Old 06-25-2014, 09:39 PM   #1
Jericon
Drives: 2013 WR Blue BRZ Ltd
Issues swapping brake lines
I'm working on upgrading to stainless lines. For the life of me i cannot get the hard line loose from the stock lines
Any tips?
Jericon is offline   Reply With Quote
Old 06-25-2014, 10:29 PM   #2
Dezoris
Dezoris's Avatar
Any tips?
It's a pain in the ass because of the undercoating on the nut, make sure you use flare wrench and penetrating lube. and hold that stock line and bracket stable.
One side of my car took like 15 minutes of careful blows to wrench.
Never put it in brake video but it was an issue.
Old 06-26-2014, 06:56 AM   #3
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
Yea it was a bitch to loosen it. I sprayed WD40 multiple times and waited. Then used a vice grip to hold the metal part of stock line whilst loosening the nut with flare wrench. And prayed hard I don't strip the nut. It came loose in the end, but took abit of force, more than I expected.
Fizz is offline   Reply With Quote
Old 06-26-2014, 09:58 AM   #4
wparsons
wparsons's Avatar
The most important part is using a proper flare nut wrench, not a normal open ended wrench!
flickr
Old 06-26-2014, 05:24 PM   #5
Khyron686
Drives: 2011 Outlander XLS, 2013 FR-S Blue
Ahh I don't own any, thought I could get away with normal open ended. What size do I need to pick up, if you know? Rather buy 1 good one than a full cheap set if possible.
Khyron686 is offline   Reply With Quote
Old 06-26-2014, 07:24 PM   #6
wparsons
wparsons's Avatar
The chances of rounding off the nut are much higher with a normal open ended wrench than the proper wrench. I don't know what size, but you can easily put a normal open ended wrench on one of the nuts on the car to figure that out.
flickr
Old 06-26-2014, 11:13 PM   #7
BatStig
Some say.....
BatStig's Avatar
Drives: 2007 Subaru Impreza 2.5i
10mm, if my memory serves me correctly.
BatStig is offline   Reply With Quote
Old 06-27-2014, 01:18 AM   #8
CSG Mike
CSG Mike's Avatar
Any tips?
Get that undercoating off of the nut, and you'll be able to get it off.
whataboutbob (06-27-2014)
Old 06-27-2014, 03:47 PM   #9
Cjymiller
Original 2013 Owner
Cjymiller's Avatar
Drives: 13 BRZ, Galaxy Blue Silica
These were a total PITA to change on mine and my friends' cars. By the last car, the method I did was as follows:
1. PB blaster and tap the bolts every 5 min for 40-60 minutes.
2. Use two vice grips to loosen.
3. Profit
Forget the flare wrench, as that started stripping the head of the nut (which is why we went to vice grips). Just make sure your vice grips are on effin tight and are flush with the nut and check against stripping the head as you try. If its sliding, tighten the vice grips more and try again.
Perrin Headerback, OFH, OFT, Ohlins R&T MI20, 17x9 Weds TC105N, Hankook RS4 (235/40), TOM's JDM Tails, PCV AOS, Perrin Crank Pulley, Perrin Rear Trans. Mount, Whiteline Shift Bushing, SS brake Lines, Hawk DTC60, Bayson R Lip Kit, LED Lighting , Smoked JDM Sidemarkers, Rear Fog Enable, Carsmo Armrest, Grimmspeed Plate Relocater
φφκα
Cjymiller is offline   Reply With Quote
Old 06-27-2014, 09:28 PM   #10
Model Citizen
Lacking brains
Drives: frz
Carefully use a torch, to heat the nut without burning anything else.
they come right off.
mine were rounding off even with a flare nut wrench, after heating even though the nuts were partially rounded they came right off.
Originally Posted by cjsporl1996 View Post
If this thread is not deleted I can file a lawsuit.
Model Citizen is offline   Reply With Quote
Old 06-28-2014, 01:28 PM   #11
wparsons
wparsons's Avatar
^^ I had to heat mine too, just be sure to FULLY flush all the old break fluid out if you torch anything in the braking system.
flickr
Stoptech S/S brake lines: same between stock caliper vs big brake kit? mav1178 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 11 05-10-2016 07:14 PM
Swapping brake fluid barabia Suspension | Chassis | Brakes -- Sponsored by 949 Racing 6 08-12-2013 09:58 PM
Issues Swapping Back/Forth from 5spd MT & 6spd MT? endos2000 BRZ First-Gen (2012+) — General Topics 29 02-17-2013 02:56 PM
Redline360: Brake Lines, Brake Rotors, Brake Pads for BRZ/FRS Redline360 Brakes, Suspension, Chassis 12 01-05-2013 10:20 PM
