Old 04-11-2012, 07:49 AM   #15
ZDan
ZDan's Avatar
Drives: '23 BRZ
Copying what I wrote in the FR-S thread:
Dip is a function of cam and tuning for max power at 7000. Tune for 7000 rpm peak and apparently you get anti-tuning at ~half that. I have (had) the same dip on my tweaked 240z 3.1. Doesn't matter what you do with the fuel maps and ignition timing if the engine simiply isn't breathing well at that rpm.
Old 04-11-2012, 08:09 AM   #16
OrbitalEllipses
Drives: Attitude
Originally Posted by Hanzo View Post
Cayman R has the same dip on the curve wonder if it's something to do with the flat engine. Here is the chart, it's on page 17: http://files.porsche.com/filestore.a...ault&version=3
On NASIOC, the dip was attributed to intake manifold design. Wonder if people are replacing intake manifolds on their Caymans to any effect. Likely a combination of that and what ZDan is saying, though I can't claim any verity on the intake manifold statement.
Old 04-11-2012, 09:53 AM   #17
Spaceywilly
ZC6A2B82KC7J
Spaceywilly's Avatar
Drives: 2002 WRX
Originally Posted by Lighting Red View Post
Yeah, that dip between 3500 and 4500 (roughly) is going to feel like quite a pause during acceleration.
It will be easy to avoid it. You will be above or below it most of the time. In normal driving you would shift around 3000RPMS so you wouldn't reach the dip, and when you're trying to accelerate you would be shifting close to redline so you will stay above the dip.
I like this comment on the Insideline article:
firstwagon says:
08:58 PM, 04/10/12
If you're buying an engine... GTI
If you're buying a car... FR-S
Straights are for fast cars. Turns are for fast drivers.
Spaceywilly is offline   Reply With Quote
Old 04-11-2012, 10:11 AM   #18
tripjammer
tripjammer's Avatar
Drives: WRB BRZ limited 6MT
Sounds like the torque in this engine is underrated. Nice!
tripjammer is offline   Reply With Quote
Old 04-11-2012, 10:13 AM   #19
tripjammer
tripjammer's Avatar
that is not much of a dip in the Cayman R...but yeah, it could have something to do with the flat engine or more likely the DI\and port injected heads...
Old 04-11-2012, 10:18 AM   #20
BMWDavid
Drives: '89 911, '06 GTI, '13 BRZ
Remember that Porsche has variable cam timing as well as a second set of cam lobes that give greater lift at some higher rpm transistion point. So they could tune the base cam lobes for a smoother torque curve at lower rpm.
2005 Honda XR650L
1989 Porsche Carrera 3.2 Coupe
2006 VW GTI/DSG
2013 Subaru BRZ WRB Limited 6MT-gone but not forgotten
2014 Nissan Murano SV
BMWDavid is offline   Reply With Quote
Old 04-11-2012, 10:29 AM   #21
brianbot5000
brianbot5000's Avatar
Drives: White WRX Hatchback, Toyota Pickup
Two things... I'm sure they dyno'd the engine during development - why didn't they fix the dip in the torque curve?
Also, this looks great, and it's nice to know the BRZ will have about +5 on both of those curves, just due to the Subaru badges and more realistic looking fender vent.
2013 Subaru BRZ, SSM Limited
vin: 6007xx
build: 3/2012
brianbot5000 is offline   Reply With Quote
Old 04-11-2012, 10:49 AM   #22
Draco-REX
Corner Junkie
Draco-REX's Avatar
Drives: 13 BRZ, 11 STI, 99 RS
If the dip is due to the manifold tuning, then it would make sense. Intake manifolds are designed to resonate like a musical instrument. The goal is, at the target RPM, the air vibrating back and forth in the runners is timed perfectly to force more air into the engine. If the FA20's intake manifold is designed that way, then it's conceivable that at half the frequency the resonance would be on the back swing, which would hinder air from entering the engine.
Granted, this is with just an armchair engineer's understanding of vibrational frequencies in a moving fluid. But the theory makes sense.
Old 04-11-2012, 11:00 AM   #23
Longhorn248
Hook 'em
Longhorn248's Avatar
Haha
Don't forget the color of the car has a direct impact on horsepower as well.
Longhorn248 is offline   Reply With Quote
Old 04-11-2012, 11:05 AM   #24
SUB-FT86
86 Member
Drives: 2013 Toyota 86 2.0T (Asphalt)
Damn that Cayman R has a shitty torque band below 5k. I thought it was going to be nice and flat.
SUB-FT86 is offline   Reply With Quote
Old 04-11-2012, 11:51 AM   #25
ZDan
ZDan's Avatar
Drives: '23 BRZ
It's not as bad as it looks, the torque scale starts at 147, not 0.
Worth noting, where the curve starts at 1500rpm, the Cayman is making ~25% more than FR-S/BRZ *PEAK* torque.
I want a Cayman R, in that snot green color...
Old 04-11-2012, 12:01 PM   #26
linkwpc
linkwpc's Avatar
Drives: 2010 camaro SS
I wonder what would a turbo do for this motor. It would it get over 250hp?
The punching cat!
Drives: 2010 Camaro SS, 2008 Forester XT, 2000 Mustang.
linkwpc is offline   Reply With Quote
Old 04-11-2012, 12:05 PM   #27
Hanzo
Hanzo's Avatar
Drives: Waiting for the ND Miata
Also keep in mind that Cayman R's chart is based on fly wheel not at the wheels.
Hanzo is offline   Reply With Quote
Old 04-11-2012, 12:14 PM   #28
Spaceywilly
ZC6A2B82KC7J
Drives: 2002 WRX
25% more torque for 160% more dollars
Scion FR-S dyno by Insideline = 173 whp @ 7000 RPM, 143 lb-ft @ 2800 RPM Lighting Red Scion FR-S / Toyota 86 GT86 General Forum 121 04-28-2012 04:11 PM
insideline brz sti rendering DIG1992 BRZ Photos, Videos, Wallpapers, Gallery Forum 16 04-02-2012 05:05 PM
Any publication strap this car on a dyno yet? mspeed6 Engine, Exhaust, Transmission 67 02-02-2012 04:48 PM
2013 Scion FR-S: 10 Things You Don't Know (Maybe) - Insideline rmagic Scion FR-S / Toyota 86 GT86 General Forum 56 12-15-2011 05:36 PM
