Old 06-20-2014, 10:58 AM   #127
tahdizzle
So elite I'm 1338
Drives: WRB Subaru BRZ
This thread makes me wish I had 15k to use on suspension :p
Old 06-20-2014, 11:08 AM   #128
RBbugBITme
Drives: S60R/Corvette
Originally Posted by 7thgear View Post
but this is not optimal, correct?
and if yes, is purely the progressiveness of the rate or the material choice/force distribution.
Its just one of many choices a designer has to make when designing a suspension. Only lap times will tell you if its optimal or not.
Andy, I would agree your assessment certainly makes sense. Have you experimented with removing the OEM bump stops while running high end shocks? Are they mounted on the control arm or the shock shaft? I'll also add that a lot of "performance" shock upgrades from the factory are the same shocks with stiffer bump rubbers.
Ryan M.
Strange Engineering
Director of Suspension Development
RBbugBITme is offline   Reply With Quote
Old 06-20-2014, 11:21 AM   #129
Racecomp Engineering
For Subarus they're on the shock shaft. With some of the high end shocks we've run (JRZ, Moton, etc.) we do not use bumpstops. For OEM with the stock springs I suspect the shocks wouldn't last long, at last for BRZ since there isn't much travel and the main spring is so soft. New 2015 WRX and STI are bumpstop active but actually have much firmer main springs than they have in the past.
No bumpstops on your Penske set I presume or is there an internal one up front?
With our own lowering springs on stock shocks (different ball game then those shopping for Penskes) we use much shorter replacement bumpstops, a mild drop, and a decent bump in spring rate. We like it for the money, but a quality shock makes a big difference at that point.
Interesting on the last point...I wouldn't put something like that past BMW...
- Andy
Old 06-20-2014, 11:23 AM   #130
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
another question
you mentioned earlier that part of the cost for strutted cars is the strut, which is expensive to design/manufacture on a small scale.
I don't suppose that making an insert, such as what koni does, would ever be a possible solution? Not enough room for a monotube?
Old 06-20-2014, 11:33 AM   #131
RBbugBITme
The customer didn't ask for any. We also haven't had any feedback yet on the spring rates he's running since he didn't buy them from us.
Ryan M.
Strange Engineering
The Following User Says Thank You to RBbugBITme For This Useful Post:
Racecomp Engineering (06-20-2014)
Old 06-20-2014, 11:36 AM   #132
RBbugBITme
another question
Not really practical for an inverted strut design.
Ryan M.
Strange Engineering
Old 06-20-2014, 12:30 PM   #133
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
I feel like we're all talking to the cool kid on the block lol
Im curious to know @RBbugBITme's impression of the prototype damptronic setup @DougW is putting together.
Old 06-20-2014, 02:43 PM   #134
Jive Turkey
the tuna, no crust.
Jive Turkey's Avatar
Drives: 2014 Hachiroku of the year
dear lord, this makes me feel like a peasant with my AST's
Jive Turkey is offline   Reply With Quote
The Following 3 Users Say Thank You to Jive Turkey For This Useful Post:
Captain Snooze (06-20-2014), CSG Mike (06-20-2014), ohmai18 (09-02-2015)
Old 06-20-2014, 02:49 PM   #135
fooddude
Drives: 04 Toyota Tacoma Prerunner Reg Cab
Thanks errbody, glad I can help.
We have more than half the field. They're all non-adjustable for weight and packaging.
Sent from my SAMSUNG-SM-G900A using Tapatalk
Ah, I see. So I am assuming in F1 or other high end races, these non-adj shocks are internally built/valved to spec per session and per track, and maybe have several spares in the paddock/garage with different internal specs to swap? (ie: instead of having a set of adj shocks...they just have a grip load of non-adj shocks to swap..and that's their "adjusting") ..Wow.
fooddude is offline   Reply With Quote
Old 06-20-2014, 02:53 PM   #136
RBbugBITme
Correct
Ryan M.
Strange Engineering
fooddude (06-20-2014)
Old 06-20-2014, 02:58 PM   #137
fooddude
Cray!
Old 06-20-2014, 03:01 PM   #138
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
Originally Posted by fooddude View Post
Cray!
Not cray...
The track, speed, engine performance, tires, and even ambient temps are all known parameters.
Why add complexity to adjustable shocks when you just dial in the car for the track conditions? Makes the systems more reliable.
-alex
Old 06-20-2014, 03:04 PM   #139
fooddude
I meant cray in a good way lol.
ie: very neat, cool, awesome, amazing, nice, fantastic, interesting, that's epic bro, etc.
Old 06-20-2014, 06:04 PM   #140
Shankenstein
Frosty Carrot
Shankenstein's Avatar
Drives: The Atomic Carrot
Hey Ryan. Thanks for bringing your expertise to our little community.
As a suspension guy who has probably had the BRZ up on a 7-post rig, did you identify anything heinous about the design or any "low hanging fruit" for the tuners to focus on?
From what I've seen, the camber and toe are relatively well-behaved (as long as you're not slammed). A few of the guys on here have had positive results from adding caster up front. Otherwise, the weight transfers are fairly smooth, and the chassis is pretty solid.
The supporting hardware seems to be the main weakness. With the "modern" approach to suspension design (bump stops, hefty sway bars, soft springs), it kind of puts damper quality and spring rate in the background. Packaging the suspension was a bit awkward in the upper rear and around the sway bars... but those are minor gripes.
What are some improvement you would have made?
If you think you're nerd enough, join in the discussions about Suspension and Aerodynamic modelling!
Wall of Fame - JDL Auto Design, Raceseng, Vishnu Tuning, Penske Shocks, Nameless, Perrin, RaceComp Engineering, Essex/AP Racing, Verus, RacerX
Wall of Shame - aFe Takeda, Wilwood, FA20Club
Shankenstein is offline   Reply With Quote
Penske Coilovers. miwialex Suspension | Chassis | Brakes -- Sponsored by 949 Racing 44 12-20-2013 08:17 PM
Penske 8300 vs Ohlins TTX36 CSG Mike Suspension | Chassis | Brakes -- Sponsored by 949 Racing 45 09-12-2013 07:08 PM
MSRP FR-S available at Penske Scion in Socal. Moto-P Dealer Cars 2 07-25-2012 09:29 PM
Penske Scion has a Silver/AT FRS in stock, MSRP. Moto-P Scion FR-S / Toyota 86 GT86 General Forum 1 07-13-2012 02:00 PM
