Old 05-09-2014, 04:53 PM   #113
steve99
Drives: FT86
Originally Posted by AL008 View Post
Hrmm.. Not too sure why my IAM was pulled but I experienced no knock...
http://datazap.me/u/toy-sooby/casual...ata=1-3-5-9-11
your getting a lot of FLCK knock correction when the IAM drops see part of your log below. (derived from looking at your KC Learned values.
If you log FLCK on your OFT as well you will see it. If you get enough of either FLCK or FBCK (Knock correction) it will drop IAM,
http://datazap.me/u/toy-sooby/casual...zoom=3093-3806
and again here
http://datazap.me/u/toy-sooby/casual...zoom=4979-5134
It back to run better fuel (United 100 octane)or pull a bit more timing in problem areas
both times it was arround 2500rpm load 0.8 so if you pull a bit of timing 2400-2600 load 0.7 0.8 0.9 should sort it.
but log FLCK first so its easier to gauge the amount of correction and pull maybe half what the ecu is pulling.
Old 05-09-2014, 05:06 PM   #114
steve99
Drives: FT86
Originally Posted by jamesm View Post
there was tons of knock... just not FBKC. you were pulling timing from FLKC, which isn't loggable via OFT on the australian roms. you can see from watching the applied advance value, where it's down to zero in places.
OFT is logging FLCK now but the scaling is a bit suspect on G rom anyway
Old 05-09-2014, 09:52 PM   #115
AL008
Drives: Celica 04
and again here
My FLCK didn't log a single event at all. It was all at 0. This time however, I had knock events happening.
http://datazap.me/u/toy-sooby/casual...data=1-3-11-12
AL008 is offline   Reply With Quote
Old 05-09-2014, 09:59 PM   #116
AL008
Drives: Celica 04
It seems very excessive the amount of timing I have had pulled from these regions yet I am still getting knock...
Old 05-09-2014, 10:10 PM   #117
steve99
Drives: FT86
On 98 RON if you drive in a high gear and get on the throttle its just going to knock a bit in that area. And if your on/off the throttle a few times it will drop your IAM. All you seem to be able to do is reduce it. It does this like crazy on the stock tune as well.
If you change your driving style a bit ie knock it back a gear before you get aggressively on the throttle at low rpm , or just get on the throttle less aggressively at low rpm in a high gear
I've pretty well given up on 98 and just run United 100 RON all the time its much better all over.
Yep looks like your flck logging not working, have you got ofm 1.07.1 and updated oft then applied latest template file ??
Old 05-09-2014, 10:44 PM   #118
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
I'm curious to know....will switching to a better grade/quality fuel (i.e. going from Shell 98RON to United 100) without any further tuning simply reduces knock occurring, but doesn't necessarily add any more power?
I'm half tempted to switch to United 100 but there aren't any United stations in my area. The Shell is literally down the road....and I generally fill up there for convenience sake.
By the way I'm currently getting e-tuning (almost completed) done by @jamesm and I can say that the car feels so much better now compared to the OTS Stg1 that I was using. I would highly recommend his services to anyone thinking about getting a custom tune, especially for us living down under because our fuel quality is quite different to what our friends get overseas.
Fizz is offline   Reply With Quote
Old 05-09-2014, 11:06 PM   #119
steve99
Drives: FT86
If you have significant knock and/or your IAM is dropping to less than one then switching to a highr octane fuel should increase power slightly as the ecu will be able to run full timing advance.
If you were tuned for no knock and iam always 1 then I believe their would be no advantage unless you then advanced timing to take advantage of the better fuel.
+1 on @jamesm
Old 05-22-2014, 09:30 AM   #120
oz_manny
Drives: MY14 Sonic Blue 86 GTS 6MT
@steve99 first and foremost, thanks for the sharing the considerable information in this thread and making the modified file available to us.
I've recently received my OFT and plan to start logging what's happening on my OEM tune, and once I'm comfortable using it, start experimenting with other tunes.
