Old 06-25-2014, 03:07 PM   #15
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
Originally Posted by FloridaBRZ View Post
So would either of the two coilovers I was thinking about fit the bill?
I'm a bad person to ask, my expectations are so high that i wouldn't bother spending money on suspension unless it is an Ohlin or Penske unit (or a lower end unit custom valved to my specs), and if i was going to lower the car i definitely wouldn't do it unless i have geometry aligning components ready to go as well.
personally i see no reason for people to coilover their dailies, if that gap is super important to you then do whatever you want, but in my eyes it's never a right choice.
Old 06-25-2014, 03:12 PM   #16
ZDan
ZDan's Avatar
Drives: '23 BRZ
I'd much rather try to put 400-450hp down through the stock suspension than through budget coilovers...
The Following 3 Users Say Thank You to ZDan For This Useful Post:
andrew20195 (06-25-2014), husker741 (06-26-2014), toeout (06-28-2014)
Old 06-25-2014, 03:15 PM   #17
tobin
tobin's Avatar
Drives: '13 BRZ
tobin is offline   Reply With Quote
Old 06-25-2014, 03:25 PM   #18
FloridaBRZ
Drives: 2013 Subaru BRZ Limited 6sp DGM
But some people have warranties still they don't want to void. Trust me, if I didn't have a warranty, id rather go FI before I started suspension work. I'm looking to do about 4k worth of mods that wont totally void my warranty to customize my car to make it more fun, until I can boost it.
FloridaBRZ is offline   Reply With Quote
Old 06-25-2014, 03:29 PM   #19
andrew20195
Originally Posted by Anthony7515 View Post
I'm getting my car turboed next week and on stock tires and wheels it won't cut it lol especially that I'm going for 400-450whp
If your goals are in that power range, you obviously have money to spend. Why go for the cheapest coilovers you can find? You don't need coilovers to fit decent sized wheels/tires, and like ZDan said, it would probably be better to remain stock than to go with dampers that may actually perform worse than the stock ones.
Enkei RPF-01s in 17x8 or 18x8 will fit, and you can run some sticky 245s on them.
andrew20195 is offline   Reply With Quote
The Following User Says Thank You to andrew20195 For This Useful Post:
Anthony7515 (06-25-2014)
Old 06-25-2014, 03:34 PM   #20
FloridaBRZ
So what is considered "budget coilovers"?
Old 06-25-2014, 03:36 PM   #21
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
your goals are simply outrageous and your budget lacks forethought entirely
want to have fun in your car? go to an autocross or lapping day
4000 dollars is 3 seasons worth of top of the line tires and entry fees to all the events you can drive out to.
The Following User Says Thank You to 7thgear For This Useful Post:
Old 06-25-2014, 03:44 PM   #22
FloridaBRZ
How are my goals outrageous? My budget is my budget. I was thinking 4k of suspension mods and maybe some minor cosmetic tweaks. Toms tails, or something like that. And once my warranty was almost done, then invest 5 or 6k in Fi and a proper tune. I think you are just totally against nodding a DD. But that is your opinion and prerogative.
Old 06-25-2014, 03:49 PM   #23
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
sorry I thought you wanted 450hp off 4k investment, I got my users confused.
4k for suspension is a good start though, just keep in mind that dampers are a wear and tear item; so whatever you upgrade to, make sure it is rebuildable locally.
Old 06-25-2014, 03:53 PM   #24
gramicci101
Off Topic
What are your goals for suspension? How much do you want to drop it? How stiff do you want it to be? Is tracking the car your primary focus, or is this your daily driver that sees occasional track time? By track time, are you doing actual tracks, or autocross? If you're doing autocross, what class are you in? Are you aiming to be competitive at regional or national level in that class?
Different answers to these can all point towards different coilovers. Or even springs and struts instead of coils.
Old 06-25-2014, 03:53 PM   #25
FloridaBRZ
That was why I was considering Tein. They are rebuildable in the us.
Old 06-25-2014, 04:06 PM   #26
Racecomp Engineering
Are coilovers even worth it for a DD that isn't going to get tracked? I want a comfortable drop and aggressive stance. I was looking at tein flex or the Cusco spec zero. But like I said, I didn't know if those choices would be wasted on a non tracked car.
If you're planning on lowering your car more than an inch, I would recommend coilovers.
You can do well with good ride quality and good performance with just springs on stock shocks with the few springs that lower an inch or less, but past that point there just isn't enough bump travel to work well on all roads/tracks.
There is a wide range of coilovers out there...some quality, some not so much (and not necessarily "better" than stock or quality springs). Depending on your goals there should be a good match for you in your price range.
- Andy
Old 06-25-2014, 04:46 PM   #27
Jive Turkey
the tuna, no crust.
Jive Turkey's Avatar
Drives: 2014 Hachiroku of the year
buy my v3's...
for a budget coil you should consider RCE tarmac 0...atleast you can get stiffer rates. the ST are pretty soft and with all that power you wont be happy. i think bilsteins are in that entry level category too, but i dont know much about them.
avoid the taiwanese stuff.
the turn in concepts coilover is called HVT. i dont know how readily available they are.
bottom line, it already seems like you're spending a lot on the turbo and etc, why would you skimp on a part of your car that i so vital to you being able to put all the power to the ground safely and not bounce around. save up a bit more IMO, or do a dedicated strut/springs (koni/RCE spring) if you want the best performance. but i'm assuming coilovers are going to be the clear winner since you want to run aggressive wheel fitment compared to stock.
Jive Turkey is offline   Reply With Quote
Old 06-25-2014, 04:56 PM   #28
CSG David
CSG David's Avatar
Decent DD status sub-1900 MSRP: TEIN Street Flex, ST Coilovers, Bilstein B14, RSR Sport-i, RSR Black-i, RCE T0
Great DD status: Penske, Ohlins, etc. Yup...pay to play.
Keep in mind we only recommend setups that we would use on our own car.
Im buying coil overs within the next 2 days i need help deciding what coil overs to Anthony7515 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 12 06-27-2014 01:00 PM
ISC N1 coil overs assbox Suspension | Chassis | Brakes -- Sponsored by 949 Racing 1 04-25-2014 01:20 PM
Stance Coil overs or BC coil overs ? tr1x5tuh Suspension | Chassis | Brakes -- Sponsored by 949 Racing 36 11-26-2013 04:13 AM
XYZ Coil overs??? Juanito08 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 4 07-31-2012 09:12 PM
