Old 06-03-2014, 07:52 AM   #127
s2d4
s2d4's Avatar
Originally Posted by AL008 View Post
Are there any problems using a 02 Spacer in the secondary of the header?
If you are confident that there is no leaks, just disable the DTC.
Old 06-06-2014, 03:14 AM   #128
Gums
Drives: SWP BRZ
Thanks for your efforts to help overcome our crappy fuel steve99.
Since reading this post I am running 100ron exclusively, though haven't loaded your tune as I have been running a prototype Phantom ESC with Shiv's G rom ESC tune.
With s2d4's assistance I have a 3rd - 4th gear pull from earlier this week.
Would value your thoughts on how this looks and which parameters I should be logging to see if I am getting any knock.
Exhaust/filter are stock.
http://www.datazap.me/u/gums/aussie-esc-pull-100ron
Gums is offline   Reply With Quote
Old 06-06-2014, 03:25 AM   #129
steve99
Drives: FT86
The FLKC is still not working correctly on G roms as far as i know,
for knock log
RPM
THROTTLE
FBKC
KNOCK CORRECTION
KC LEARNED ( we can derive flck from this)
IAM
try FLKC but is probably suspect
Engine LOAD
PROBABLY WORTH
LTFT
FUEL SYSTEM STATUS OL/CL
AFR
COMMANDED AFR
got no experience with the phantom esc but we will be able to see if its knocking
Old 06-06-2014, 03:43 AM   #130
Gums
Drives: SWP BRZ
Thanks Steve,
Bit of a noob when it comes to this, added link in previous post to datazap
Old 06-06-2014, 06:02 AM   #131
steve99
Drives: FT86
Thanks Steve,
Hi you need to log
RPM
THROTTLE
FBKC
KNOCK CORRECTION
KC LEARNED ( you can derive flck from this but you will need to look at the Ignition Advance Max A table)
IAM
Engine LOAD
It looks a bit suspect where the KC Learned is stepping down at higher rpm on towards the end the third rpm peak. But you really need to log LOAD and knock correction and FLCK to make sense of it. It might just be the tune reducing advance as load rises under boost
http://www.datazap.me/u/gums/aussie-...1-2-5-6&solo=5
I think your better off sending the logs to Shiv and let him look at it
Old 06-18-2014, 11:46 PM   #132
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
I did a power run on a dynapack yesterday, as I've never dyno'ed this car before. Here are the results:
http://s9.postimg.org/kevmjohnz/2014...527_Page_1.jpg
This chart overlays a run taken from stock BRZ which was done on the same dyno:
http://s9.postimg.org/g70uaxg8f/2014...527_Page_2.jpg
My tune was done by @jamesm from HRI Tuning. Only other mod is a Motiv catted front pipe. I felt that I really needed a custom tune instead of a canned tune because the of the crappy fuel here...even on 98RON...and the ECU's hyper-sensitivity to fuel quality.
Anyways, what I noticed was that the AFR readings from the dyno run doesn't quite match the readings taken from my OFT logs. Can someone chime as to why? Here's my most recent data log taken couple of days ago: http://datazap.me/u/fizz/hrilog11?lo...1&zoom=33-2077
The AFR's from the dyno appears to be quite lean at WOT...?
Fizz is offline   Reply With Quote
Old 06-19-2014, 12:01 AM   #133
steve99
Drives: FT86
Likely Dyno guys would have hooked up their own wideband 02 sensor which would be more accurate than the stock o2 sensor the OFT is using I suspect.
Old 06-19-2014, 12:05 AM   #134
s2d4
s2d4's Avatar
The placement location would be another variation as well unless it is at the rear oem o2 sensor, even then they won't be exactly the same.
Old 06-19-2014, 12:09 AM   #135
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
Ok thanks guys....makes sense now. But still curious which is the more accurate/true reading? The sensor from dyno, or sensor from car?
If the reading from the dyno is a better reflection of actual conditions, that means I'm potentially running too lean at WOT? Or am I worrying too much?
Old 06-19-2014, 12:16 AM   #136
steve99
Drives: FT86
hopefully the dyno's O2 would be more accurate as they would check its calibration.
Old 06-19-2014, 12:22 AM   #137
s2d4
s2d4's Avatar
I would go with the stock at the moment.
Did you ever do one with just Shiv's tune?
Old 06-19-2014, 12:32 AM   #138
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
No I didn't. But with Shiv's canned tune I was getting heaps of tip-in knock. Since getting the custom tune done it's all smooth....
Old 06-19-2014, 12:36 AM   #139
s2d4
s2d4's Avatar
Yeah, you can tell by the commanded afr at the high load low rpm range, also appears to target the same from cl to ol.
Looks like power did drop in that area because of it though, a bit of a balancing act I guess.
Old 06-19-2014, 02:54 AM   #140
Kodename47
Kodename47's Avatar
Drives: UK GT86
The dyno O2 sensor will be exposed to more ambient air and is after 1/2 cats depending on your exhaust configuration so it will read leaner probably by a good 0.1-0.2 AFR points minimum. As for which one to trust, that's down to you. I've heard reports recently of someone I know having 3 sensors in the exhaust pre-cat (inc. 1 OEM) and one in the tail pipe. They all read differently, so again, do you trust 1/none/all??
Feed it back to James and see what he says. So long as its not knocking I don't see an issue so long as you're not lean at the top end, which you're not.
.: Stealth 86 :.
Kodename 47 DJ:
Knock Correction vs Knock Correction Learn values? swift996 Software Tuning 19 11-03-2015 10:09 PM
Dynosty Fuel System Upgrades- Billet Fuel Rails!!! Dustin@Dynosty Forced Induction 4 10-08-2014 10:00 AM
FuelLog (Android) App:~10k miles of MPG, Range, Fuel Prices, Fuel Qty, Etc. MmmDieselFumes Scion FR-S / Toyota 86 GT86 General Forum 28 02-02-2014 08:19 PM
Fuel gauge misreading actual fuel in tank. Scionshaun Scion FR-S / Toyota 86 GT86 General Forum 19 10-09-2013 03:39 PM
Dynosty FR-S/BRZ Fuel System Upgrades! Deatschwerks DW65C Fuel Pump Dustin@Dynosty Engine, Exhaust, Bolt-Ons 3 08-21-2012 04:53 PM
