Old 06-11-2014, 08:42 AM   #141
Toyota John
Calle Atun
Drives: 13 FRS, 93 Mr2, 85 ae86
I was able to get my trims down to + or - 5% which is way better then what it was stock. Seems to have fixed my driveablity problems with the lean spot transitioning from closed loop to open loop after shifting. I have more work on my MAF scale to get the trims lower but at least now I don't have to use my custom F'ed up fuel map I made to minimized the transition area. I found the IAT compensation map that you said to disable for logging. What are the other compensation maps I should disable while MAF logging? Also what is the best way to blend closed loop and open loop MAF scales together?
Toyota John is offline   Reply With Quote
Old 06-11-2014, 11:07 AM   #142
Kodename47
Kodename47's Avatar
Drives: UK GT86
Other table worth doing is the Engine Load Compensation table.
The easy way to do the OL and CL scale is to do the OL part 1st and then use the new scale from that and put it as the CL original MAF scale. If you use the cut off voltage option to ensure that there's no cross over then it works fine. You can also use the spreadsheet I posted a while back: MAF Smoothing Spreadsheet.
.: Stealth 86 :.
Kodename 47 DJ:
Old 06-11-2014, 11:59 AM   #143
phrosty
Originally Posted by Kodename47 View Post
Discount any data that has a low count, I would look for at least 15-25 minimum for reliable data.
What I do is count the number of seconds spent in that MAF bin. Also, because I lerp the correction between two bins (I believe vgi's tool does this too), if 90% of the correction goes in bin A, 10% in bin B, the bins will also get the same proportion of time associated with them, so A would get 90% of 0.1 seconds and B would get 10% of 0.1 seconds, etc.
phrosty is offline   Reply With Quote
Old 06-11-2014, 04:04 PM   #144
Toyota John
Calle Atun
Ok so I would run the closed loop first, than open loop and then with the finished open loop add that to the closed loop scale and run closed loop again? Would there be any benefit to disabling the accel enrichment for the logging as well?
Old 06-12-2014, 02:18 AM   #145
Kodename47
Kodename47's Avatar
Drives: UK GT86
Go and do one log and collect all the data you need for both OL and CL. Do your OL scaling 1st, then paste the corrected MAF scale from that into the current MAF scale for the CL screen. Just make sure the areas that are being corrected don't overlap by using the MAF Voltage Maximum parameter.
I've not diabled the accel enrichment, the idea is to be smooth with the pedal for the CL and you filter out excessive trims in OL which means that there is no need to.
Feel free to upload a log and I'll put it through to see how it compares with your result. Sometime the key is to not use too many filters to check over your data, use the range of graphs to visualise it and then re-run the log and reduce the filters to suit.
.: Stealth 86 :.
Kodename 47 DJ:
Old 06-16-2014, 10:22 AM   #146
Toyota John
Calle Atun
Ok seems to be good now. Trims are under 3%+or-. Most are +or-1%. The +or- 3% seems to show up under throttle changes which I think is normal? Thank you for your help this fixed my lean spot transitioning from closed loop to open loop and the after shifting stumble is gone. Good work on the MAF scaling program @vgi. Thank you for your hard work.
Old 06-25-2014, 01:51 AM   #147
troek
troek's Avatar
Drives: 2012 Toyota 86
i noticed my LTFT is -7 to -10 at idle, so im gona give this a try. very useful thread.
troek is offline   Reply With Quote
Old 06-25-2014, 03:12 AM   #148
Kodename47
Kodename47's Avatar
Drives: UK GT86
Note which injectors are at use at idle. It changes depending on the coolant temperatures which may impact the results.
.: Stealth 86 :.
Kodename 47 DJ:
Old 06-25-2014, 03:14 AM   #149
troek
troek's Avatar
hmm i didnt have that channel selected to data log. this is at idle while fully warmed up(190 coolant temp).
Old 06-25-2014, 03:32 AM   #150
Kodename47
Kodename47's Avatar
Drives: UK GT86
Here's an idle log I did a while back:
FYI:
1 - PI
2 - DI
3 - Both
.: Stealth 86 :.
Kodename 47 DJ:
Old 06-25-2014, 03:58 AM   #151
troek
troek's Avatar
cool, thanks. so after 62 degrees it stayed at DI?
when i try to load a datalog with VGIs program, i get this error "Error parsing number at line 2: java.lang.NumerFormatException: For input string: "OpenFlash Data File 1"
i logged all the channels quoted in the OP. is my log the wrong file format?
Old 06-25-2014, 04:01 AM   #152
steve99
Drives: FT86
The first 2 or 3 lines of the log file contain some rubbish just delete them just leave the headers for the data like ol/cl rpm mafv
ect
Vgi program does no like it :-)
Old 06-25-2014, 04:02 AM   #153
Kodename47
Kodename47's Avatar
Drives: UK GT86
Try removing the rows above the column headers.
.: Stealth 86 :.
Kodename 47 DJ:
Old 06-25-2014, 04:36 AM   #154
troek
troek's Avatar
i read that on the usage tab, and for some reason it didnt register until you mentioned it. thanks!
AFR in Closed Loop Toyota John Software Tuning 39 07-07-2019 08:26 AM
BRZedit Fuel Trims, Closed to Open loop transiton mad_sb Engine, Exhaust, Transmission 32 08-06-2015 03:14 AM
Notes on injector / maf scalining using full time open loop mad_sb Software Tuning 40 03-03-2014 05:49 PM
Screencast: closed loop boost control with RaceRom jamesm Software Tuning 2 02-10-2014 02:23 PM
Screencast: experimenting with full-time closed loop fueling jamesm Software Tuning 2 12-27-2013 10:19 AM
