Old 06-08-2014, 02:58 PM   #295
xxBrun0xx
xxBrun0xx's Avatar
Drives: 2014 WRB BRZ Limited
Looks like it should be about one thread out at the end.
Sent from my XT1053 using Tapatalk
***Edit: An update to this - after over a month since applying blue loctite to the adapter bolt, shifter play has not changed at all. The loctite makes a big difference! ***
xxBrun0xx is offline   Reply With Quote
The Following 2 Users Say Thank You to xxBrun0xx For This Useful Post:
TM (06-08-2014), unsurety (06-15-2014)
Old 06-18-2014, 05:13 PM   #296
daiheadjai
daiheadjai's Avatar
Drives: 2003 S2000, 2008 Fit
Originally Posted by unsurety View Post
lol... I was about to post the same thing about the washer and boot. I did the installation today too, and I'm not the most mechanically inclined. I ripped that boot off too, after cussing and being gentle with it, I figured I probably wasn't going back.
I did not put the washer back on. I may regret not putting some blue loctite on the adapter bolt. But it was actually quite difficult to thread in - I hand tightened it as far as it would go before using a tool as well.
I did notice it was notchier than before. But I still love it. I have MTEC shift springs and Pentosin MTF2 fluid.
I notice a lot of people (myself included) wanted to know how the quickshifter felt in combination with the MTEC springs.
Would you mind giving some thoughts/review?
Thanks!
daiheadjai is offline   Reply With Quote
Old 06-18-2014, 05:41 PM   #297
unsurety
aeiou
unsurety's Avatar
Drives: WRB BRZ
Thanks!
In one word - amazing.
The select few people that I've allowed to drive it loved it. I'm lucky enough that so far, every mod has not made me want to go back to OEM/stock.
MTEC springs are a no brainer. The TRD is a lot more expensive, but I don't regret it at all.
mini review:
In my Camaro, the short shifter had stronger centering springs but I still angled the shift knob and my hand for 2-3, and 5-4 shifts. With the MTEC, all I do is push straight up or push straight down, respectively. It's perfect. I still angle it slightly when shifting quickly, just for peace of mind. But once you try it, the difference is obvious.
When I first shifter after installing the TRD QS, I thought it didn't go all the way into gear! It's much easier for shift timing now. It requires a some more effort, which I really like. I'm not scrawny, I'm not some hulking meathead either... I have no problems getting into each gear with the stock shift knob. 3-2 downshift requires more effort, but not a problem.
TRD QS 3rd vs. 4th gear:
Originally Posted by Shoebox View Post
For that price anyone could get a c6z and have money for a simple heads cam package and make a bunch more power and have a superior handling car. This seems overpriced to say the least. "Have it your way" is basically offering someone a massive dildo to shove up their ass BUT they have the option of choosing the method in which it is inserted....
unsurety is offline   Reply With Quote
The Following User Says Thank You to unsurety For This Useful Post:
daiheadjai (06-18-2014)
Old 06-20-2014, 04:08 AM   #298
drift86
Drives: GT86, 22 BRZ
Another one is the BPS short shifter, which I loved the look of. TWM is an expensive option.
I've tried a TWM short shifter in my friend's car. I didn't like the feel at all and much preferred the stock shifter.
Sure, the shift was much shorter, but it really lacked consistency and feel. Some of the problems were:
- when you move the stock shifter into gear, initially there is some resistance as the synchros do their work and then it lightens up as it 'locks in' to the gear. The TWM did not have this positive feel as the throws were so short, and required more effort that it was just one motion and you can't feel the gear engaging
- the shift throws were different between different gears. 2nd gear was particularly short
We checked the installation and it was properly locked into place so I don't think it was an installation issue.
Does the TRD have these issues?
drift86 is offline   Reply With Quote
Old 06-20-2014, 07:58 AM   #299
unsurety
aeiou
unsurety's Avatar
Drives: WRB BRZ
The quickshifter is really just an extension to the existing shift lever. It's overpriced because TRD. But it works incredibly well because it's so simple.
In my picture above, the angle makes it look off, but the throws in each gear are the same distance. And if anything, the shorter throws make shifting even more precise. It's easier to tell when you're in gear because the distance is easy to get used to. I grinded a few times while stock, but it's hard to do with the QS. It has that same resistance you're talking about, it's more than stock (which is good).
The round piece next to the bolt is essentially the short shifter. The bracket is the main stay bushing, which improves shift feel. Maybe your friend didn't install one?
Old 06-20-2014, 08:05 AM   #300
unsurety
aeiou
unsurety's Avatar
Drives: WRB BRZ
I do have one complaint about the shifter though. The short travel coupled with the higher resistance getting in/out of gear makes it harder to get into neutral. You end up using more force to get out of gear, and sometimes shoot past neutral into the next gate.
Minor complaint, easy fix. Just push sideways when going into neutral.
Old 06-26-2014, 02:42 PM   #301
Zed
Drives: 2013 Subaru BRZ Limited GBS
Any BRZ owners that got this installed at a dealer? did you go to Toyota or Subaru? how much was the install cost?
Zed is offline   Reply With Quote
Old 06-26-2014, 07:09 PM   #302
SuperKazRacing
Drives: 2013 RED FR-S
Originally Posted by jpit View Post
Bought it from this Toyota/Scion dealer for $135 with free shipping (use code FB10).
http://www.conicellitoyotaofconshohocken.com/
HOW THE F#CK DID YOU FIND IT ON THEIR SITE ? I TRIED # PTR 54-18130
and TRD QUICKSHIFTER and NOTHING ????????
SuperKazRacing is offline   Reply With Quote
Old 06-26-2014, 07:17 PM   #303
nosi9frs
nosi9frs's Avatar
Drives: Raven FR-S
You need to search for toyota parts instead of scion parts, I had the same problem a few months ago
nosi9frs is offline   Reply With Quote
The Following User Says Thank You to nosi9frs For This Useful Post:
SuperKazRacing (06-26-2014)
Old 06-26-2014, 07:38 PM   #304
SuperKazRacing
OK Boy's and Girl's ! Derek Jenkins @ CONICELLI TOYOTA just hooked me up for $135 Shipped ! They Have 11 More !!! Just wanted to share on the Best Price Anywheres ......
Old 06-27-2014, 11:37 AM   #305
CamryDS
Drives: 2003 Camry Blue | 2013 FR-S White
Going to call up larer this morning to pick one up!!
Sent from my SM-N900P
Excuse the typos
CamryDS is offline   Reply With Quote
Old 06-27-2014, 12:25 PM   #306
formulagt
formulagt's Avatar
Drives: 13' FJ Cruiser TT | 13' 10 Series
Just tried to get the same deal, their cost is $152 so you got a helluva a deal LOL. I even called there.
formulagt is offline   Reply With Quote
Old 06-27-2014, 12:48 PM   #307
CamryDS
bah I won't be calling ebaying it from another toyota dealership is 150 =/
Old 06-27-2014, 01:03 PM   #308
formulagt
formulagt's Avatar
They'll do $148 shipped so that's the current pricing. Just an FYI.
TRD Quickshifter lovebeingbleu98 Brakes, Suspension, Chassis 3 02-13-2014 01:14 AM
Amazing Wax geb2391 Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 27 04-12-2013 05:42 PM
The most amazing thing I've done with my BRZ so far azngolfur BRZ Photos, Videos, Wallpapers, Gallery Forum 8 01-09-2013 09:23 PM
Concept-Three-LED's DRL's are AMAZING! soros151 Cosmetic Modification (Interior/Exterior/Lighting) 4 11-09-2012 02:42 AM
