Old 06-24-2014, 02:11 AM   #141
glamcem
glamcem's Avatar
Drives: 2022 BRZ Limited
Originally Posted by jsimon7777 View Post
Lots of relatively low-mileage LSx motors out there. GMs get in crashes all the time, and there are a variety of cars and trucks that use them. The aftermarket parts support makes the twins look pitiful. Still, the only reason I'd put an LSx in my twin is if the stock motor pops, and I don't think that's likely.
^^this
There is no reason to buy $5k-6k LS3 engine brand new when you can get a cheap LS1 with the header and exhaust you're already above 400 hp anyways..
AFAIK, LS2 and LS3 engines are the stroked versions of the LS1 and LS6 (6.2lt , 6.3lt and 5.7lt respectively) and since the LS1 and LS6 engines have thicker walls they're pretty much bullet proof
if you insist here you can get a new LS3 engine (with the header and tune you gain about 30-40 whp on top of that) GM performance also sells upgraded cam version (still under GM warranty) for $400 more
http://www.gmperformancemotor.com/parts/19301326.html
and the "hot cammed version"
http://www.gmperformancemotor.com/parts/19301358.html
glamcem is offline   Reply With Quote
The Following User Says Thank You to glamcem For This Useful Post:
fooddude (06-24-2014)
Old 06-24-2014, 02:37 AM   #142
fooddude
Drives: 04 Toyota Tacoma Prerunner Reg Cab
Thx for the links.
According to the Vorshlag build, would an LS2/3+ be required though because the Twin uses ETC? (Unless of course, you swap the LS1 intake manifold/tb with an LS2; or the other way arnd and convert gas pedal to cable).
So... How much are Used engines LS2/3 be? (Or other LSx engines that use an ETC and is at least 430hp)
Any other recommended best bang for the buck ETC LSx's?
How much do you think the entire swap will be after everything is said and done?? (all parts, kit; but me doing all the labor).
A lot mention it'll only be $8k-12k for the entire build after the price of the car itself. Is it me or does this pretty cheap, attainable and inexpensive for the regular non-rich folk? You think it's really possible to do for $10k'ish? I may have to really consider doing this in the future, if it's really this cheap to do.
That YT video of that green miata with the LS1 beating/hanging with a Ferrari is pretty enticing...and, that was only a 360hp LS1!! ...now imagine that with a 430hp LS2/3!! (I know, the twin is a bit heavier...but it's still pretty light, sub 3k lbs and maybe only 300-400lbs more and it'd be 430hp).
fooddude is offline   Reply With Quote
Old 06-24-2014, 02:59 AM   #143
fooddude
Are there any ft86club member build threads that have or are installing an LSx?
I know that red rocket bunny guy with the vsxx wheels mentioned an LS; but I think it only has a body kit and wheels so far. Any others?
I'd love to see one done in Sleeper/Ninja form -absolutely no body kit, pretty much stock exterior, only just modest 17" wheels and coilovers. That's def the way I'd do it
Old 06-24-2014, 03:49 AM   #144
fooddude
..the only reason I'd put an LSx in my twin is if the stock motor pops, and I don't think that's likely.
That sounds like a good, realistic, financially smart plan - New LSx swap when the engine gets a little older, maybe in 10years, high/100k miles or blown engine...whichever comes first
Old 06-24-2014, 05:34 AM   #145
cf6mech
Drives: FRS Silver LS1 swapped.
Yes me.
cf6mech is offline   Reply With Quote
Old 06-24-2014, 09:38 AM   #146
eikond
Wish Nissan made one
eikond's Avatar
Drives: '13 WRB BRZ Premium
As this topic continues to be discussed, please keep in mind that you can't just look at the cost of the shortblock motor. You'll need a transmission (LSx needs t56 which will run up to $3000), upgraded driveshaft, rear ends and axles, fuel pump, electrical, cooling, etc..
Just remember you can't talk about an engine swap and only consider the cost of the engine.
eikond is offline   Reply With Quote
Old 06-24-2014, 12:03 PM   #147
Reaper
in orbe terrum non visi
Reaper's Avatar
Drives: violent
ive posted three times about viscous performance.
