Old 06-20-2014, 02:33 PM   #1
mkivalex
Drives: 13 Scion FRS, 93 JDM Toyota Supra
Gap under passenger headlight
I've had the car for about 5 months now, and I don't know how I never noticed this gap, or maybe its just appeared, but I don't know how it could have.
Hear is looking down over the passenger headlight, notice the huge gap between the bumper and headlight,
Here is looking down over the driver headlight, notice that there is no gap and the "end " of the bumper is tucked under the headlight revealing no edge.
Now that I have noticed it its driving me crazy, I've seen shitty aftermarket body kits with smaller gaps, Is this something the dealer would address, or tell me to suck it up?
Thanks guy
mkivalex is offline   Reply With Quote
The Following User Says Thank You to mkivalex For This Useful Post:
Gords_zenith (06-21-2014)
Old 06-20-2014, 02:50 PM   #2
jonzhuxD
Drives: Ultramarine FR-S
Thanks guy
There was a TSB for improper fitting body panels but I don't think this was covered. This is typical if you've removed your front bumper. There are some members who have tried replacing the clips that hold the bumper on with limited success in fixing the gap. Mine looks just like yours except on the driver's side.
jonzhuxD is offline   Reply With Quote
Old 06-20-2014, 02:59 PM   #3
hmkk
I had the exact problem after I got my bumper repainted, from what I heard, they said one of the clips was bent the wrong way and was a fairly easy fix. That said, after they re-installed the bumper it was perfect again
hmkk is offline   Reply With Quote
Old 06-20-2014, 03:01 PM   #4
mkivalex
Hmm I've never had the bumper off but maybe I'll take a look at the clips
Old 06-21-2014, 07:33 PM   #5
Liquidsnake
Drives: "I drives like a Porsche"
I had my front bumper repainted and it's the same. I'm taking it back to get refitted.
Liquidsnake is offline   Reply With Quote
Old 06-21-2014, 08:01 PM   #6
Gords_zenith
Gords_zenith's Avatar
Drives: WRB BRZ Sport Tech
I just had this fixed at my dealer (June 16) for the exact same thing I think there's an issue with the passenger headlight brackets but they replaced them under warranty. Tbh I think there needs to be additional bracing needed in behind the lower bumper to alleviate the stress on the tiny plastic clips, because if you slightly pull up and out at the Lower corner the gap closes. My 0.2 cents
Gords_zenith is offline   Reply With Quote
Old 06-22-2014, 03:11 PM   #7
636
636's Avatar
Drives: '23 CWP BRZ
I had the same problem.
"Also found this gnarly gap in my bumper. lol, oh well.
Took my bumper off, and took my time realigning it, gave it a solid pop and in it went.
"And fixed the gap I found earlier."
636 is offline   Reply With Quote
The Following User Says Thank You to 636 For This Useful Post:
Gords_zenith (06-22-2014)
Old 06-22-2014, 04:20 PM   #8
slicktop
Drives: 2013 Raven FRS 2JZ-GTE/V160 swapped
Mine had that gap when I removed the bumper to paint my headlight housings. I had to re-position it and that fixed the "problem".
slicktop is offline   Reply With Quote
Old 06-24-2014, 01:27 PM   #9
FRSTRM
Baby LFA
FRSTRM's Avatar
Drives: Baby LFA
Yup this is fairly normal. Issue with the bumper fitment.
FRSTRM is offline   Reply With Quote
Old 06-24-2014, 02:54 PM   #10
Chattanooga FR-S
Chattanooga FR-S's Avatar
Drives: Monogram Firestorm
Sorry, it's all I was thinking while reading the thread...
Chattanooga FR-S is offline   Reply With Quote
Old 06-24-2014, 05:31 PM   #11
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
You're right:
S-TT-0043-12 wasn't really a TSB it was just a warning to technicians and states that some vehicles may have body panels that aren't flush (either under- or over-flush) which are causing customers to complain. This tech tip doesn’t offer a fix, and merely states that Toyota is “looking into” the issue.
So basically you take it to the dealer, and they should mess with the front bumper clips till it fits properly hopefully.
I need frs passenger fender and headlight! Jonoraven93 Exterior Parts (Aero, Lighting, Etc.) 20 02-05-2018 02:55 PM
BRZ Passenger Side Headlight Available pd Exterior Parts (Aero, Lighting, Etc.) 3 12-22-2013 05:01 PM
OEM/USDM Passenger Headlight Nizz300Ft86 Exterior Parts (Aero, Lighting, Etc.) 1 11-25-2013 10:12 PM
Cracked BRZ passenger headlight Jive Turkey Exterior Parts (Aero, Lighting, Etc.) 16 09-24-2013 01:50 PM
WTB: Passenger-side FRS headlight retrosmiths Exterior Parts (Aero, Lighting, Etc.) 0 07-17-2013 01:49 AM
