Old 06-09-2014, 01:45 PM   #519
ATL BRZ
TEQSPORT Brand Manager
ATL BRZ's Avatar
Drives: '24 GR86 + '16 FR-S
You guys too busy to announce your 10% off Tarmac 2 sale on here instead of just Facebook?
Old 06-09-2014, 02:16 PM   #520
Racecomp Engineering
OOPS !
yes , rare opportunity. 10% all TARMAC 2 coilovers while supplies last.
Lurkers can stop lurking and grab your wallets !
Myles
The Following 3 Users Say Thank You to Racecomp Engineering For This Useful Post:
ATL BRZ (06-09-2014), fooddude (06-09-2014), Scottemad123 (06-09-2014)
Old 06-10-2014, 07:57 PM   #521
Hippophobia
Drives: 2013 Whiteout FRS
So, I probably missed it in here somewhere, but I have the Tarmac 0's and they are maxed in the front and wish I could go slightly more. I have about 25 threads in the rear and I love the look of the rear.
In order to match the front to the rear, what do I need to do? Buy front top mounts in order to lower the coil overall?
Hippophobia is offline   Reply With Quote
Old 06-10-2014, 09:40 PM   #522
ka-t_240
OOPS !
Myles
Got mine Yesterday!
ka-t_240 is offline   Reply With Quote
Old 06-11-2014, 10:29 AM   #523
Lowering front top mounts would do it.
- Andy
Hippophobia (06-11-2014), mfbmike (10-13-2014)
Old 06-23-2014, 06:54 PM   #524
ka-t_240
Are there any other adjustment options for the top on the Tarmac2, or is the Allen Key that comes with the only option. Looking to see what other people are using? Looking for something less "loseable". I see the KWV3 have an adjuster knob, does that work with these?
Old 06-24-2014, 01:34 AM   #525
ATL BRZ
ATL BRZ's Avatar
Fun times ahead!
The Following 3 Users Say Thank You to ATL BRZ For This Useful Post:
fooddude (06-24-2014), stoked_on_spool (03-08-2016), whataboutbob (06-24-2014)
Old 06-24-2014, 01:39 AM   #526
whataboutbob
AutoX-10/10ths every run
Originally Posted by ATL BRZ View Post
Fun times ahead!
Nice setup, looks familiar.
Build thread:Here
The Following User Says Thank You to whataboutbob For This Useful Post:
ATL BRZ (06-24-2014)
Old 06-24-2014, 01:22 PM   #527
We sell those adjustment knobs, which I have sitting on my car, but are prone to pop out if you leave them in. OTHERWISE……..most use the 2mm allen key that comes with the kits.
Myles
Old 06-25-2014, 01:01 AM   #528
fooddude
Drives: 04 Toyota Tacoma Prerunner Reg Cab
@Racecomp Engineering:
Would setting up settings for the T2's be difficult if one had an LS3 swap? ..If the LS3 swap only added 50'ish extra pounds in the front over factory (probably the same amount of additional weight anyways (if not less) as an everyday intercooled FI kit for the FA). Would your standard T2 settings in the manual still work decently and/or at least be a good starting point for dialing in settings?
I am thinking of maybe getting an LS3 swap 10-15 years down the road..when the FA engine gets a bit older, past 100k miles and/or blows up.
fooddude is offline   Reply With Quote
Old 06-25-2014, 12:54 PM   #529
ATL BRZ
ATL BRZ's Avatar
As she sits now on the T2's after dialing in the ride height and alignment.
Old 06-25-2014, 01:19 PM   #530
Wouldn't be much trouble to adapt the set-up.
- Andy
Old 06-25-2014, 01:20 PM   #531
That is such a good looking car.
- Andy
ATL BRZ (06-25-2014)
Old 10-13-2014, 11:13 AM   #532
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Anyone running the Beatrush Camber plates with Tarmac Zeros?
http://www.ft86speedfactory.com/beat...ounts-871.html
Do I still need the conical washer?
Are those Beatrush plates no-raising, or if they raise how much?
Thanks.
Racecomp Tarmac II Clubsport coilover JoeBoxer Suspension | Chassis | Brakes -- Sponsored by 949 Racing 47 11-16-2013 11:02 PM
Tarmac Zero Coilovers Specs? tintumz22 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 18 06-13-2013 11:26 PM
KW CLUBSPORT COILOVERS W/ FREE SHIPPING FOR THE SCION FR-S/SUBARU BRZ!!! NJA Brakes, Suspension, Chassis 7 03-30-2013 08:26 PM
Wheel Directory: Enkei ES-Tarmac 16x7.0 +45 quik1987 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 09-12-2012 12:24 PM
Toyota 86 Tears Up Tarmac at 2012 TAS (TRD, N1, HKS, Up Garage Models) + LFA Roadster knoxviue FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 35 01-20-2012 01:44 AM
