#141 |
Drives: S60R/Corvette
Sorry boss, I've never seen the BRZ suspension in person and I definitely have not had it on a 7-post.
Ryan M.
Strange Engineering Director of Suspension Development |
#142 | |
The rear suspension is all about compromises to save money since they borrowed it from the Impreza and before that the Legacy. The original reason for that suspension design was to get more rear cargo room.
| The Following User Says Thank You to xwd For This Useful Post: | Kostamojen (06-21-2014) |
#143 |
Because compromise ®
Drives: Red Herring
I really don't like my chances of trying to sneak AUD10k past the wife for the household budget.
#144 |
Drives: Used to Drive:Grand-Am GS #54 E36M3
| The Following 2 Users Say Thank You to dradernh For This Useful Post: | Captain Snooze (06-21-2014), srizzors25 (04-28-2015) |
#145 |
Drives: Red Herring
I was under the impression that the standard dampers were quite good for a car at this price point. The standard sway bars are not what I would call "hefty".
#146 |
#147 | |
In fact, I bet if the car sat 1" lower from the factory, most owners on here wouldn't even touch the suspension. |
| The Following User Says Thank You to Kostamojen For This Useful Post: | s0sl0w (06-23-2014) |
#148 | |
Frosty Carrot
Drives: The Atomic Carrot
As far as sway bars, I complain too much and I should get over it. My background is with off-road suspensions... so I feel naughty when something interferes with articulation (even when it improves handling). If the world were made of Nutella and rainbows, our car would have come with wishbones and pushrods (and maybe a third spring setup):
If you think you're nerd enough, join in the discussions about Suspension and Aerodynamic modelling!
Wall of Fame - JDL Auto Design, Raceseng, Vishnu Tuning, Penske Shocks, Nameless, Perrin, RaceComp Engineering, Essex/AP Racing, Verus, RacerX Wall of Shame - aFe Takeda, Wilwood, FA20Club |
| The Following User Says Thank You to Shankenstein For This Useful Post: | Captain Snooze (06-21-2014) |
#149 |
Drives: Red Herring
Yeah, if I won the lottery I would buy just the Kirkham chassis and make a coffee table out of it.
#150 | |
Drives: 2012 Toyota 86
) and to go lower, i needed stiffer.
#151 | |
Junior
Drives: a car
One last thing; how should we endevor to find out about all those options and what they do if someone where to call you guys and get into the nitty gritty custom stuff?
#152 |
An 8780 manifold is a housing mounted to the outside of a damper that hold various adjusters. There are many incarnations of this damper at this point. You can have thru-rods, inerters, solid main pistons or adjustable bleed on the main piston while the manifold can have dual-bleed adjusters, digressive, and regressive adjusters. Everyone of them independent in compression and rebound.
Here is a bad video with some guy mispronouncing thru rod. You can see the gold dual-bleed adjusters sticking out the bottom of the manifold. There is a silver high speed compression adjuster on the opposite end of the manifold you can kind of see. [ame="https://www.youtube.com/watch?v=enDKh-CqoMY"]PS-8780 from Penske Racing Shocks ID11637 - YouTube[/ame] I'm trying to make a big push this year to kind of turn our website into something similar to the Garrett turbo website with the Turbo 101/2/3 tech info. Keep an eye on that every now and then, its slow going because we're so busy but it'll get done. I started working on the BRZ shock package again today in collaboration with a certain company that makes well known camber/cast plates and rear shock mounts. The shocks will likely end up with options for single rebound bleed in the shaft, and 7500 style head valve for high speed compression adjustment, dual-bleed in the shaft, and the 8300 (single adjuster in the remote reservoir) or 8760 style (dual adjuster in the remote reservoir). The order of adjusters I just listed were basically in order of cost and you can read about them a little in our tech docs. 7500 double adjustable http://www.penskeshocks.com/assets/T...A)%2008-10.pdf 8300 double adjustable http://www.penskeshocks.com/assets/8...K%20Manual.pdf 8760 double adjustable http://www.penskeshocks.com/assets/A...e%20Manual.pdf Dual-bleed tech http://www.penskeshocks.com/assets/E...-DB%20REV1.pdf You can read about a growing number of topics here such as "what is pressure balancing", "regressive valve assemblies", and the "mustang strut manual" which should be renamed because all of our struts are the same. http://www.penskeshocks.com/technical/ Of course you can always call and talk to us about the basics or the uber technical. I'm working with an Evo guy now that didn't really know what he wanted so we actually saved him money by pushing him toward the same adjuster setup as most of our pro teams in the Tudor series and others. Long winded but hopefully helpful.
Ryan M.
| The Following 5 Users Say Thank You to RBbugBITme For This Useful Post: | BatStig (06-10-2015), Kostamojen (04-25-2015), Racecomp Engineering (02-24-2015), waterbison777 (04-28-2015), wparsons (04-28-2015) |
#153 |
*Drooooooooooooooooool*
Thanks for the update Ryan! |
#154 |
![]() Done. Designed with custom-for-Penske Raceseng 1" extended rear upper mounts. ![]() We'll have a set on the Raceseng car soon.
Ryan M.
| The Following 7 Users Say Thank You to RBbugBITme For This Useful Post: | BatStig (06-10-2015), CSG Mike (04-28-2015), Kostamojen (04-28-2015), Shankenstein (04-28-2015), solidONE (04-28-2015), waterbison777 (04-28-2015), wparsons (04-28-2015) |
| Penske Coilovers. | miwialex | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 44 | 12-20-2013 08:17 PM |
| Penske 8300 vs Ohlins TTX36 | CSG Mike | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 45 | 09-12-2013 07:08 PM |
| MSRP FR-S available at Penske Scion in Socal. | Moto-P | Dealer Cars | 2 | 07-25-2012 09:29 PM |
| Penske Scion has a Silver/AT FRS in stock, MSRP. | Moto-P | Scion FR-S / Toyota 86 GT86 General Forum | 1 | 07-13-2012 02:00 PM |
| Brz Info/Specs (helpful info for questions asked often) | Gaen | BRZ First-Gen (2012+) — General Topics | 0 | 05-24-2012 10:09 PM |
