| Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack Specific topics relating to wheels and tires. |
NW Region Moderator
Drives: FR-S No More
Wheel Directory: OZ Formula HLT 17x8.0 +48 / 17x9.0 +42
| The Following User Says Thank You to DarrenDriven For This Useful Post: | NWFRS (07-06-2016) |
#2 |
Drives: Ultramarine toyobaru
+48 front +42 rear I think
I tom@kartboy a few weeks ago about this and he stated he ordered the tirerack guarantied fit. |
| The Following User Says Thank You to headlikeahole For This Useful Post: | DarrenDriven (07-08-2013) |
#3 |
I think i will put them in my red 86.. probably the same gold... what do you think?
#4 |
NW Region Moderator
Added to the Wheel Directory:
http://tinyurl.com/86wheels
#5 |
Drives: Black BRZ
just found these on sale on tirerack for $189 a piece. gold or matte grey. 17x9 +42
#6 |
Drives: 13 FR-S Asphalt
17x9 +42
#7 |
Drives: FRS, M3
That looks good guys
#8 |
Goldz
17x9 +42 all around @21lbs. Hankook R-S3 245/40-17. Showing the two different caps that come with them in the first pic. Note there is only one set of the OZ logo center pieces so once you install them (sticker card)on the desired center cap you can't really reuse them. I don't use them. I also have ARP extended studs and the length is perfect for this wheel. Enjoy!
![]() ![]() ![]() ![]() ![]() ![]() ![]() It is real tight on the inside but I have not had any clearance issues. On stock suspension.
![]() Last edited by phatfil; 11-01-2015 at 09:35 AM. |
#9 | |
Drives: 2013 FR-S MT Ultramarine
UPDATE: I did a quick check last night with just the wheel, and I feel I would be more worried rubbing against the seat that the spring sits in, it is much closer than anything else. The sway seems to be tucked away enough, but I cant be sure until I get the tires mounted on the wheels. I'd really like to do these without a spacer if possible, but I dunno if thats gonna be possible up front. ![]()
| OZ Formula HLT 17x9 +42? | Gunman | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 2 | 06-09-2013 06:39 PM |
| WTT Enkei 17x8 for 17x9 5x100 | subaruferrucci | Wheels and Tires | 3 | 04-30-2013 12:28 PM |
| WEDSSPORT TC105N - 17x8.0 +42 / 17x9.0 +35mm 5x100 ~ 15 Lbs Per Wheel | RavSpec | Wheels and Tires | 72 | 12-04-2012 03:58 PM |
| TE37SL - 17x8.5 / 17x9.5 / 18x9.0 5x100 Pre Order Available Now ! | RavSpec | Wheels and Tires | 2 | 07-14-2012 10:37 PM |
