Old 06-19-2014, 05:05 PM   #1
protpibe
protpibe's Avatar
Drives: 4-Runner Sport - 13' BRZ SportTech
Effect of aftermarket rear control arms on toe
So I just put Buddy Club adjustable rear control arms into my car and I'm havnig some issues with the alignment. The shop I took it to assures me that adjusting the length of the rear control arm will have no effect on Toe, but the closest they can get the rear toe to is .8 toe out, which is obviously way too much.
The rear control arms are at their shortest setting and it looks like they weren't even touched. The camber is -1.5 right now.
The way the control arms attach to the knuckle make me think that if you lengthen the rear control arm, it will start to toe the wheel in, am I right in this assumption?
I have no issues ordering rear toe arms, but I"m thinking I should be able to get these to 0 with the factory toe arms for now.
Any help would be appreciated.
Top Tier Imports - Check out my build journal HERE
protpibe is offline   Reply With Quote
Old 06-19-2014, 05:15 PM   #2
Figo
Figo's Avatar
Drives: Vortech Supercharged FR-S
3 quick solution:
1. raise the height of rear.
2. run more negative rear camber. (do not recommend too much negative camber)
3. toe arms.
I'd rather lose by a mile because I built my own car,
than win by an inch because someone else built it for me.
Your car is your story, so don't let someone else write the book.
( White Tiger ) - FiGo's 車誌.
Figo is offline   Reply With Quote
Old 06-19-2014, 05:21 PM   #3
protpibe
protpibe's Avatar
The car isn't actually slammed at all. There's about a finger width from tire to fender. My problem is that I don't think the shop that I took it to is competent when it comes to aftermarket alignments.
My control arm length is set to it's shortest. Camber is currently -1.5 and toe out is .89
I guess what I'm asking is that if the rear control is lengthened, would that not bring the toe back in since it's pushing the rear of the knuckle outwards?
Old 06-19-2014, 05:31 PM   #4
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
If they told you that changing camber does not affect toe, then I would find another shop. Adding more negative camber or lengthening the rear control arm will definitely bring the toe back in. The reality is that the Subaru spec calls for a decent amount of negative rear camber already. The amount you are lowered and the amount of camber you run will determine whether the OEM eccentric adjuster will be able to get your toe within specs. @Figo is correct.
wparsons (06-20-2014)
Old 06-19-2014, 05:50 PM   #5
protpibe
protpibe's Avatar
If they told you that changing camber does not affect toe, then I would find another shop. Adding more camber or lengthening the rear control arm will definitely bring the toe back in. The reality is that the Subaru spec calls for a decent amount of negative rear camber already. The amount you are lowered and the amount of camber you run will determine whether the OEM eccentric adjuster will be able to get your toe within specs. @Figo is correct.
Yeah thats pretty much what they said. I just checked the rear control arms and they literally weren't touched and are at the shortest. I think I'll just take it elsewhere tomorrow
Old 06-20-2014, 12:09 AM   #6
protpibe
protpibe's Avatar
For anyone else that runs into this issue and the alignment shop you use tells you that control arms don't affect toe, don't give them a penny.
After 10 minutes under the car, it becomes pretty apparent. The control arm adjustment wasn't touched at all and it's really obvious what effect control arm length has on toe angle. The guy doing it must of been lazy or just didn't know much.
Old 06-20-2014, 02:46 PM   #7
Jive Turkey
the tuna, no crust.
Jive Turkey's Avatar
Drives: 2014 Hachiroku of the year
Originally Posted by Figo View Post
3 quick solution:
3. toe arms.
remember when i told you this and you didn't believe me?
i had the same issue, i dont want to run more camber or change height so toe arms with aftermarket control arms are basically a must if you want to really dial it in how you want.
yeah..if they say that they really dont know how to setup a suspension
Jive Turkey is offline   Reply With Quote
The Following User Says Thank You to Jive Turkey For This Useful Post:
Figo (06-20-2014)
Old 06-20-2014, 03:03 PM   #8
Figo
Figo's Avatar
I have learned alot since I got this car. hah.
Old 06-20-2014, 03:17 PM   #9
CSG Mike
CSG Mike's Avatar
You need a new alignment shop.
The Following 3 Users Say Thank You to CSG Mike For This Useful Post:
Jive Turkey (06-20-2014), protpibe (06-20-2014), wparsons (06-20-2014)
Old 06-20-2014, 04:58 PM   #10
Tye300
Tye300's Avatar
Drives: Toyota 86 TRD Version AT
I recently got an alignment and have cusco LCAs. Toe arms are stock. I was able to get -1.5 camber for my rears with 0 toe. It can be done.
Tye300 is offline   Reply With Quote
Old 06-20-2014, 07:55 PM   #11
Malt
Drives: 2015 WRX
At what ride height? That's the issue most are having with their alignments. Lowering the rear gets you more static negative camber that may be impossible to dial out without toe arms.
Malt is offline   Reply With Quote
The Following User Says Thank You to Malt For This Useful Post:
Old 06-20-2014, 10:59 PM   #12
Tye300
Tye300's Avatar
Not as low as some people here. I'm around 2-2.5 inches lower than stock. Around what the OP said his ride height was.
Old 06-21-2014, 06:31 AM   #13
Malt
Drives: 2015 WRX
I'm glad you were able to get yours done with just LCA's but there often is a huge difference side to side on the stock suspension from the factory. Many are unable to get what they want alignment wise without the toe arms and people need to be aware of that fact so they are not surprised.
Which would you rather spend: The ~$150-$200 for toe arms up front and get aligned once or risk it and have to end up buying toe arms anyway AND have to pay for another alignment?
Coming from someone who has spent way more than I should have getting my alignment dialed in people should just do it the right way the first time if their cars are lowered instead of trying to piecemeal it together like I did. I could have easily saved several hundred dollars if I had just bought everything at once.
The Following 2 Users Say Thank You to Malt For This Useful Post:
CSG Mike (06-21-2014), Tye300 (06-21-2014)
Old 06-21-2014, 10:18 AM   #14
makinen
makinen's Avatar
Drives: Toyota 86
I've got my rear camber -3.3 and toe in 8 mm with longest position of SPC LCAs after direct swap from stock rear LCAs.
Attachment 82746
Adjusting both eccentric bolts of stock toe arms and SPC lower arms, finally got camber -2.0 and toe 0.
20 mm down by RCE Tarmac springs.
So I can say that at least using SPC LCAs another toe arms are not necessary for usual applications.
makinen is offline   Reply With Quote
SPL Arms - Brand New! - Rear Lower Control Arm + Rear Toe Arm w/ Eccentric Lockout quiet-k Brakes, Suspension, Chassis 8 03-22-2014 10:17 PM
WTB: any rear control arms lp87 Want-To-Buy Requests 5 01-13-2014 11:50 AM
GTSPEC rear control arms & toe arms review Jesse Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 08-23-2013 03:20 PM
Rear control arms Toyobaru808 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 1 11-29-2012 09:23 PM
Rear control arms EN2_Squirrel Suspension | Chassis | Brakes -- Sponsored by 949 Racing 24 11-07-2012 04:04 PM
