Old 06-16-2014, 06:52 PM   #15
Astroboy
Astroboy's Avatar
Drives: None
Originally Posted by nos145 View Post
So I've looked around not haven't found anything similar on our forums, therefore I decided to do a quick write up.
Car: 2013 FRS
Odometer reading: 2200 km
Transmission: Automatic
Issue:
Engine knock sound in the range of 2000-3000 RPM in 3rd/4th gears (loudest points) when engine is warm.
The AC was off at all times.
No check engine light at all.
This issue is most evident when the car is in DRIVE (i do not know why, but its not as pronounced when using paddle shifters) and it is in 3rd or 4th gear in the range of 2000-3000 RPM, most evident at 2500 RPM.
To replicate the issue I usually go onto a slightly sloped road and get the car to aforementioned gear/rpm ratio.
The noise is definitely a knocking sound. If i hold it in that gear/RPM it just keeps knocking away.
This issue first arose at about 700-1000 KM. I had just fueled up at Shell (93 octane) gas station and went on the road. It was so bad that I could hear it over music playing. At the time I thought it was a bad batch of gas. I drove for about 50km and after I got home and let the car sit for 10 minutes and started it again the sound wasn't there.
This happened again 2nd time at about 2000 KM. This time I had different fuel (costco 91 octane) and I've went about 450 km on the duel (was 3/4 empty). Therefore I figured that the fuel is not the issue.
I decided to take it to the dealer today and i managed to replicate the issue on a small scale (the knocking wasn't at it's loudest) but the mechanic agreed that there was an issue. They have ordered new high pressure fuel pump for me and will install it in a week.
On the drive back it started knocking pretty loud again.
It should be mentioned that I've had rough start issue as well about two times since I got the car.
I've found similar issue on Australian GT86 forums:
Here is the link to the thread if anyone is interested: gt86 aussi forums /forum/f16/engine-pinging-rattle-noise-under-acceleration-953/
So has anyone else here experienced this issue and does anyone know what the hell this is?
I highly doubt this is a fuel pump issue as I have 0 crickets under my hood, but from the part order I saw the dealership put in that's the excuse they used.
Did your car by any chance vibrate from the passenger side?
Sent from my LG-D800 using Tapatalk
Astroboy is offline   Reply With Quote
Old 06-22-2014, 02:15 AM   #16
nos145
Cognite
nos145's Avatar
Drives: 2013 Whiteout FRS
no vibrations sorry
vibrations are usually bad :O
nos145 is offline   Reply With Quote
Old 06-26-2014, 06:18 PM   #17
Astroboy
Astroboy's Avatar
Drives: None
no vibrations sorry
Misfire maybe?
Old 07-02-2014, 09:51 PM   #18
Margovincent_22x
Margovincent_22x's Avatar
Drives: Lightning Red BRZ MT Limited
Have the same issues and followed almost all types of fix but still popping.
I din the Seals, spark plug, coil pack, port injector, sensors etc... the only thing left is to change the DI but its too expensive for me.
Margovincent_22x is offline   Reply With Quote
Old 06-30-2015, 04:15 PM   #19
microbionic
microbionic's Avatar
Drives: 2013 Subaru BRZ
any resolve?
microbionic is offline   Reply With Quote
Old 07-01-2015, 04:39 PM   #20
Brett
First 86
Brett's Avatar
Drives: Whiteout MT FR-S
Originally Posted by microbionic View Post
any resolve?
Sort of: I bought a new GTI, but that's a whole other thing
Not really. It continued to do it, but it didn't seem to harm anything. I realize this is not really a good fix, but turning up the radio a bit seemed to at least help me not get irritated when it happened.
Good luck!
Brett
Don't shop, adopt!
Brett is offline   Reply With Quote
Old 07-01-2015, 05:26 PM   #21
microbionic
Good luck!
Brett
Lol..... Im thinking I got me some rod knock in my brz... its at the dealer now... @50k miles...no word back for 2 days... the torture
Old 07-01-2015, 05:34 PM   #22
Astroboy
Astroboy's Avatar
Drives: None
Any mods?
Sent from my LG-D850 using Tapatalk
Old 07-01-2015, 05:45 PM   #23
microbionic
Any mods?
Fumuto valve and a k&n drop in
Old 07-01-2015, 06:25 PM   #24
Astroboy
Astroboy's Avatar
Drives: None
That's it D=
Are you sure it's not a motor mount?
The Following User Says Thank You to Astroboy For This Useful Post:
microbionic (07-01-2015)
Old 07-01-2015, 06:36 PM   #25
microbionic
That's it D=
No not at all... but listening to the videos of other brzs and wrxs with that issue... it sounds alarmingly simular... I will post back what I hear. They said they should know more thursday...and yes... thays all my wife would let me get I was one of the first people to get an oem arm rest though
The Following User Says Thank You to microbionic For This Useful Post:
Astroboy (07-01-2015)
Old 07-02-2015, 10:08 AM   #26
microbionic
They said it was the bottom end, and asked for the oil history which i have sent. and that is all i know so far....
Old 07-02-2015, 10:29 AM   #27
T182graff
Drives: Scion FR-S
I had this same issue and my engine failed and oiled spilled out on my way to the dealership. Here is a video of what I found
Sorry this is the correct video
https://www.youtube.com/watch?v=jHUuQ-b-25E
T182graff is offline   Reply With Quote
Old 07-02-2015, 11:51 AM   #28
Astroboy
Astroboy's Avatar
Drives: None
What oil were you using
engine, frs, knock, ping, sound
anyone experience engine knock on 91 octane? chenshuo BRZ First-Gen (2012+) — General Topics 15 01-13-2013 08:10 PM
obd2 engine sound app brichard0625 Engine, Exhaust, Transmission 4 09-25-2012 05:36 PM
Engine sound trying too hard? pinoyplaya BRZ First-Gen (2012+) — General Topics 8 09-06-2012 08:04 AM
Muddled sound issue was385 Electronics | Audio | NAV | Infotainment 7 06-28-2012 01:14 AM
