Old 06-24-2014, 07:29 AM   #15
campy
No rice, no life
campy's Avatar
Drives: 2013 Asphalt FR-S
How long does a bottle of nitrous even last? I feel like I would end up spending all that money, use it once, then be out.
campy is offline   Reply With Quote
Old 06-24-2014, 08:17 AM   #16
Accurate Race Shop
Accurate Race Shop's Avatar
Drives: Scion FR-S
A 100 shot or 1.00 lbs shot is one pound the bottle holds 10 pounds. On most v8 cars that is a 10 second blast way to much for our cars in my opinion. I would go about half that with our cars. In reality with a 100 shot you are going to get 3 to 4 good passes and 3 or 4 weak passes on the bottle. And the last 2 or 3 passes are not going to be nearly as good as the first few unless you heat the bottle.
Sent from my Q10
Old 06-24-2014, 08:24 AM   #17
sluflyer06
Drives: 2014 BRZ Ltd - DGM
Then you get it refilled lol. I had a buddy use it successfully many years ago on a Tiburon for all the years he had the car without blowing anything up. I have no idea what current prices are but in 2005ish I think it was somewhere close to $40 to re-fil 10lbs I think. I imagine its possibly much higher now, the prices were going up quickly.
He ran a 75shot and you may get I dunno 10 good runs out of it with a bottle warmer, can't really remember. Its not a lot.
2014 BRZ Ltd. - DGM
E30 318is trackday funday car
E46 323ci vert
sluflyer06 is offline   Reply With Quote
Old 06-24-2014, 08:33 AM   #18
Accurate Race Shop
Drives: Scion FR-S
I think the drive by wire systems will be the best for our cars. There is no red button it is all hooked to the gas pedal. When you floor it a small amount of nitrous is introduced with a fogger system. This is the setup most road course and drift cars use that run it. Again I only know of a few clubs that still allow it to be used during their events. The scca strictly forbids it and so does nasa (last time I checked).
Sent from my Q10
Old 06-24-2014, 09:45 AM   #19
Argento_FR-S
Drives: Scion FR-S
Just wanted to chime in here... I purchased the kit from the N/X test car after his car blew. Several months later I installed an FX400 8-puck clutch and hooked up the kit along with an MSD RPM window switch and an electric pressure gauge for the dash. As well as a wideband A/F meter. I have gone through 3 bottles so far with a ~75hp shot with no issues at all. Even with my car having over 45k miles on it. I'll eventually push the kit to its maximum after I purchase a stand alone fuel system and some colder plugs. I'm a touch worried about running more than a 75hp shot with the stock fuel system since the car can roughly handle 250whp on the stock fuel system. (The guy i bought the kit from said it made ~250whp/250wtq on the 100 shot) After I have everything where I feel comfortable to share with everyone I'll find a dyno and post a full install w/ dyno plots for 50hp-150hp shots in 25hp increments. Also would like to add that as of right now my car makes most mustangs and camaros cry down in Mexico...
Edit: Also should note that kit was installed at roughly 30k miles and I daily drive 75 miles each way to work.
Argento_FR-S is offline   Reply With Quote
The Following User Says Thank You to Argento_FR-S For This Useful Post:
Accurate Race Shop (06-24-2014)
Old 06-24-2014, 09:55 AM   #20
Roadcone
StreetKart
Drives: 2014 Scion FR-S Monogram
first off.. tl;dr
most people are scared of nitrous because they are too dumb to tune the car for it. people think lean wipes out motors so they jet the kits rich... rich wipes out a nitrous motor well before lean will.. its too much timing that kills them usually. I just dont want to spend 60 bucks every week or two. i'd rather have a blower since it'd cost me about 1200 to do a nitrous kit like i would want... and THEN get it tuned.
TRD|Verus Engineering|Titan7|DEZOD Motorsports|JDL Auto Design
Roadcone is offline   Reply With Quote
Old 06-24-2014, 10:47 AM   #21
sw20kosh
Drives: 2013 Black FR-S
That is incorrect. You can safely go up to 300-320 whp on pump gas.
Old 06-24-2014, 01:33 PM   #22
Argento_FR-S
Drives: Scion FR-S
This may be true, but since the wet kit pulls straight from the fuel rail supply I'm not comfortable with the pressure drop and load that puts on the pump.
Old 06-24-2014, 01:42 PM   #23
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Less than a quarter mile even if you have two of the big bottles. Hence the too soon junior line.
Old 06-24-2014, 03:31 PM   #24
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Originally Posted by stevo585 View Post
Or at least no one talks about it. That's nitrous oxide systems....
Funny that you ask being from Orlando. @jamesm tuned one successfully right there in your hometown.
Old 06-24-2014, 03:42 PM   #25
zooki
Drives: waiting on a 2021...
Wait, what? Less than a quarter of a mile? I ran a 200 shot on my Mustang and could get 5 or so(depending on ambient air temp) passes before the bottle pressure started dropping and I had to kick on the bottle warmer. That was with a 10lb. bottle
2016 4Runner Tail edition
2020 Camry 2020 RAV4
2013 Chevy 3500 4x4 Duramax
1999 Ford F250 Powerstroke, the tow rig
1969 Mustang, the fast car....(:
zooki is offline   Reply With Quote
Old 06-24-2014, 03:57 PM   #26
King Tut
NASA SpecE30 Racer
King Tut's Avatar
I saw it in a movie bro.
The Following 2 Users Say Thank You to King Tut For This Useful Post:
gramicci101 (06-24-2014), Sportsguy83 (06-24-2014)
Old 06-24-2014, 03:59 PM   #27
tahdizzle
So elite I'm 1338
Drives: WRB Subaru BRZ
I saw the same movie. No lie.
Hit it too soon and you'll run out!
The Following User Says Thank You to tahdizzle For This Useful Post:
Old 06-24-2014, 04:11 PM   #28
stevo585
Drives: White 2014 BRZ
I know he did and that guy is very happy with it. Talked to jamesm about it. He doesn't really like it in his opinion.
Which I agree boost is better.
stevo585 is offline   Reply With Quote
The Following User Says Thank You to stevo585 For This Useful Post:
