granny's with dementia
Old 06-27-2014, 04:44 PM   #18
iamdaspoon
iamdaspoon's Avatar
Got the car serviced and never bothered to take it off. It does get annoying though.
Old 06-28-2014, 03:07 AM   #19
ShibaYuki
Drives: 2013 WRB Subaru BRZ Sport-tech
Originally Posted by Roadliner View Post
The airbag module is held in by 3 bendable metal clips in a hole behind each of the steering wheel spokes, including 1 just behind your problem area. The clip might be loose? Try pushing that area of the airbag module to see whether it 'clicks' back into place first?
Uhh, yea. I tried doing so but all I basically did was make a lot of noise. Haha! It still in an indented position. And now it's annoying me. Should I take mine to the dealer and let them explain to me how it happened and how to fix it?
ShibaYuki is offline   Reply With Quote
Old 06-28-2014, 01:11 PM   #20
dreroc-z
Drives: 1989 Camaro IROC Z28
Disconnect your negative terminal first then tinker around with it.
dreroc-z is offline   Reply With Quote
Old 06-28-2014, 01:30 PM   #21
ericmpena
ericmpena's Avatar
Drives: Subaru BRZ Limited
Do a warranty claim on that. Shouldn't be hard to get them to replace it for you.
ericmpena is offline   Reply With Quote
Old 06-28-2014, 02:02 PM   #22
1Cor10:23
1Cor10:23's Avatar
Drives: '13 Whiteout FR-S (M/T)
Mine also marginally larger gap on right as others have described, not as bad as OP. Hope you get that taken care of via warranty.
1Cor10:23 is offline   Reply With Quote
Old 06-29-2014, 01:27 PM   #23
brzadrian
I'm Batman
brzadrian's Avatar
Drives: 2013 Subaru BRZ aka Sally
i got the same problem!
brzadrian is offline   Reply With Quote
Old 06-29-2014, 04:51 PM   #24
iamdaspoon
iamdaspoon's Avatar
Anyone else's e brake boot popping out?
Old 06-30-2014, 06:48 PM   #25
extrashaky
Drives: 2014 BRZ Limited
Originally Posted by kberkel View Post
Not to be rude, but how?
By pushing it repeatedly.
Today I realized that when I swing my legs out of my car, I brace myself against the steering wheel with my right hand against that exact area. I suspect that the people having trouble with the trim separating are actually bending their steering wheels and pushing that trim apart little by little over time by using the steering wheel to lever themselves out of the car.
Upon close inspection, the gap on mine is ever so slightly larger on the right. Now that I've seen the pics here of the damage that can be caused, I think I'm going to be a lot more careful of what I grab onto.
WTB: Stock steering wheel (wheel not airbag) mobybrz Interior Parts (Incl. Lighting) 2 09-11-2014 03:23 PM
Steering Wheel mikeTee Cosmetic Modification (Interior/Exterior/Lighting) 8 03-30-2014 03:46 PM
scion frs steering wheel air bag and steering wheel Jhon19lopez Interior Parts (Incl. Lighting) 7 01-04-2014 07:04 PM
Swapping steering wheels with a new tC steering wheel. jonathan9573 Cosmetic Modification (Interior/Exterior/Lighting) 4 12-21-2013 12:45 AM
Seperation of Australian and New Zealand regional forum diss7 Site Announcements / Questions / Issues 19 09-26-2013 08:15 AM
