Old 06-19-2014, 10:41 AM   #953
FastWhite
Drives: Subaru BRZ Limited M/T
You would end up in CSP. Lot of "slow" Miata competition. Get to run R compounds, trany work. All that good expensive stuff. Might as well go SM and FI.
FastWhite is offline   Reply With Quote
The Following User Says Thank You to FastWhite For This Useful Post:
barabia (06-19-2014)
Old 06-19-2014, 10:51 AM   #954
vroom4
FYI: If you are at 0 toe in front. 3 turns of the 'flats' on the tie rods on both sides gets you to 1/4" total toe out. So 1 and 1/2 turns would be ~ 1/8" total toe out.
vroom4 is offline   Reply With Quote
The Following User Says Thank You to vroom4 For This Useful Post:
Scooby South (06-19-2014)
Old 06-19-2014, 10:55 AM   #955
Scooby South
Conedancer
Scooby South's Avatar
Drives: 2013 Subaru BRZ SWP
Thats some good info..
Wouldn't it be dependent on ride height tho??
Bill
Scooby South is offline   Reply With Quote
Old 06-19-2014, 05:38 PM   #956
vroom4
Bill
Yea, it was more the CS guys. It would probably be pretty close though. I mean in reality who cares what the number is. If you just try different things, do it the same on both sides and make sure you record your 'base' settings, you can find what you like. 3 turns of the flats is good to know for everyone though because if you are at like 9 turns..you know something isnt right.
Old 06-20-2014, 11:49 PM   #957
MidnightRunner
MidnightRunner's Avatar
Standard WRX Camber plates..nothing special
Oh wow. So any 2008+ wrx camber plate can work?
There is no great genius without a mixture of madness - Aristotle
MidnightRunner is offline   Reply With Quote
Old 06-21-2014, 10:01 AM   #958
Scooby South
Conedancer
yes.. Subaru has the same bolt pattern for ALL their Strut mounts..that is why so much is interchangeable
Bill
The Following User Says Thank You to Scooby South For This Useful Post:
MidnightRunner (06-22-2014)
Old 06-22-2014, 01:04 AM   #959
MidnightRunner
Bill
Thank you Bill, I really appreciate that.
Old 06-22-2014, 03:59 PM   #960
xDanger_208x
xDanger_208x's Avatar
Drives:
I'm bored so I'm poking around the engine bay... question?
Is it legal to remove the metal bracket on the driver side of the engine? It serves no other purpose than as a cover for some fuel injection components.
It's the one that looks similar to the ecu mount.. but on the other side.
xDanger_208x is offline   Reply With Quote
Old 06-22-2014, 04:18 PM   #961
Scooby South
Conedancer
take a pic. It 'shouldn't' be a issue. but let me see what we are looking at before I say yay or nay..
Bill
Old 06-22-2014, 04:20 PM   #962
xDanger_208x
Drives:
Bill
I'm trying to attach the picture but tapatalk isn't uploading it for some reason.
Old 06-22-2014, 04:31 PM   #963
xDanger_208x
Drives:
Here.
It's quite heavy for its relatively meaningless job. I'd say close to 5 lbs.
Old 06-22-2014, 05:01 PM   #964
Scooby South
Conedancer
Here.
I am going to say 'NAY'..
"I. Upper engine shields made of plastic material, the purpose of which is to hide mechanical components in the engine compartment, may be removed if they have a solely aesthetic and/or acoustic function."
Since its a Gov. Mandated Safety item (Fuel rail protection).. and its metal, not Plastic, Like the intake cover on the top... I would not remove it.
Bill
Old 06-23-2014, 03:37 PM   #965
BRZZZZZZZZZZ
Car Nut
BRZZZZZZZZZZ's Avatar
Drives: BMW 335d, Toyota Echo RS, FRS
Alright I am getting serious about auto x now. Ive already had a good headstart with the suspension and wheel and tires mods for STX. I don't want to touch my powertrain for fear of voiding warranty. What are the key things for STX that I need that arent powertrain related?
I've already done shocks and springs, camber plates, sway bars, rear LCA, and wheels/tires.
BRZZZZZZZZZZ is offline   Reply With Quote
Old 06-23-2014, 04:05 PM   #966
Kido1986
Dodging cones
Kido1986's Avatar
Drives: 2013 BRZ Limited, 93 Z28
Those items plus header and a tune are the key items for STX. There's obviously more but those items (plus header/tune) are 80% of it.
Lighter battery would be nice, easy way to save 20 lbs.
Originally Posted by trevorovert View Post
Originally Posted by mrbillclintong View Post
If you guys spot any riced frs/brz post them here just for laughs no hating please.
Isn't there already a thread like this? It's called aggressive wheels or summat...
C Street Build/Progress Questions about C Street Autocrossing?
Kido1986 is offline   Reply With Quote
Thoughts on a "component" setup with a 3.5" dash and 6.5" door setup? PatrickSAN Electronics | Audio | NAV | Infotainment 22 11-14-2012 02:12 PM
SCCA sway bar rules gmookher Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 09-01-2012 06:48 PM
Suggestion for vendor rules... Tainen Site Announcements / Questions / Issues 31 08-15-2012 01:53 PM
Rules for posting in this section Hachiroku User/Vendor/Sponsor Reviews, Feedback, Comments 0 06-25-2012 11:02 AM