Sent from my SAMSUNG-SGH-I747 using Tapatalk
Old 06-24-2014, 12:12 PM   #148
glamcem
glamcem's Avatar
Thx for the links.
if you're really serious about this you can start looking at ls1tech, corvette, camaro and GTO forums.. you would be surprised how many totaled GTOs are out there but then again I am not sure if it really worth the efforts since all things combined (motor, drivetrain, wiring, ecu, labor etc) it won't be cheap
Yes and all those things cost a lot of money, and how well the car responds after all that is also questionable since the cooling and many other things should be factored also..
I would prefer the new TR 6060 (Tremec) over the all transmissions since they are more robust and new one costs about $3k, I have seen a few used trannies around $1500 a while ago
http://www.summitracing.com/parts/nal-92236241
Old 06-24-2014, 12:14 PM   #149
glamcem
glamcem's Avatar
to the OP if someone is really serious about the bang for the buck (in terms of power) buying a used Corvette makes a lot of sense,
Old 06-24-2014, 12:19 PM   #150
Reaper
Reaper's Avatar
Drives: violent
There are two ls budget options ive done over the years.
The little 4.8 v8 out of gm vans and some trucks. Ive bought these for under 500 $ before. Its capable of holding over 500hp on boost but more importantly with a stock cam from a bigger ls and intake and exhaust manifolds this junkyard motor can make over 450hp on the cheap.
My second favorite engine is the LQ9 (Or lq4/6) its a cast iron ls1 and 6.0l. Rated somewhere around 350hp. Ive bough these low mileage for 2, 000 $ with wiring harness and they make well over 400hp with a cam shaft and a manifold. They also do well with ls6 heads and can be built for 550hp with just hand me down parts from other ls engines. The lq4/6 motors have different compression ratios depending on if you want to build na or turbo.
The Following 2 Users Say Thank You to Reaper For This Useful Post:
fooddude (06-24-2014), SkAsphalt (06-24-2014)
Old 06-24-2014, 03:45 PM   #151
fooddude
Thanks captain obvious, lol jk ..I am sure we all already know there is much more components that needs to be changed.
Old 06-24-2014, 03:48 PM   #152
Gilluspe
Drives: 2013 FR-S/ 1986 RX-7
Send a message via AIM to Gilluspe Send a message via MSN to Gilluspe
if i was going to swap engines in a twin, Would definitely be Rotary. about 250hp n/a 13b. the car just doesn't sound enough like a weed wacker on steroids right now
Gilluspe is offline   Reply With Quote
Old 06-24-2014, 03:48 PM   #153
fooddude
@glamcem @Reaper:
If I were to do it, I would most likely go the Vorshlag route and go for their recommended tranny that fits with this chassis (ie: bolt on and no need for extreme chopping/fabbing of firewall/tunnel). They are developing headers and a driveshaft too. And of course, the other needed bits - accessories, cooling, ac, heater, fuel delivery, wiring, ecu, etc., etc., etc.
Old 06-24-2014, 04:00 PM   #154
fooddude
What the difference between the E-Rod LS3 and regular LS3? Why is it so much more, yet the same hp?
And what's the diffs between all the different LS327's? ..480, 515, 525... just the camshafts?
Are LS1 and LS2 the outdated and old LS's and not sold brand new anymore?
Is there such a thing as LS4, LS5, LS6?
What's an LS6?
Honestly...if someone/I could even afford an LS swap in the first place, I'd prolly just get a brand new LS3...for peace of mind you're getting a brand new engine that needs no further fiddling with, no missing parts, no need for rebuild, etc. Getting a used engine at the junker is still a little bit of a gamble, how well it works, mileage, how well it was maintained (or lack thereof) and any damages or missing parts.
After the "Ferrari" 86, we now have the "Porsche" BRZ Nardi330 Scion FR-S / Toyota 86 GT86 General Forum 30 07-06-2013 11:41 AM
Portland people meet with Seattle area people before going into ForumFest 2013? stockysnail Northwest 24 06-18-2013 06:19 PM
First spotting in the wild! pr0j AUSTRALIA 3 07-22-2012 03:48 AM
Official: The new Ferrari V12 Ferrari Berlinetta Levi Other Vehicles & General Automotive Discussions 27 03-07-2012 11:31 PM
First Ferrari, now Porsche??? zoomzoomers Other Vehicles & General Automotive Discussions 33 02-26-2012 11:45 AM
