Old 06-22-2014, 06:26 AM   #29
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
What happens (if anything) to the front/rear bias with these fitted?
Nose wheelie
Fizz is offline   Reply With Quote
The Following User Says Thank You to Fizz For This Useful Post:
Captain Snooze (06-22-2014)
Old 06-22-2014, 06:28 AM   #30
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
^lol
Old 06-22-2014, 09:44 PM   #31
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
Probably none...
I got these off a WRX owner. For the GD Impreza, the front caliper for Wilwood are the same size, diameter, and sweep between a GD WRX, and the FRS/BRZ. On paper, the two kits are the same..
The brakes felt great on the WRX (he had Endless front, Rotora rear), I don't anticipate any issues with bias using street pads. May change when at the track, that's why I will play with compounds later on.
-alex
Old 06-22-2014, 09:46 PM   #32
mav1178
mav1178's Avatar
Originally Posted by toms2jz View Post
as far as the pads go, you have to use the endless pads i did my research and theres no way around it.
@toms2jz look at my most recent post above, you can get other pads as long as the Endless pad size is provided.
I originally wanted Winmax but they are 6-9 months out for this custom size.
-alex
Old 08-14-2014, 12:15 AM   #33
mav1178
mav1178's Avatar
New brake lines + brake install (finally)
(I am skipping several steps in this last part. I am assuming you will know how to safely remove a brake line with a flared wrench, also assuming you know how to remove the stock brake calipers & rotors)
Finally got around to installing the calipers this week. First, a complete picture of all parts ready to go on the car + the brake lines.
It should be noted that I ended up using a set of Goodridge lines sourced from @FRSport.com
First to be installed (after removal of stock rotors and calipers) is the caliper adapter bracket. There's a couple of 10mm hex bolts that secure the bracket to the spindle, as well as the caliper to be bracket.
The rotors are next to go on. The calipers are then bolted on, then the pads inserted, then the pad retaining clip. It is a multi-step process but fairly straightforward.
Brake lines are also bolted on at this time.
After install the calipers are bled, starting from the rear to the front. I went RR/RL/FR/FL in sequence.
With Work Wheels on:
-alex
P.S. pads broken in but I will wait a few days before posting initial impressions of setup. Definitely stops more aggressive but initial pedal feel improvement can also be attributed to stainless brake lines.
The Following 3 Users Say Thank You to mav1178 For This Useful Post:
FRSport.com (08-15-2014), fstlane (04-08-2015), ill86 (02-17-2015)
Old 08-14-2014, 12:54 AM   #34
CSG Mike
CSG Mike's Avatar
Those rotors are so pretty.
Old 08-14-2014, 12:27 PM   #35
jumbaco
jumbaco's Avatar
Drives: FD
damn, looks awesome!
jumbaco is offline   Reply With Quote
Old 08-15-2014, 01:05 PM   #36
FRSport.com
FRSport.com's Avatar
Drives: Scion FR-S Subaru BRZ
Send a message via AIM to FRSport.com
WOW! Quality build you got there. Blue and Gold looks great too
FRSport.com is offline   Reply With Quote
Old 04-08-2015, 06:56 AM   #37
Metabrz
001 of 012
Metabrz's Avatar
Drives: MY12 NZDM Subaru BRZ "BRZ001"
Bump
Any updates on this performance wise. How do they go at the track and any further comments on f/r bias?
TIA
BRZ001: Peace Love and Wheelies @metabrz on IG
Metabrz is offline   Reply With Quote
Old 04-08-2015, 01:19 PM   #38
mav1178
mav1178's Avatar
The pads (PMU HC+) are pretty good, but it's not the best for the type of driving I do now which is probably 60-70% track. I've ordered Winmax W5 and those are scheduled to arrive before June.
No issues with bias, at the track they have performed well with no issues. Probably the only "problem" I have with these is that they're expensive from a parts replacement perspective, Endless rotors are almost twice the price of replacement rotors for the more popular AP Sprint kit for our cars.
-alex
Metabrz (04-09-2015)
Old 04-09-2015, 05:22 AM   #39
Metabrz
001 of 012
Metabrz's Avatar
-alex
Thanks, I am considering the AP kit and an Endless kit, seems your experience with consumables matches my research to date.
Project Mu, Stop Tech, Endless + more Brake Upgrades! Speed Element Brakes, Suspension, Chassis 390 10-11-2015 11:48 AM
Endless Brake Pads yomchi1989 AUSTRALIA 18 03-03-2014 07:07 PM
Front Brake Caliper Piston Rebuild? smbstyle Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 0 10-17-2013 06:18 PM
APR CF Brake Duct + 5Axis kit install? jeffs42885 Cosmetic Modification (Interior/Exterior/Lighting) 12 08-18-2013 11:30 PM
Custom Third Brake Light Install (incl. Pics) Skorov AUSTRALIA 14 07-27-2013 05:04 AM