In my case I also have a Crawford BPB kit fitted but unfortunately there are no BPB tunes available yet from Shiv for G series ECUs.
Any advice on any possible side effects of using the Stage 1 OFT or your tune with the BPB on 98RON?
Anyone else in Oz with BPB and advice on OFT tuning options?
oz_manny is offline   Reply With Quote
Old 05-22-2014, 06:31 PM   #121
steve99
Drives: FT86
I dont have BPB so i have not looked at whats been done in the tune. It looks like they change the volumetric efficiency of the engine at certian rpm so i would guess that there are intake and exhaust cam timing adjustments to suit and possibly minor fueling ignition timing adjustments as well.
As BPB tunes are only out for C rom at present if your keen you could compare C rom stage 1 and C rom stage 1 BPB and see what changes were made and copy to g rom.
Or just wait a couple more weeks and they will probably be a G rom tune for BPB
Old 05-22-2014, 07:12 PM   #122
AL008
Drives: Celica 04
http://datazap.me/u/toy-sooby/casual...zoom=9884-9915
I am receiving knock events up to -2.4 @ 2700rpms/0.5 load
but I have already reduced timing to the vicinity of -1.76 in those areas.
Should I continue to reduce these cells by even more? Does reducing timing in the vicinity of these values sacrifice alot of power?
Cheers for the help.
Old 05-22-2014, 07:52 PM   #123
steve99
Drives: FT86
I can only see it pulling about 1.6 but anyway, it looks like you MAF scaling is off quite a bit.
If you have a look at you LTFT its running at over -7% when your in closed loop ie cruise mode so when you jump on the throttle it going to pull 7% off the fuel target and make you run lean when your in open loop mode (agressive throttle movements) so I suspect this running 7% lean is not helping your tip in knock issues.
So it looks like you will benefit from scaling your MAF sensor to get your closed loop fuel trims back down to less than hopefully 2% this will make you hit the correct fueling targets when you open the throttle
I posted up the info here and @vgi has a very useful utility that linked in the post
On 98 RON or even 100 ron your not going to eliminate tip in knock completly but you should be able to do better than you doing
see here for maf scaling
http://www.ft86club.com/forums/showthread.php?t=64790
Old 05-22-2014, 08:49 PM   #124
AL008
Drives: Celica 04
Thanks for your response Steve.
Do you believe that a leak in the overpipe connection to header will cause the LTFT to be around that range?
Last time I eliminated the possibility of a leak on the header to engine side by installing the Grimmspeed header gasket so I'm pretty sure that shouldn't be leaking...
Otherwise typically do stock cars have fluctuations similar to what I am experiencing with the idea that there are no exhaust leaks?
Thanks.
Old 05-22-2014, 09:10 PM   #125
steve99
Drives: FT86
Thanks.
Its not unusual for trims to run around 7 % from memory mine was 5 or 6 in places mine is totally stock
Its also possible its a leak although i would expect it t be worse if it was a leak near 02 sensos
Aftermarket intakes will throw off maf scaling as well
Old 06-03-2014, 07:40 AM   #126
AL008
Drives: Celica 04
Are there any problems using a 02 Spacer in the secondary of the header?
Knock Correction vs Knock Correction Learn values? swift996 Software Tuning 19 11-03-2015 10:09 PM
Dynosty Fuel System Upgrades- Billet Fuel Rails!!! Dustin@Dynosty Forced Induction 4 10-08-2014 10:00 AM
FuelLog (Android) App:~10k miles of MPG, Range, Fuel Prices, Fuel Qty, Etc. MmmDieselFumes Scion FR-S / Toyota 86 GT86 General Forum 28 02-02-2014 08:19 PM
Fuel gauge misreading actual fuel in tank. Scionshaun Scion FR-S / Toyota 86 GT86 General Forum 19 10-09-2013 03:39 PM
Dynosty FR-S/BRZ Fuel System Upgrades! Deatschwerks DW65C Fuel Pump Dustin@Dynosty Engine, Exhaust, Bolt-Ons 3 08-21-2012 04:53 PM
