| View Poll Results: What side seal have you had a problem with | |||
| Driver's side seal problems |
41 | 47.13% |
| Passenger side seal problems |
4 | 4.60% |
| Happend on both sides |
19 | 21.84% |
| Seal problems? I ain't got no seal problems! |
23 | 26.44% |
| Voters: 87. You may not vote on this poll | |||
#15 |
Drives: 2013 Asphalt 6spd
I noticed my passanger side was doing it not long after I bought it at 7.5k miles. I have digi film tint from toyota. I disabled the window indexing to keep it from getting worse, but when I roll the windows back up after having it down, it always pulls the seal with it. With the indexing disabled, and the seal out of place it is a little more difficult to close the door, so I try to reseat before closing the door. I might have to put a filler strip in like you did and see how well it works.
| The Following User Says Thank You to Target70 For This Useful Post: | suaveflooder (06-24-2014) |
#16 | |
![]() Quote:
I agree with you in the sense that it doesn't happen to all cars, but we are pretty much at a 50/50 failure rate and I know of at least 3 more people on this forum that are having the problem right now that haven't voted or commented. Thankfully this is not a mass hysteria thing like the DI seals. This one tends to be more of an annoyance than anything else. Once again, I have no intention of getting this "fixed" again as it's not a major issue to the car and I would LOVE to keep the car out of a technicians as much as possible I haven't heard of many people actually having those seals leak…they just look funny, lol. I'm of the opinion that it's just a bad design. There are plenty of frameless windows that don't have issues. This one just happend to be designed poorly.
#17 | |
#18 | |
Drives: '13 FRS - STX
Folding? Leaking? Deteriorating? |
#19 |
mine got so bad that at one point it began to bunch up and stop the window before it was all the way up. I read a post saying that that the bunching cause it to start leaking. I don't know the semantics about if being a failure, problem, or defect, I just wish it wouldn't do it. my 240 has frame less windows, now 22 years old on original window seals with no leaks or warping, so it can be done.
#20 |
Drives: Whiteout FRS
I got them on both sides. Got my dealership to order me a pair of brand new window seals under warranty to get it fixed.
#21 |
Drives: Raven Manual FRS
happens to my car every time it rains. when I get in the car, close the door and the window goes up, I have to reach up and grab the edge of the seal and pull it back down on the inside.
I need to get that by the dealer and have it replaced before it starts tearing or leaking. |
#22 |
Drives: Raven FR-S 6M
I don't see any poles in here but I will fill out the poll.
“The World is Flat”
[||•]=(86)=[•||] |
#23 |
#24 | |
My seals both folded at one point or another, passenger side is currently folded driver side fixed itself, no problems.
#25 | |
Visually it doesn't concern me because it's not seen with the windows up. I'm looking for solutions rather than replacement because my car is very close to being out of warranty and this is my second one to be replaced. Long term concerns are, of course, leaks. Second the window motor. After it folds the first time, if I don't put it back the window "struggles" a little to get closed again. While it wouldn't be an immediate issue, or even an issue at all for all I know, it is still a concern. |
#26 |
Drives: Scion FR-S
Like many problems with this car, I believe that the problem will arise over time for most users. See leaking tail lights and crickets as a good example.
I've tried reinforcing with curled up tape, or silicone adhesive, didn't help. I've recently resorted to using a silicon lubricating spray every wash or so, which seems to help. Problem is very dependent on outside temperature. |
| The Following User Says Thank You to kodyo For This Useful Post: | suaveflooder (06-25-2014) |
#27 |
Drives: 2013 DGM BRZ Ltd
My drivers side seal did this and was replaced under warranty, I use gummi pflege stift on them now and have not had the problem come back.
| The Following 2 Users Say Thank You to raptor87 For This Useful Post: | suaveflooder (06-26-2014), unsurety (06-28-2014) |
#28 |
Drives: 2013 BRZ (gone) 2016 Ford Fusion SE
No seal problems as of yet. I've had the car since March. The windows squeak like a dying animal when they're a little wet and you roll them up or down. Nails on a chalk board.
| The Following User Says Thank You to Bobblehead For This Useful Post: | suaveflooder (06-26-2014) |
| Driver's side window seal/door seal | KAB-FRS | Issues | Warranty | Recalls / TSB | 255 | 01-01-2021 07:09 PM |
| window seal? | ravenblackfrs | Issues | Warranty | Recalls / TSB | 3 | 01-29-2014 06:12 PM |
| Drivers Side Window (Not Seal) | Mister | Issues | Warranty | Recalls / TSB | 20 | 12-16-2013 03:56 PM |
| Window Seal Leaves Marks on Windows | AsianStyle | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 13 | 09-22-2013 04:28 PM |
| Does anyone else have this problem after lowering their BRZ? (pics included) | Calin | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 25 | 01-28-2013 12:59 AM |
