Old 06-21-2014, 01:24 PM   #15
The86Ghost
Drives: 2014 FRS (Whiteout)
Originally Posted by Reaper View Post
If your trying to save the header and exhaust for budget reasons you dont need a turbo. If its for sentimental reasons the well.....I dunno.
Sent from my SAMSUNG-SGH-I747 using Tapatalk
Mainly for budget reasons but i probably wont buy one for about a year
The86Ghost is offline   Reply With Quote
Old 06-21-2014, 01:25 PM   #16
s2d4
s2d4's Avatar
Originally Posted by The86Ghost View Post
If i sell the header what would u recommend?
TR3 performance/FA20Club.
Old 06-21-2014, 01:28 PM   #17
protpibe
protpibe's Avatar
Drives: 4-Runner Sport - 13' BRZ SportTech
You're not planning on getting one for a year?
Sent from my HTC One using Tapatalk
Top Tier Imports - Check out my build journal HERE
protpibe is offline   Reply With Quote
Old 06-21-2014, 01:31 PM   #18
The86Ghost
Soonest would be about 6 months. why?
Old 06-21-2014, 01:31 PM   #19
Reaper
in orbe terrum non visi
Reaper's Avatar
Drives: violent
I'm not going to talk bad but id like to get a point across;
If you're on a budget like that you need to seriously consider the true cost of a turbo. Possible grenaded engine, transmission, broken cv's, you will NEED tires if you're still on stock ones. Anything over 300whp and you need fuel injectors, pump, map sensor, clutch (act is about 600$ and considered a great deal), a good tune, gauges (2-300 $ PER gauge), more frequent oil changes (8 quarts of 13 $ a qt oil adds up) etc. There's a lot more to it than just a 4, 000 $ sbd, or even a 6, 000 $ fbm kit. Between ecutek and dyno time you can spend almost 2, 000 $
Old 06-21-2014, 01:35 PM   #20
The86Ghost
If you're on a budget like that you need to seriously consider the true cost of a turbo. Possible grenaded engine, transmission, broken cv's, you will NEED tires if you're still on stock ones. Anything over 300whp and you need fuel injectors, pump, map sensor, clutch, a good tune, gauges, more frequent oil changes etc. There's a lot more to it than just a 4, 000 $ sbd, or even a 6, 000 $ fbm kit. Between ecutek and dyno time you can spend almost 2, 000 $
Very true i am still debating the whole thing, but that defiantly opened my eyes didnt know that dyno would be that much, thanks alot for the input
Old 06-21-2014, 01:36 PM   #21
protpibe
protpibe's Avatar
fi kits for the twins are popping up everywhere. I would do some research now but not totally make up my mind until I was a little closer to pulling the trigger
Factor in cost of ecutek license and tune as well
Old 06-21-2014, 01:42 PM   #22
Reaper
Reaper's Avatar
Drives: violent
Not every tune is that much but ecutek is really the best option and racerom is EXTREMELY beneficial with a turbo its saved my motor several times already when you wire a wideband o2 into it. I think its 800 $ for ecutek racerom plus a few hours at your preffered tuner.
Just an example:
I really want coilovers. I have enough money in my "car budget" to buy them now. BUT I dont because if my car budget is at 0 $ and I grenade a cv shaft or the transmission or have another fuel system problem, or my now perfectly running car decides suddenly that the summer is actually too hot and now I need an oil cooler and bigger radiator what do I do? Just an example.
Old 06-21-2014, 01:45 PM   #23
The86Ghost
Just an example:
I see. I suppose once you get a turbo u need a little reserve money incase something happens. Yeah i think i might hold off on the turbo for a while until i can TRUELY afford it.
Old 06-21-2014, 01:46 PM   #24
Reaper
Reaper's Avatar
Drives: violent
Glad I could help.
Old 06-21-2014, 01:47 PM   #25
The86Ghost
Glad I could help.
Thanks a lot
FBM Stage 1 Base Turbo Kit Starting @ $3995 Garrett or PTE Turbo Choices FullBlown Forced Induction 588 12-02-2015 02:41 PM
91 MR2 Turbo with KO Racing GT35R for sale/trade for FR-S turbo kit Unleashed Cars for Sale/Trade 8 02-20-2013 06:26 PM
Turbo Tuesday 12/4/2012 (Dynamic Turbo Miami) F3dzo Southeast 46 12-06-2012 01:49 PM
Geneva Preview: Techart to debut 911 Turbo, Turbo S vh_supra26 Other Vehicles & General Automotive Discussions 1 02-22-2010 06:20 PM
