Old 06-24-2014, 11:24 PM   #1345
fast_dude
Drives: 2014 Scion FRS
Originally Posted by s2d4 View Post
Thanks. I got it going now.
2014 Scion FRS- Kw2 suspension, Openflash headers, Openflash tablet, Invidia N1 exhaust, Invidia Overpipe, Nameless catted front pipe, TRD intake, Enkei RPF1s with Hankook RS3 tires, carbon fibre front lip, TRD knockoff spolier, SPC lower control arms.
fast_dude is offline   Reply With Quote
Old 06-24-2014, 11:40 PM   #1346
Annahra
Annahra's Avatar
Drives: 2014 WRB BRZ LTD
No, Yes.
Thanks--played with it a little more and figured it out!
Annahra is offline   Reply With Quote
Old 06-25-2014, 12:18 AM   #1347
steve99
Drives: FT86
we are up to 1.9 now....
+1 on that that OFM your using is way old
grab new one from here
http://openflashtablet.com/products/...ads/index.html
as well as new template file and windows 8 patch if your on windows 8
Old 06-25-2014, 11:53 AM   #1348
bkblitzed
is better than you
bkblitzed's Avatar
Drives: 2013 raven FRS
Will the regular 2.5 Perrin CAI work fine with the OFT maps? Or will i have to adjust the MAF or AFR's through RR?
bkblitzed is offline   Reply With Quote
Old 06-25-2014, 02:26 PM   #1349
ST-A
Master Tuner
Drives: GT86 + Celica ST205 GT-4 WRC + MR2
just installed the Kraftwerks SC kit, now onto tuning using the OFT.
does anybody know if the stock MAP sensor can also be rescaled so it can read about 1bar/15psi? stock it seems it can read up to 0.4bar
Or do i need an upgrade sensor like the denso/honda K20 map sensor?
ST-A is offline   Reply With Quote
Old 06-25-2014, 03:04 PM   #1350
phrosty
They are very similar until you get near 5V. It should be safe. Perrin was nice enough to share their scaling though, so there's no reason to not adjust it in RR.
phrosty is offline   Reply With Quote
Old 06-25-2014, 06:03 PM   #1351
smbstyle
smbstyle's Avatar
Drives: 2013 SWP BRZ
I have been running a OFT that I purchased new about 2 months ago; running the latest software. 93 octane, only other mods are HKS drop-in, snorkel mod, cat delete pipe and muffler delete.
After about my 5th track day and 1k miles later after I installed it, I've noticed that it's stumbling on warm startup pretty good; two cranks with nothing, 3rd crank stumbles a bit then idles fine after that. Full WOT without any issue after that, no CEL lights or anything.
Any ideas what is causing this or has anyone else had the same issue?
Flashed back to the stock tune and it's not stumbling anymore.
2013 SWP BRZ
Build Thread: http://www.ft86club.com/forums/showthread.php?t=38781
smbstyle is offline   Reply With Quote
Old 06-25-2014, 06:48 PM   #1352
steve99
Drives: FT86
It might be just heat soak, were you fanging round track on a hot day then stopped for a bit then tried restart ?.
When you flashed back to stock it would have had 10 minutes to cool down.
Other than bump up idle speed dont think oft tune on petrol do much else in that area dont think they changed cranking enrichment on petrol.
leave bonnet up to let heat out after track work may solve it.
smbstyle (06-26-2014)
Old 06-25-2014, 07:49 PM   #1353
troek
troek's Avatar
Drives: 2012 Toyota 86
if its not an overheating issue like mentioned above, you could try getting your battery tested. its a very easy check and will eliminate that variable.
troek is offline   Reply With Quote
The Following User Says Thank You to troek For This Useful Post:
Old 06-25-2014, 08:19 PM   #1354
fast_dude
Hey guys,
I finally got the oft stg 1 installed and the car runs great. I am thinking of picking up a uel borla headers and a downpipe. I am just wondering if the stg 2 tune will throw any cels? thanks again.
Old 06-25-2014, 08:24 PM   #1355
steve99
Drives: FT86
Originally Posted by fast_dude View Post
Hey guys,
stege 2 tune should disable the p0420 cel for cat efficiency if it was missed just open tune in romraider and diable that cel code then flash
Old 06-25-2014, 08:26 PM   #1356
fast_dude
ok, thanks.
Old 06-27-2014, 10:49 PM   #1357
Triumphrider
Triumphrider's Avatar
Drives: 2013 Scion FRS in white out
Hopefully a quick question for someone. I updated my oft tonite using the OFM program. I clicked on "upgrade" after, however it keeps asking me for a template? What does that mean?
2013 Scion Frs AT in Whiteout, Borla UEL header, Greddy SP Elite AxleBack. Kraftwerks C38 Supercharger tuned by Moto East and 2 kid seats in the back.
Triumphrider is offline   Reply With Quote
Old 06-27-2014, 10:56 PM   #1358
Malt
Drives: 2015 WRX
The upgrade button is for applying new template files located at http://openflashtablet.com/products/...ads/index.html
Sometimes when the firmware is updated on the tablet you have to apply a new template. Shiv usually tells us if/when we need to upgrade the template.
If you are looking to get the newest maps you will need to either download the off the shelf maps on Shiv's site or wait for new Dev files to be released.
As of the most currently released maps the 1.5x series, the only difference between the 1.50 and subsequent versions is the added support for additional CalID's and as such there is no need to load the newest versions of the maps if the OFT currently works for you and you have at least a 1.5x series map on it OR the dev fiile.
Malt is offline   Reply With Quote
#lolwut, divinecomedy, dopeandcashcabinet, free shiv now, goddamitimissedit, golden cage, i missed the show, looks good, missed the fun, omgbbq, shiv 2016, thefatandthefurriest
Tablet on the dash ! TRD_86 Electronics | Audio | NAV | Infotainment 23 05-16-2015 03:48 AM
Tablet Install ThugNasty Electronics | Audio | NAV | Infotainment 4 04-13-2013 03:15 PM
Blutooth OBD II and a 9.7 tablet.. Scooby South Electronics | Audio | NAV | Infotainment 10 12-16-2012 08:11 PM
7.0 Tablet w/ Torque App Thatruth2001 Northwest 26 11-21-2012 11:53 AM
