Old 06-21-2014, 09:07 AM   #1
Ibanezboy21
Drives: 2014 Subaru BRZ (S pack)
Lets talk lug nuts
any difference between the expensive ones vs the cheap ones?
any good brands to keep an eye on?
thanks
Ibanezboy21 is offline   Reply With Quote
Old 06-21-2014, 11:21 AM   #2
-Ozzy-
Drives: Raven FR-S - Chevy Cobalt Coupe
Yes.
-Ozzy- is offline   Reply With Quote
Old 06-22-2014, 01:45 AM   #3
Ibanezboy21
Yes as in durability?
I'm pretty sure the colour will fade/chip off no matter how expensive the nut is
The Following User Says Thank You to Ibanezboy21 For This Useful Post:
unsurety (06-22-2014)
Old 06-22-2014, 01:58 AM   #4
Figo
Figo's Avatar
Drives: Vortech Supercharged FR-S
McGard SplineDrive kit. Trust me.
I'd rather lose by a mile because I built my own car,
than win by an inch because someone else built it for me.
Your car is your story, so don't let someone else write the book.
( White Tiger ) - FiGo's 車誌.
Figo is offline   Reply With Quote
The Following 2 Users Say Thank You to Figo For This Useful Post:
kodyo (06-22-2014), unsurety (06-22-2014)
Old 06-22-2014, 02:55 AM   #5
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
Their page on SplineDrive looks like a page for bling.
These require their socket to remove and replace. If you are removing your wheels a lot a standard wheel nut that uses a 19mm socket is the simplest and easiest to replace you should loose the socket.
Personally I wouldn't consider using aluminium alloy nuts on my wheels.
If you want colour there are coloured steel nut available.
Old 06-22-2014, 06:06 AM   #6
Ibanezboy21
any advantages using aluminium nuts beside the weight?
alot of people dont like them because the threads wear out easily
any good brands out there or are they all the same (a nut is a nut?)
Old 06-22-2014, 06:14 AM   #7
6pack
6pack's Avatar
Drives: GT86
Muteki SR48 (for example) brought by Evasive.
http://www.evasivemotorsports.com/mm...tegory_Code=L1
Not necessarily red but necessarily made of durable chrome vanadium.
Check this thread: http://www.ft86club.com/forums/showthread.php?t=18106
6pack is offline   Reply With Quote
Old 06-22-2014, 09:57 AM   #8
Figo
Figo's Avatar
U will be able to buy socket only on amazon. Aluminum nuts are not strong enough. If u r going to remove then frequently, u might ruin the thread one day. Spline drive is two- pic design, which protect ur rims. Also the paint last long.
Old 06-22-2014, 10:33 AM   #9
campy
No rice, no life
campy's Avatar
Drives: 2013 Asphalt FR-S
I have spline drive lugs and I can confirm that no one has stolen my wheels yet, and I park in some pretty ghetto places.
campy is offline   Reply With Quote
Old 06-22-2014, 01:18 PM   #10
kodyo
Drives: Scion FR-S
I have the McGard spline drive w/lock set. Amazon had a pretty decent price on them.
kodyo is offline   Reply With Quote
Old 06-22-2014, 01:55 PM   #11
Ben_G
Drives: Blue BRZ
Spline drives.... not for security reasons, since anyone with the spline socket can remove all the nuts, but because they are durable and the washer base seems to make it easier to tighten on alloy wheels than regular lugs.
I wouldn't use aluminium just because the weight savings are negligible, and even if you were saving two pounds, it's all at the centre of rotation and you would be better served buying lighter tires or wheels.
Ben_G is offline   Reply With Quote
Old 06-22-2014, 02:25 PM   #12
FR-S Matt
Ray's racing lug nuts. $100 for a set with wheel locks. They are durable as hell and I've removed them at least 10 maybe 15 times now. Love em.
Old 06-22-2014, 06:55 PM   #13
AC13_JohnG
AC13_JohnG's Avatar
Drives: FR-S & MK6 Golf
I second this. Can't go wrong with a good price and lifetime corrosion warranty.
"David Hasselhoff, disguised as his superhero alter ego, The Bay Watcher. He stuffs his fanny pack (he calls it his "utility belt") with cheeseburgers and stalks the city fighting crime (actually, he is just eating cheeseburgers)."
AC13_JohnG is offline   Reply With Quote
Old 06-22-2014, 07:06 PM   #14
Figo
Figo's Avatar
Probably because your wheels do not worth taking risk.
Just kiding..
If you got a set of $8000 wheels, if they really want them, they will take them anyway.
Lets talk tires... frs10 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 34 10-04-2013 05:21 AM
Lets talk about clutches charged86 Engine, Exhaust, Transmission 26 08-30-2013 04:13 PM
Lets talk rev limiter. Method Engine, Exhaust, Transmission 7 06-13-2013 09:20 PM
Lets talk exclusivity whitejdm BRZ First-Gen (2012+) — General Topics 33 02-15-2012 01:17 PM
Lets talk weight KaliKev Scion FR-S / Toyota 86 GT86 General Forum 63 09-12-2011 12:05 AM
