#519 |
TEQSPORT Brand Manager
Drives: '24 GR86 + '16 FR-S
You guys too busy to announce your 10% off Tarmac 2 sale on here instead of just Facebook?
#520 |
OOPS !
yes , rare opportunity. 10% all TARMAC 2 coilovers while supplies last. Lurkers can stop lurking and grab your wallets ! Myles |
| The Following 3 Users Say Thank You to Racecomp Engineering For This Useful Post: |
#521 |
Drives: 2013 Whiteout FRS
So, I probably missed it in here somewhere, but I have the Tarmac 0's and they are maxed in the front and wish I could go slightly more. I have about 25 threads in the rear and I love the look of the rear.
In order to match the front to the rear, what do I need to do? Buy front top mounts in order to lower the coil overall? |
#522 |
#523 | |
- Andy |
| The Following 2 Users Say Thank You to Racecomp Engineering For This Useful Post: | Hippophobia (06-11-2014), mfbmike (10-13-2014) |
#524 |
Are there any other adjustment options for the top on the Tarmac2, or is the Allen Key that comes with the only option. Looking to see what other people are using? Looking for something less "loseable". I see the KWV3 have an adjuster knob, does that work with these?
#525 |
![]() ![]() ![]() ![]() ![]() Fun times ahead!
| The Following 3 Users Say Thank You to ATL BRZ For This Useful Post: |
#526 |
AutoX-10/10ths every run
| The Following User Says Thank You to whataboutbob For This Useful Post: | ATL BRZ (06-24-2014) |
#527 | |
Myles |
#528 |
Drives: 04 Toyota Tacoma Prerunner Reg Cab
@Racecomp Engineering:
Would setting up settings for the T2's be difficult if one had an LS3 swap? ..If the LS3 swap only added 50'ish extra pounds in the front over factory (probably the same amount of additional weight anyways (if not less) as an everyday intercooled FI kit for the FA). Would your standard T2 settings in the manual still work decently and/or at least be a good starting point for dialing in settings? I am thinking of maybe getting an LS3 swap 10-15 years down the road..when the FA engine gets a bit older, past 100k miles and/or blows up. |
#529 |
As she sits now on the T2's after dialing in the ride height and alignment.
#530 | |
![]() - Andy |
#532 |
I Love custom Turbo kits
Drives: Limited BRZ
Anyone running the Beatrush Camber plates with Tarmac Zeros?
http://www.ft86speedfactory.com/beat...ounts-871.html Do I still need the conical washer? Are those Beatrush plates no-raising, or if they raise how much? Thanks. @Racecomp Engineering
| Racecomp Tarmac II Clubsport coilover | JoeBoxer | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 47 | 11-17-2013 12:02 AM |
| Tarmac Zero Coilovers Specs? | tintumz22 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 18 | 06-14-2013 12:26 AM |
| KW CLUBSPORT COILOVERS W/ FREE SHIPPING FOR THE SCION FR-S/SUBARU BRZ!!! | NJA | Brakes, Suspension, Chassis | 7 | 03-30-2013 09:26 PM |
| Wheel Directory: Enkei ES-Tarmac 16x7.0 +45 | quik1987 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 1 | 09-12-2012 01:24 PM |
| Toyota 86 Tears Up Tarmac at 2012 TAS (TRD, N1, HKS, Up Garage Models) + LFA Roadster | knoxviue | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 35 | 01-20-2012 02:44 AM |
