go_a_way1
Old 06-23-2014, 10:12 PM   #603
spitz
spitz's Avatar
Drives: '13 SWP BRZ-L
Looks like I should spend more time at the seat
spitz is offline   Reply With Quote
Old 06-23-2014, 10:38 PM   #604
sw20kosh
Drives: 2013 Black FR-S
Originally Posted by CSG David View Post
You mean this? JRSC + stock suspension, tires, Winmax W4 brake pads, and RT700 brake fluid.
Have you tried going for a bit more power than carb legal tune?
Old 06-23-2014, 10:39 PM   #605
nelsmar
People have difficulting believing me when I say that you have a power gain from idle on up.
Do you happen to have a dyno comparing the REALLY low RPM ranges? I know it's not typical due to lugging, but it's nice to have
Originally Posted by enivid View Post
Rotrex says : "place the oil canister with the cap below or level with the supercharger's shaft"
oh HAH I guess i got that backwards!
My flickr - Canibeat
Local magazine scout
Old 06-23-2014, 11:46 PM   #606
D K
Stig's dark passenger
They recommend it so oild doesnt drain into the charger but it really doesnt matter.
The scavenge pump within the charger will pump all the oil out in a matter of a few revolutions.
Mine is high mounted and Oscar said its perfectly fine.
D K is offline   Reply With Quote
Old 06-24-2014, 03:39 AM   #607
SPCorBUST
SPCorBUST's Avatar
Just read all 28 pages. I didn't see many dyno sheets, so I don't have a firm understanding of the upper limits for the kit. I am really happy about there being a lack of issues with this kit, but I'm probably only going to purchase this for the CARB (and piggy) protection this kit can provide.
What type of numbers might this kit run with the smaller pulley, a good source of e85 (well, e82-84, typically), a 265 pump and 550cc injectors?
SPCorBUST is offline   Reply With Quote
Old 06-24-2014, 05:45 AM   #608
CSG Mike
CSG Mike's Avatar
Originally Posted by bacon_cheese_beer View Post
i dont know anything about guages.
http://www.evasivemotorsports.com/mm...ct_Code=P3FRXU
if i purchase this unit, will it be just plug and play? what will it measure exactly? thanks in advance.
I'd recommend you get an AIM Solo DL instead. It costs more, but logs, rather than being just a display that stores peaks.
Rumor has it CSG may be doing a private group buy in the near future.
bacon_cheese_beer (06-24-2014), spitz (06-24-2014)
Old 06-24-2014, 05:46 AM   #609
CSG Mike
CSG Mike's Avatar
I don't know with a smaller pulley, but I can confirm that with a stock pulley, E85, cat deletes, and a retune, the kit will make ~325whp, and is clutch limited. The next limitation would be the pump, and THEN possibly injectors.
The Following 3 Users Say Thank You to CSG Mike For This Useful Post:
*LongFella (06-25-2014), CxG (04-03-2018), SPCorBUST (06-24-2014)
Old 06-24-2014, 05:47 AM   #610
CSG Mike
CSG Mike's Avatar
Originally Posted by spitz View Post
Has anyone driven with the SC on an otherwise completely stock suspension'ed car (with brake pad and tire upgrades) at the track? I can't recall whether CSG's car already had their suspension setup when they put the kit on their car. I'm curious as to how you felt the car w/ the kit performed.
You can power-oversteer pretty much at will.
spitz (06-24-2014)
Old 06-24-2014, 12:13 PM   #611
SPCorBUST
SPCorBUST's Avatar
That's great! It's not far off from where I'm at now then. I put down 330 on Bill's Mustang with the C38 on e60, stock clutch, stock exhaust except for catback, 265 pump and 550cc injectors.
My clutch seems to be holding up fine under normal WOT shifting (for now).
Any speculation on psi with the forthcoming smaller pulley?
Sent from my SGH-M919 using Tapatalk
Setup 3: JR C30, DW 700, Grams 265, 3bar, FlexFuel, Moto-East
Setup 4: JR C30 HBP, DW 700, Grams 265, 3bar, FlexFuel, Church
Setup 5: JR C30 HBP, DW 700, DW 300, 3bar, FlexFuel, Delicious, Built Motor
Setup 6: JR C30 HBP, DW 700, DW 300, 3bar, FlexFuel, Delicious, Closed Deck Built Motor
Old 06-24-2014, 01:17 PM   #612
CSG Mike
CSG Mike's Avatar
Psi is linear with supercharger RPMs. If you increase RPMs 10%, you can increase a 10% in psi.
I don't like using Psi as a measurement, because it tells you nothing of actual flow, or how much air mass is going into the engine.
Old 06-24-2014, 02:02 PM   #613
CSG David
CSG David's Avatar
The desire for power is subjective. Consistent power works better for our application. While numbers are great to visualize the limitations, the CARB tune is the product of testing in many different environments (weather + tracking) that have produced no problems. In other words, while the common habit is to retune for the proper elevation changes, temperature, and application, the CARB tune already covers all of that.
On another note, it's great to troll people with a CARB legal setup. I mean, BRZ #1 had zero ECU and engine mods done to it too.
The Following User Says Thank You to CSG David For This Useful Post:
racecaresuaceb (07-07-2014)
Old 06-24-2014, 03:37 PM   #614
Venator
Venator's Avatar
Drives: Asphalt FR-S
So are you saying that the carb tune is the better way to go?
And Jezza spake unto them and proclaimed that he who shall be last, shall be sideways and smiling.
Venator is offline   Reply With Quote
Old 06-24-2014, 05:29 PM   #615
CSG Mike
CSG Mike's Avatar
If you're not going to get any other bolt-ons? Yes.
Old 06-24-2014, 05:43 PM   #616
spitz
spitz's Avatar
I'd like to be on this when it happens.
Jackson Racing Rotrex Supercharger System Info and Discussion Jackson Racing Forced Induction 827 04-06-2020 05:56 PM
Jackson Racing Supercharger Press Release and Info CounterSpace Garage Forced Induction 110 01-03-2017 10:04 PM
Jackson Racing supercharger NoppyNop Forced Induction 241 06-26-2014 04:05 PM
Jackson Racing Supercharger Pre-Order Sale, $200 off! Xero-Limit Forced Induction 2 03-05-2014 05:14 PM
